RV10 door seals
Ed Godfrey
PostPosted: Sun Sep 16, 2012 11:12 am    Post subject: RV10 door seals Reply with quote
Has anyone installed the door seals from
http://www.rvtraining.com/html/atp/html/accessories.html and if so, what
is your experience with them. I am at a fork in the road as to which
seals to go with. Looking at the ones on the factory demo, I wasn't
impressed with the use of the blind rivets to hold it in place. Also,
although the use of the McMaster seals is intriguing, I guess I have
some reservations about sanding away so much of the door opening.
Therefore, I was wanting to see if there was any feedback on the seals
from rvtraining. Thanks.
Ed Godfrey
40717
carl.froehlich(at)verizon
PostPosted: Sun Sep 16, 2012 12:03 pm    Post subject: RV10 door seals Reply with quote
I did the easy way. I used 3/8" self adhesive McMaster seals on the door.
The seal is inside the door lip so you don't do the grinding. I filled in
the hinge area with a piece of rigid foam (held in the RTV) so that the seal
lays on top. Once you have the hinge area filled the seal goes on a just a
couple of minutes. The adhesive is quite adequate. 44 hours (and countless
door opening and closing) and it works well.
Part number: 93085K11
http://www.mcmaster.com/#catalog/118/3471/=jbjp4s
$11 for 20 feet. I tried 1/2" tall seal first, but this was too much and
the door was way hard to close. The 3/8" gets compressed, but not enough to
deform the door.
Carl
 Filesize:  140.26 KB
 Viewed:  10989 Time(s)
amekler
PostPosted: Sun Sep 16, 2012 12:31 pm    Post subject: RV10 door seals Reply with quote
Carl,
My door only leaks at the hinge.
Can you give more details on how you handled the hinge?
Alan
On Sep 16, 2012, at 4:03 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net> wrote:
[quote] I did the easy way. I used 3/8" self adhesive McMaster seals on the door.
deform the door.
Carl
rv10flyer
PostPosted: Sun Sep 16, 2012 2:30 pm    Post subject: Re: RV10 door seals Reply with quote
Just cut out some .032" or thicker pieces that fit the hinge openings perfectly. Proseal in for easy removal later. Paint. You can do that with McMaster Carr seals like I did or those type in the pic. Mine leak zero.
Wayne G.
PostPosted: Sun Sep 16, 2012 3:11 pm    Post subject: RV10 door seals Reply with quote
Nothing special. Just rigid foam insulation material carved with a razor
knife to fill up the hinge area so that the top of the foam was flush with
the inside of the door. I used RTV to glue these into place.
The hardest part was finding this material in black instead of the Lowes
pink. I happened to have some material left over from the steel siding on
the hangar door that worked well. If you get the pink, don't try to paint
it black as the paint will melt it (yes - I tried). If all you can get is
the pink, then carve it to fit and put a thin coat of black RTV over the
side that faces out.
Carl
Strasnuts
PostPosted: Sun Sep 16, 2012 3:32 pm    Post subject: RV10 door seals Reply with quote
Here is mine with the McmasterCarr seal 1120A311 No leaks at all. I used
nutplates for the hinges even though you could still use nuts.
 Filesize:  1.1 MB
 Viewed:  10972 Time(s)
 Filesize:  1.07 MB
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
amekler
PostPosted: Sun Sep 16, 2012 3:33 pm    Post subject: RV10 door seals Reply with quote
Carl,
Thanks.
My plane is 3 years old and i dont't know what kind of seal it has(it is not on the door) cold air comesvin at the hinge site otherwise it is a nice fit.
Not sure whether i should replace the whole seal or just do something at the hinge.
Alan
On Sep 16, 2012, at 7:11 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net> wrote:
Carl
rleffler
PostPosted: Sun Sep 16, 2012 4:25 pm    Post subject: RV10 door seals Reply with quote
Most people fiberglass over the opening to make it flush with the door. I just used a piece of scrap fiberglass, cut it to size, epoxied it in place, then a little micro to make things smooth. This gives a nice surface for any type of seal you choose.
On Sep 16, 2012, at 7:32 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Carl,
Thanks.
Alan
> Carl
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
robin(at)PaintTheWeb.com
PostPosted: Sun Sep 16, 2012 4:57 pm    Post subject: RV10 door seals Reply with quote
Here is our fiberglass bridge.
http://painttheweb.com/painttheweb/rv-10/Images/Doors/Door_(14).jpg
Robin
Sent from the new iPad
> Carl,
> Thanks.
> Alan
> Sent from my iPhone
>> Carl
rene(at)felker.com
PostPosted: Sun Sep 16, 2012 5:54 pm    Post subject: RV10 door seals Reply with quote
I used them. Work great.....
Mauledriver(at)nc.rr.com
PostPosted: Mon Sep 17, 2012 8:03 am    Post subject: RV10 door seals Reply with quote
That's a real good pic to reference for handling the hinge in the door.
I bridged mine too but sealed it all up so there is no access to the
hinge nuts. In other words, the hinge half is in place permanently.
I carved up some blue foam then laid some thin glass cloth over it.
(Note that 2 different kinds of McMaster-Carr seals are being referenced
in this thread. They are completely different from one another.)
Bill "getting ready to touch up some paint around the windshield" Watson
Robin
> Bob
> Sent from my iPad
John Ackerman
PostPosted: Mon Sep 17, 2012 4:58 pm    Post subject: RV10 door seals Reply with quote
I'm very happy with the rvtraining seals. Much better than my attempt at using van's seals.
On Sep 16, 2012, at 12:11 PM, egodfrey(at)ameritech.net wrote:
Has anyone installed the door seals from http://www.rvtraining.com/html/atp/html/accessories.html and if so, what is your experience with them. I am at a fork in the road as to which seals to go with. Looking at the ones on the factory demo, I wasn't impressed with the use of the blind rivets to hold it in place. Also, although the use of the McMaster seals is intriguing, I guess I have some reservations about sanding away so much of the door opening. Therefore, I was wanting to see if there was any feedback on the seals from rvtraining. Thanks.
Ed Godfrey
40717
hotwheels
PostPosted: Tue Sep 18, 2012 7:52 am    Post subject: Re: RV10 door seals Reply with quote
All I did to create a couple of pockets was to epoxy in a couple of balsa wood pieces cut roughly to shape. Then fill with micro and sand. Turned out pretty nice.
Jay
 Filesize:  357.29 KB
 Viewed:  10893 Time(s)
 Filesize:  407.65 KB
