Dynamic propeller balancing sensor.
aero(at)rwaltman.com
PostPosted: Thu Sep 06, 2012 8:33 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
I'm beginning to look into how difficult would it be to make my own
"poor man's" dynamic prop balancer.
Any recommendation for an of-the-shelf accelerometer to be used as sensor?
Roberto Waltman
PostPosted: Thu Sep 06, 2012 10:03 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
At 11:32 AM 9/6/2012, you wrote:
--> AeroElectric-List message posted by: Roberto Waltman <aero(at)rwaltman.com>
I'm beginning to look into how difficult would it be to make my own "poor man's" dynamic prop balancer.
There are a number of variable capacitor accelerometers offered
on eBay. You'll also need a charge amplifier and a 'charge-stable'
coax signal cable to run between the accelerometer and
amplifier.
http://tinyurl.com/9hhege2
http://tinyurl.com/9o324vg
http://tinyurl.com/8nd2y9y
The output of the amplifier may need to be filtered to
get rid of vibrational noises. I'm thinking a band-pass
filter centered on the vibration-frequency of some
handy test rpm would do the job.
Since your data is only used for comparative measurements,
calibration is not an issue. You could build your own
charge amplifier
http://tinyurl.com/d4t67hd
If charge amp is built into a single assemlby with
the accelerometer, you can do away with the fancy
'low capacitive noise' coax.
Then read the conditioned signal with an rms reading
voltmeter. This setup will only give you gross unbalance
data . . . it won't tell you which blade is heavy.
But test weights will quickly reveal whether adding
some small weight made things better (light blade)
or worse (heavy blade).
Just saw this critter
http://tinyurl.com/8ejraxb
which seems to be an internally signal conditioned
device. You could google the device and see
if there are any user's manuals floating around
out there.
I wasn't aware of this product.
[img]cid:.0[/img]
Signal conditioning built in and designed for
use on machine tools. See:
http://tinyurl.com/8v3ejxe
Looks like just what you need. You'll still need
to filter irrelevant vibrations so that you can
take a close look at the relevant data.
 Filesize:  34.56 KB
 Viewed:  12593 Time(s)
PostPosted: Thu Sep 06, 2012 12:14 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
Brilliant! I was planning to go the FFT and Adroid tablet GUI way.
For the one single airplane/propeller that I want to take care of, your
suggestion is perfect.
device.
Thank you very much for the pointers. (If going with capacitive sensors,
I almost forgot about the existence of charge amplifiers. Worked with
Kistler force plates, years ago.)
Roberto Waltman
PostPosted: Thu Sep 06, 2012 1:59 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
Thank you very much for the pointers. (If going with capacitive sensors, I almost forgot about the existence of charge amplifiers. Worked with Kistler force plates, years ago.)
I've used up this month's 'play money' exploring
some thermocouple readouts off eBay . . . but
as soon as it's doable, I'll pick up a self-amplified
accelerometer and get educated. I've got some
work coming over the hill that might benefit from
this technology.
Here's an exemplar band pass filter for 30 Hz, (1800
propeller RPM).
[img]cid:.0[/img]
This is a rough order of magnitude swipe at the task.
You can fiddle with alternative gains, center frequency and bandwidth at:
http://tinyurl.com/9xwbwfm
Good luck!
 Filesize:  111.3 KB
 Viewed:  12590 Time(s)
Eric M. Jones
PostPosted: Fri Sep 07, 2012 4:56 am    Post subject: Re: Dynamic propeller balancing sensor. Reply with quote
Bob's inputs here are great.
Here's my two-cents:
GovernmentLiquidations.com frequently has complete Chadwick Helmuth vibrex and strobex units for cheap. A business in a box! These are very professional units that are still used (for helicopters mainly...but hey, they still use propellers). Alternatively, pick up stuff from Ebay.
Failing this, if you still want to roll your own, at least grab some C-H Strobex manuals to see how they do this, online: http://www.scribd.com/doc/40565507/Strobex-Manual .
BTW: I knew and worked with Jim Helmuth personally when I worked on Endoscopic Strobo-Laryngoscopy for vocal cord vibration analysis. He was a brilliant, gentle and greatly admired man (Chadwick was the biz man, Jim Helmuth the engineer.) We all watched helplessly as he smoked himself to death far too young because he couldn't break his cigarette addiction. Damned shame.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Fri Sep 07, 2012 7:15 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
Looks like a valuable addition to the archives.
Do you have a membership to download this?
The guy had an impressive resume. He's referenced
a lot in the arena of lightning-in-a-jar.
Eric M. Jones
PostPosted: Fri Sep 07, 2012 10:37 am    Post subject: Re: Dynamic propeller balancing sensor. Reply with quote
Sorry Bob,
But the whole PDF appears to be there. The download is $9. An enterprising person could image grab it all some rainy Sunday.
C-H's manual called "Smooth Propeller" and the Vibrex 2000 manuals are good too. I can't believe the military doesn't have free downloads on all this stuff.
Maybe some AeroElectric lister can find them.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
PostPosted: Fri Sep 07, 2012 2:03 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
At 01:37 PM 9/7/2012, you wrote:
Sorry Bob,
No problem. Next time I have enough wishes in
the que, I'll pay the one-day feed and go grab
some stuff. But if I get flush (got a couple
of $jobs$ on the back burner) I'll get a year
subscription. Scribd is a fantastic resource.
PostPosted: Fri Sep 07, 2012 6:04 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
...it won't tell you which blade is heavy.
Not being a mechanical engineer, that's all I could think.
Fortunately, other peoples are. [Mech engineers, physicists,
etc.]
See slides 36 to 42 in this presentation:
sem.org/PDF/Suri_Rotor%20Balancing.pdf
Roberto Waltman
PostPosted: Fri Sep 07, 2012 7:18 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
Fortunately, other peoples are. [Mech engineers, physicists, etc.]
Cool! That's a flashback to and engineering graphics
course I took way back when . . . The dudes that
figured out that process had some pretty twisted
grey matter. One of those cases where a protractor,
compass and ruler can be used to yield some interesting
results. There's a process using similar tools whereby
you can use star sightings to draw circles representing
lines of possible position (each star sighting has
an infinite number of possible positions which inscribes
a circle on the surface of the earth). Plot LOP from
three stars and the intersection of three circles
is pretty close to where you're at. Love it . . .
Hmmm . . . I wonder if this would adapt to a
two bladed system? Anybody out there with sufficient
twist in the cognitive neurons?
millner(at)me.com
PostPosted: Fri Sep 07, 2012 7:24 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
>> This setup will only give you gross unbalance data . . . it won't
tell you which blade is heavy. But test weights will quickly reveal
whether adding some small weight made things better (light blade) or
Typically with dynamic balancing, though, one isn't just adding weights
to one blade or the other, but rather just the right amount of weight at
just the right circumferential point on the hub... Typically, NOT at the
blade attachment location.
Perhaps your technique will give you sufficient resolution for that, I
haven't investigated... but your heavy/light blade reference concerns me
in that regard.
Paul
PostPosted: Fri Sep 07, 2012 7:55 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
It is not a three-blade system. It is a rotating mass, of
any geometry, measured/balanced by placing sample weights
120 degrees apart. I assume you need at least three to make
the intersection of the three circles unique.
Roberto Waltman
PostPosted: Fri Sep 07, 2012 9:14 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
It is not a three-blade system. It is a rotating mass, of any
geometry, measured/balanced by placing sample weights 120 degrees
apart. I assume you need at least three to make the intersection of
aHHH . . . but of course. Guess it would be
pretty hard to make this work on a two bladed propeller
unless you could put the weights on the hub.
I suspect the professional chasers of propeller
shake use a methodology not unlike the old Bear
alignment systems that used a strobe to mark wheel
position when the heavy (or light) spot was straight
up or straight down. I remember my mechanic putting
a chalk mark on the tire and using the 'scope to
clock the chalk mark. The 'scope only located the
weight, he put his hand on the fender to judge when
he was getting close to the right weight . . . if
he overshot, the 'scope would report a swap of
the heavy/light sides.
Kinda crude by today's techniques but it sure
worked better than the static bubble balance
method.
dave.saylor.aircrafters(a
PostPosted: Fri Sep 07, 2012 9:38 pm    Post subject: Dynamic propeller balancing sensor. Reply with quote
We balance props on a regular basis using an ancient Chadwick. It
usually takes about an hour.
The Chadwick system uses an accelerometer and a strobe. A black box
calculates when the acceleration reaches it peak and flashes the
strobe at that point. The box also indicates a quantity for the
vibration, in units of "inches per second", or IPS.
There's also a mag pickup system but that's more for helicopter main rotors.
Since the peak occurs when the heaviest part of the weighted disc is
adjacent to the accelerometer, you know where to add weight (opposite
the accelerometer, with the target positioned as it appeared in the
flash).
The user fine tunes the flash rate by watching for shift in the target
position while pushing a tuning button, and simultaneously adjusting
for RPM. It takes a little practice but once you know what to watch
for it's pretty easy.
Chadwick used to have an FAA-approved pamphlet called "The Smooth
Propeller" that talked about how and where to add weights. It's
pretty much trial and error until you get a handle on how much weight
has a resulting effect.
Dave Saylor
831-750-0284 CL
On Fri, Sep 7, 2012 at 10:12 PM, Robert L. Nuckolls, III
> It is not a three-blade system. It is a rotating mass, of any geometry,
> measured/balanced by placing sample weights 120 degrees apart. I assume you
> need at least three to make the intersection of the three circles unique.
method.
PostPosted: Sat Sep 08, 2012 4:46 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
That's were they normally go. Small washers...
The blades are expected to be already statically balanced.
That is, same weight, but not necessarily same weight
distribution. That's why dynamic balancing is needed.
Modern system do not use a strobe light. An accelerometer
and an optical sensor are mounted near the prop, and a
reflecting tape is mounted on the prop itself, but not as a
reference for a strobe. A computer reads data from both and
provides vibration amplitude and phase information as a
guide to be used placing weights.
Products:
http://www.rpxtech.com/rpxweb/Dynavibe.asp
http://www.smartavionics.com/pb3/pb3.html
http://dssmicro.com/products/prod_mb_main.htm
http://dssmicro.com/products.htm
A field report (Vibrex):
http://www.dvatp.com/aviation/maintenance/dynamic_balancing/
Roberto Waltman
klehman(at)albedo.net
PostPosted: Sat Sep 08, 2012 5:19 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
I have a commercial unit that uses the ADXL103 acceleration sensor. I've
also experimented with that chip (actually one channel of an ADXL203) to
do a little monitoring of propeller and bearing condition.
The overall concept is to bounce an infra red signal off reflective tape
on one prop blade to get rpm and the phase of the imbalance. Add a
weight and repeat the run. Compute a suggested change in phase and
magnitude which can be done in software or with a paper vector diagram.
ie. suggest a relative change in the size of the weight and how many
degrees of prop rotation to move it forward or aft.
FWIW on the few props that I've tested, I've yet to find a significant
improvement on Warp Drive props or on two blade metal props that were
already in obvious good condition. And I've greatly increased my opinion
of how sufficient static prop balancing can be. Graybeards can static
balance to within a few spray puffs of paint on the tips. That would be
with the prop on a horizontal mandrel and the mandrel resting on knife
edges.
It is easy to chase insignificant apparent imbalances that are different
at varying engine rpms but it was certainly educational.
Ken
Roberto Waltman
millner(at)me.com
PostPosted: Sun Sep 09, 2012 9:38 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
>> Modern system do not use a strobe light. An accelerometer and an
optical sensor are mounted near the prop, and a reflecting tape is
mounted on the prop itself, but not as a reference for a strobe. A
computer reads data from both and provides vibration amplitude and phase
information as a guide to be used placing weights.
The new Insight G3 engine monitor is to eventually include a real-time
vibration monitor. Whether it will be capable enough to suggest
location and size of balance weights, I do not know. It wasn't
functional on version 0 IIRC.
Paul
Products:
PostPosted: Mon Sep 10, 2012 8:46 am    Post subject: Dynamic propeller balancing sensor. Reply with quote
Found a copy here:
http://www.expaircraft.com/PDFgallery.htm
Roberto Waltman.
