Kolb Firestar cockpit enclosure
Dennis Thate
PostPosted: Thu Aug 23, 2012 10:49 am    Post subject: Kolb Firestar cockpit enclosure Reply with quote
I'm considering extending my Kolb Firestar's flying season by enclosing the cockpit area. I would like to see some original cockpit enclosure designs others have built. From cheap and quick to more elaborate designs.
I've seen some very creative designs locally, but would like to see a wider sampling of other Firestars across the country. Please list type of materials used also.
Fall flying is fast approaching !
 Filesize:  24.99 KB
 Viewed:  8266 Time(s)
PostPosted: Thu Aug 23, 2012 11:15 am    Post subject: Kolb Firestar cockpit enclosure Reply with quote
Travis Brown, at Kolb Aircraft, is a good source for info
and materials for building a full enclosure.
Sargents, Colorado
<retroman(at)frontier.com>
Dennis Thate
PostPosted: Thu Aug 23, 2012 2:40 pm    Post subject: Re: Kolb Firestar cockpit enclosure Reply with quote
Here is one photo of a original top notch example.
 Filesize:  718.18 KB
 Viewed:  8251 Time(s)
Thom Riddle
PostPosted: Fri Aug 24, 2012 3:27 am    Post subject: Kolb Firestar cockpit enclosure Reply with quote
The Slingshot has the same basic fuselage as the Firestar. The canopy on the slingshot hinges (piano hinge) on the left side so the whole thing tilts over completely out of the way for easy entry/exit. Attached is a photo of my Slingshot with the canopy open.
 Filesize:  226.73 KB
 Viewed:  8226 Time(s)
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Dennis Thate
PostPosted: Fri Aug 24, 2012 9:13 am    Post subject: Re: Kolb Firestar cockpit enclosure Reply with quote
Tom,
Very Nice ! is that a Kolb factory kit built or builder fabricated unit ?
Thanks for the post,
DT
Thom Riddle
PostPosted: Sat Aug 25, 2012 2:59 am    Post subject: Re: Kolb Firestar cockpit enclosure Reply with quote
I did not build this Slingshot so I can't guarantee that it is factory stock canopy, but suspect it is because all the slingshots I've seen up close (4 so far) had the same canopy arrangement.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
