pipercolt
Joined: 08 Jan 2012 Posts: 46 Location: Randolph New York
Posted: Thu Sep 13, 2012 6:13 pm Post subject: GSC propeller |
I have a Kolb Mk 111 with a Rotax 582. Has anyone had any experience with GSC propellers?
Posted: Thu Sep 13, 2012 7:58 pm Post subject: GSC propeller |
<bob.pipercolt(at)yahoo.com>
Had a 3 blade GSC prop fail, Sep 1993. Collected all 3
blades on the tail boom. Had to replace the tail boom.
Immediately started flying Warp Drive props, and have for
more than 3,000 WD since then, on 582, 912UL and 912ULS.
Attached are photos of GSC and Warp Drive Blade Grips. No
comparison between the two.
Rock House, OR
36.74 KB |
9093 Time(s) |
36.77 KB |
9093 Time(s) |
_________________ John Hauck
Titus, Alabama |
brubakermal(at)yahoo.com Guest
Posted: Thu Sep 13, 2012 8:46 pm Post subject: GSC propeller |
I had one on my plane, the people in the shop are great to talk to, easy to get along with and understand. Give them a call thell set you up. I like the look of wood and becouse it is wood alot of people seem to replace them as soon as they buy a plane that has one so, used ones are easy to find and cheep But still worth the money.
Thanks To the people who responded to my firestar request were still looking but got a couple leads. Please call if you would consider selling your firestar. mal
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com/
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Sent: Thursday, September 13, 2012 10:13 PM
Subject: GSC propeller
--> Kolb-List message posted by: "pipercolt" <bob.pipercolt(at)yahoo.com (bob.pipercolt(at)yahoo.com)>
http://forums.matronics.com/viewtopic.ptronics.com/Navigator?Kolb-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Dana
Posted: Fri Sep 14, 2012 2:39 am Post subject: GSC propeller |
At 11:56 PM 9/13/2012, John Hauck wrote:
| Quote: | Had a 3 blade GSC prop fail, Sep 1993. Collected all 3
blades on the tail boom. Had to replace the tail boom. |
John, I assume that was on the ground?
Dana
There are 3 kinds of people: those who can count & those who can't.
Dana
At 10:13 PM 9/13/2012, pipercolt wrote:
| Quote: | --> Kolb-List message posted by: "pipercolt" <bob.pipercolt(at)yahoo.com>
Thanks |
Had one on a PPG and was very happy with it.
Dana
Posted: Fri Sep 14, 2012 6:25 am Post subject: GSC propeller |
Dana
Was climbing full throttle. Probably had the dual K&N air
filter go through the GSC, but cannot say for certain.
Never found it. If I had had the filter safety wired, I
would know for sure it did not go through the prop.
The 582 immediately shut down as the carbs were thrown from
the sockets, and the starter was ejected from the mag end of
the engine. Carbs and starter were captured by the cables.
Made a forced landing in the smallest "shoe box" sized field
I have ever landed in without putting a scratch on the
MKIII.
Rock House, OR
Titus, Alabama |
Dana
Posted: Fri Sep 14, 2012 9:18 am Post subject: GSC propeller |
So what did it do to the tail boom that you were able to land it, but had to replace it? Makes me feel a bit better about the tailboom's safety factor...
-Dana
At 10:22 AM 9/14/2012, John Hauck wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
MKIII.
Rock House, OR
Email Forum -
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruit salad.
Posted: Fri Sep 14, 2012 11:48 am Post subject: GSC propeller |
-Dana
As you can imagine, there was a pretty good size dimple in
the side of the boom tube in the area of the H brace. The
tail boom was struck hard enough to knock it about 5 degrees
out of column. I had no idea that the tail boom was bent
until after the forced landing. In fact, all I knew was
there was a terrific explosion, followed by severe vibration
momentarily, then severe quiet. I had a small rectangular
field surrounded on two sides by high tension power wires,
one side by a large bamboo thicket and the other side by
tall trees.
The tail boom is tough, both 5 and 6 inch boom tubes. They
are also very flexible which prolongs their life in the
severe environment that they live.
Scratches and nicks in the surface of the tube would be
cause for concern. However, I know of one boom tube, 5",
that got nicked and dimpled from FOD. The owner/pilot used
scotch bright wheels to buff and polish out the surface.
Flew many hours, then sold the aircraft to a really big
pilot. The FSII continues to fly safely.
Rock House, OR
Titus, Alabama |
gajindra(at)sbcglobal.net Guest
Posted: Fri Sep 14, 2012 3:03 pm Post subject: GSC propeller |
Had a GSC on my 582 till an axle bolt broke on landing and went thru the prop.Split one blade from tip to root.Replaced with an IVO.Love the IVO.But I also liked the GSC till it broke.Replaced the AN 3 axle bolts with AN 4 bolts
Gary Jindra
Mark 3c
99 hours
Sent: Thu, September 13, 2012 10:13:13 PM
http://forums.matronics.com/viewtopic.php?p=383023#383023
Matronics List Features Navigator to /www.matronics.com/Navigator?Kolb-List" target=_blank>http://www.matronicsp; -Matt Dralle, List Admin.
