occom(at)ns.sympatico.ca Guest
Posted: Thu Jun 01, 2006 1:07 pm Post subject: Spars / repairs |
I've just agreed to buy a Mod IV. It must be an earlier one as the uphostery
says Denney under the logo. It's very nicely done but is damaged. The rear
spar is broken and repaired with a sleeve over the tube just outboard of the
rear strut attachment. I don't have the plane or books yet and I guess I
have some reading ahead but I'm doubtful about such a repair. Is this type
of thing done?
The Sportplane LLC site says they have spars if that is the way to go.
lcfitt(at)sbcglobal.net Guest
Posted: Thu Jun 01, 2006 2:42 pm Post subject: Spars / repairs |
Dave, I personally am not comfortable with a spar repair. I guess if it
was engineered - OK, but one of the bragging rights we have as Kitfox pilots
and owners is the history of structural integrity. Trying to invision the
spar replacement - it won't be a small task though. Where are you located.
Lowell
dave(at)cfisher.com Guest
Posted: Thu Jun 01, 2006 2:55 pm Post subject: Spars / repairs |
Hi Dave,
Spar Damage is a major problem.
Only fix is a new spar and I would bet you will be needing an entire wing.
To remove ribs all intact will be highly unlikely and very labour
intensive, plus what else is damaged ? If the spar got that damaged then
surely it is likely that more could be found. Where is this Kitfox
located now ?
I see by your email you are in Nova Scotia. I am in Ontario.
Dave
Posted: Thu Jun 01, 2006 3:37 pm Post subject: Spars / repairs |
The aircraft is about 85 KM away in Brookfield N.S. I can get it home in a
couple of hours. The damage was not caused in motion, I am told it was
flipped in wind. It all looks very good with the exception of the wings
needing new covering, several ribs have been replaced I'll get some pictures
when I get it home.
Posted: Thu Jun 01, 2006 9:30 pm Post subject: Spars / repairs |
Hi Dave,
I agree, replace the spar or the entire wing.
Why was the spar busted? Could it have been from
something that hurt other parts too?
If the wing had a chance to flex when the spar was
broke, the ribs may be weakened by rotation or the
epoxy come unattached from the spar.
This is not worth the risk to find out in flight.
Kurt S.
--- "Dave G." <occom(at)ns.sympatico.ca> wrote:
| Quote: | I've just agreed to buy a Mod IV. It must be an
a repair. Is this type of thing done?
is the way to go.
Posted: Fri Jun 02, 2006 1:57 am Post subject: Spars / repairs |
Thanks Kurt. I just got a reply from the new Kitfox and spars are reasonably
priced. I'll be replacing it. I'll post pictures when I actually get it
home. That is tomorrow, course it's going to rain.
Posted: Fri Jun 02, 2006 10:55 am Post subject: Spars / repairs |
Dave,
Lots of folks have disassembled wings for various reasons, it is doable. I
am sure when you get to that point there will be lots of tips from the list.
The new spar is the way to go. After stripping the fabric you will get a
good look at ribs, etc and can make a judgement as to what can be re-used.
Lowell
kitfox(at)ida.net Guest
Posted: Fri Jun 02, 2006 10:48 pm Post subject: Spars / repairs |
If it was me. I would allways wonder what else was damaged. The correct and
safe mode. Replace the wings. Just an idea.
Those kind of stresses and damage have not been evaluated. The real story is
you have no idea about the condition of the rest of the pieces of the wing.
It has not been tested or proven.What about the rest of the plane? Lot of
stress to wipe out a wing. We all hear about wing stress loading and failure
point. What we do not continue to read is the damage on the rest of the
structure to get it to that point.
Albert
