dosmythe(at)cox.net Guest
Posted: Sat Jun 03, 2006 12:36 pm Post subject: West System Epoxy answer |
Guy,
Like I said the other day, you would probably have to cut an access hole
in the tops of the tanks in order to be able to reach all the insides. The
hole might have to be 12 inches square or whatever it takes to reach all the
insides. Could possibly be done. After that, just fabricate an aluminum
plate for the hole and attach with flush screws. This is just a thought in
case many of us might have to make drastic changes due to ethanol or
whatever. I personally would rather consider this type approach than doing
a blanket tank change out.
Don Smythe
roncarolnikko(at)hotmail. Guest
Posted: Sat Jun 03, 2006 1:35 pm Post subject: West System Epoxy answer |
I am in favor of Brads' fuse tank only using our old tanks for a
compartment. I could put a smaller tank inside of mine which would still
outlast my bladder. The cg would not be a problem then. Could be prefabbed
and dropped in Dons' hole with a flange built on top to rivett over the hole
and be done quickly. Ron NB Ore
[quote]From: "Don Smythe" <dosmythe(at)cox.net>
Subject: Re: Re: West System Epoxy answer
Date: Sat, 3 Jun 2006 16:33:31 -0400
Guy,
hole
the
Don Smythe
