Posted: Tue Sep 04, 2012 1:38 pm Post subject: Battery Tender performance |
I have known this for some time (since the time I gathered
the plots at: http://tinyurl.com/8o65jha and http://tinyurl.com/9paguuy
A more recent plot I published a few days ago for my Battery Tender
Jr. had a recharge curve for 12 a.h. battery that looked like this:
[img]cid:.0[/img]
Not much of a top-off cycle. No absorption dwell . . .
So I ran some new plots on Ron's 12 a.h. batteries and my
10 year-old Battery Tender. Here's what I got.
[img]cid:.1[/img]
These plots confirm the question as to whether batteries 'charged' with
the Battery Tender really get topped off. Two cycles of Battery Tender
only recharge produced the red and green plots. A third cycle was
augmented with a 3 hour top-off which was still drawing about 150 mA
at 14.5 volts.
The third, topped off cycle stored about 60 minutes more service
at a 1.2A rate than for the un-augmented cycles.
I've given away all my SEC1562 chargers to family members.
Got a new one ordered yesterday. I'll run some charge/discharge
cycles on the same battery. I think we'll find that the Minders
and Tenders are not designed to top off SVLA batteries of any
size.
Does that mean they're 'bad' chargers? No, in instance under
study the Battery Tender still put ~90% of the battery's total
capacity back in storage.
I've used the Battery Tender to charge and maintain a family
of instrumentation batteries for years. I retired a couple
of test batteries last year that were over 10 years old
and tested to better than 75% of new. So it MIGHT be said
that cycling a battery less aggressively is good for
service life . . . but for sure, the battery maintainer
products are best used to store batteries that are fully
charged when put away.
The next chapter will be written when the new 1562 gets
here. Given the very reasonable price ($20) it may well
be that the SEC1562A is about the best value out there
for a top-off charger-maintainer.
60.15 KB |
6284 Time(s) |
192.73 KB |
6284 Time(s) |
raymondj(at)frontiernet.n Guest
Posted: Tue Sep 04, 2012 3:30 pm Post subject: Battery Tender performance |
Sorry if I missed it, but could you define tender vs maintainer vs smart
charger vs old style charger in terms of expected charge profiles for
typical batteries used in OBAM aircraft.
Raymond Julian
On 09/04/2012 04:36 PM, Robert L. Nuckolls, III wrote:
snip
size.
rparigoris
Posted: Tue Sep 04, 2012 3:31 pm Post subject: Battery Tender performance |
Hi Bob
Thx. for taking the time and effort to share your findings.
Again the batteries I was referring to were abused and discharged repeatedly below 12.4 volts.
It would be interesting to see the results you achieve if you use the chargers I sent you. They are 500mA constant current chargers that do nothing more than turn off ~ 15.4 volts, but that allows a reasonable dwell above the 13.7 float voltage.
Ron Parigoris
Posted: Tue Sep 04, 2012 5:21 pm Post subject: Battery Tender performance |
Bob, your previous posts on this topic of using a "Battery Tender" as a "charger" was the key to helping me unravel a set of problems I was having with my Odyssey 680s. Just wanted to say thanks and to share my experience if others may find it useful.
I have a Z-14 with 2 680s. Very early in my build I bought 2 680s (which really weren't needed at the time) to ease design of the battery box but they were actually used very little. They were charged a few times and occasionally maintained (hooked up overnight even though they had not been discharged) with the brand name "Battery Tender". A few years later when I was 90% done with 90% to go, I decided to get fresh batteries (not quite at the same time and these weren't needed at the time either). These batteries were used quite a bit in panel testing and such. These were also charged and maintained with the battery tender (many cycles).
When I finally got to first flight, I found that neither of the new batteries would turn over the IO540 on my RV10. When both batteries were cross fed, no problem but alone, neither battery could quite turn the cold engine over. Per Bob's posts, I suspected that use of the "Tender" was my problem. A trip to Walmart turned up a suitable charger with settings for Gel vs Lead vs (glass mat?). One charge and now one of the new batteries was a tiger and the other got a lot better.
The way I intended to use my 2 batteries was to normally use one to power the EFISs and most of the rest of the avionics. The other was for starting. After start, the batteries would be cross fed. This now worked but my avionics panel would start to go dim after 5 minutes or so unless the engine was started and the alternators were online. I was hoping for more.
After much data collection, a carbon pile tester, and some additional field experience it turned out that the batteries I bought some 4 or 5 years ago were still in great shape once charged with the new charger. Furthermore, 1 of the new batteries seemed ruined in the sense that the other 3 batteries consistently outperformed it and I found it unsuitable for either position in the aircraft.
It appeared that repeated discharge and charge with only the Battery Tender permanently reduced the capacity of 1 of my new batteries. It also appeared that 4 or 5 years of aging on the shelf in a more or less fully charged state was not as bad as repeated use and undercharging with a Battery Tender/maintainer.
Further reinforcing these observations, at my first condition inspection I decided to swap in the better of my 2 newer batteries. for the first year, I had been flying with my 2 older batteries. Thought my carbon pile tester had bellied up, I found that my 2 older batteries and one of my new batteries all had the same voltage when fully charged with no load. When I swapped out my oldest battery for my best new battery it turns out it didn't perform quite as well (the engine would not always turn over on it). I went back to the 2 older batteries and everything works as intended.
I've since set aside the battery tender knowing that if I have a charged battery on the shelf, I could probably use it to maintain the full charge. But the Walmart charger is my main charging tool. Now that I'm flying regularly there is little need for charging and my Z-14 is performing exactly as desired (though I haven't had any kind of electrical component failure to test its failure tolerance). I'm quite confident behind my 100% electrical panel in IFR operations.
(I do have 2 mags which are refreshingly retro in this microprocessor world - they are electromagnetic mechanical wonders!)
Thanks again Bob,
Bill Watson
N215TG
On 9/4/2012 5:36 PM, Robert L. Nuckolls, III wrote:
[quote] I have known this for some time (since the time I gathered
at 14.5 volts.
size.
Checked by AVG - www.avg.com
Date: 09/04/12 [b]
email(at)jaredyates.com Guest
Posted: Tue Sep 04, 2012 6:00 pm Post subject: Battery Tender performance |
Bill, next time you are out at the hangar and think about it, could
you see what the manufacturer and model are of your successful Walmart
charger?
On Tue, Sep 4, 2012 at 9:20 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
| Quote: | Bob, your previous posts on this topic of using a "Battery Tender" as a
in the aircraft.
Thanks again Bob,
Bill Watson
N215TG
at 14.5 volts.
size.
Date: 09/04/12
Posted: Tue Sep 04, 2012 7:19 pm Post subject: Battery Tender performance |
Yep, will do tomorrow.
On 9/4/2012 10:00 PM, Jared Yates wrote:
charger?
> in the aircraft.
> Thanks again Bob,
> Bill Watson
> N215TG
> at 14.5 volts.
> size.
> Bob . . .
> No virus found in this message.
> Date: 09/04/12
Posted: Tue Sep 04, 2012 7:39 pm Post subject: Battery Tender performance |
At 06:30 PM 9/4/2012, you wrote:
| Quote: | Hi Bob
Will they accept a charge at all? If so, the only thing
I'm aware of that might recover them to some degree is
a couple of deep discharge/charge cycles. Concord suggests
you can put a LOT of volts on a battery that won't accept
any charge until it's recharge current rises above some
nominal value . . . I think it was a couple amps.
Then proceed with two or three deep cycles and measure
capacity on last cycle. If not 'recovered' to flight-worthy
levels, then the battery is 'trash'. That's about 80% of
new. Of course, you can settle for less.
| Quote: | It would be interesting to see the results you achieve if you use
The battery maintenance devices did too but they
turned off sooner. I don't know if I've still got
them around. I had no interest in using them.
I'll see what I can find.
Posted: Tue Sep 04, 2012 8:00 pm Post subject: Battery Tender performance |
At 06:28 PM 9/4/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
Sorry if I missed it, but could you define tender vs maintainer vs smart charger vs old style charger in terms of expected charge profiles for typical batteries used in OBAM aircraft. |
Legacy chargers did not change much in terms of
utility beginning with devices like this:
I owned one of these things about 1955. It was stronger
than a 'trickle charger' . . . about 3A as I recall
and would recharge a dead battery overnight. But it had
ZERO controls. It was a constant current charger that
would boil a battery dry if left on after the battery
achieved full charge.
Modern incarnations of this philosophy are much
more robust. Will crank an engine and certainly
charged a battery much faster. They might even include
a clock-works timer to shut the thing off after some
period of time to prevent severe overcharging. Here's
some examples of robust 'manually controlled' chargers . . .
http://tinyurl.com/cljbyur
http://tinyurl.com/cd437g2
The advent of microelectronics prompted more sophisticated
charger designs that fall into two classes. Charger/maintainers
like this series of microprocessor controlled devices.
Where operator intervention was not needed to prevent
overcharging. These generally include microprocessor controls
programmed to conduct a good approximation of the ideal
recharge protocol
http://tinyurl.com/9s7kpww
for constant current bulk charge, constant voltage
dwell for absorption cycle, followed by a drop to
some value just above open circuit voltage to
offset the battery's internal losses . . .i.e.
'maintain' it forever. These are the current
crop of smart chargers.
Then we come to "maintainers" . . . constant
current charge to some endpoint generally above
14.0 volts followed by a drop to maintenance
level of just over 13.0 volts. Products like
Battery Tender
Battery Minder are typical "wall warts" that will
charge a battery to just short of full before
they drop to the maintenance mode.
The two products I'm comparing for performance are
the Battery Tender and an SEM1562A Schumacher
charger/maintainer (as soon as it gets here).
Bottom line is that all three classes of charger
are readily available today. The manual devices
can be quite robust but will cook a battery if
used improperly. The charger/maintainers are automatic
and represent a relatively goof-proof way to charge
a battery and store it. The maintainers will also
charge albeit to less than 100% of battery's rated
capacity but they too will maintain the battery
nicely while being stored.
Bob . . . [quote][b]
Posted: Wed Sep 05, 2012 8:37 am Post subject: Battery Tender performance |
The charger from Walmart is a Shumacher:
https://dl.dropbox.com/u/60509998/DSC04046.JPG
There were several models but this one seemed to be the right one for my
Odyssey 680s
Here is a blurry shot of my Battery Tender Plus:
https://dl.dropbox.com/u/60509998/DSC04048.JPG
charger?
> in the aircraft.
> Thanks again Bob,
> Bill Watson
> N215TG
Posted: Thu Sep 06, 2012 5:47 am Post subject: Battery Tender performance |
At 11:36 AM 9/5/2012, you wrote:
This is a very capable charger . . . and probably
appropriate to a program where batteries are
deeply discharged and then recharged such as
trolling motors, mobility carts, etc. If
one has the occasional need to put a 'fast'
charge on a car or rv battery, something with
this capability will cover more 'battery bases'
and the price is right . . . about $40.
If one wishes to do a simple top off and maintenance
on a battery on a hangared airplane, then
time-to-recharge is not an issue. Then a product
like the SEM1562A
http://tinyurl.com/25q3532
might be a better choice. For the same dollars,
one can have two such devices doing the guardian
angel thing over batteries in different
locations.
Don't wrapped around the 'features axle' for
chargers with lots of lights and buttons unless
you need to maximize battery life for devices
in deep-discharge service. Protocols finely
tuned to battery technology are not all that
different from each other. Further, 99 times
out of 100, you're putting an airplane away
with a fully charged battery. Ideally, the
battery in your airplane NEVER gets a deep
discharge cycle and will last a very long
time.
Posted: Thu Sep 06, 2012 8:24 am Post subject: Battery Tender performance |
Makes a lot of sense.
In fact, I think that was the charger you were recommending at the time
I was asking. Impatiently, I went to my local Walmart and picked the
best thing I could find on the shelf that day.
On 9/6/2012 9:46 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> my Odyssey 680s
like the SEM1562A
locations.
time.
