speedy11(at)aol.com Guest
Posted: Tue Aug 21, 2012 8:15 pm Post subject: Adding an electrical system |
I am adding an electrical system to a PT-22 per a customer's request. It will consist of an overhauled Eclipse Y-150 starter, a RG battery, starter switch and contactor, a switched bus to power a Becker radio and transponder, a wind driven generator, and associated wiring.
Does anyone have experience with adding electrical to a PT-22?
Any gotchas?
I can't find any generator or alternator that is approved for the PT engine, that's the reason for the wind generator. It will only produce about 5 amps, so it will barely power the transponder and slowly recharge the battery and allow occasional radio transmission.
Since I'm doing a form 337 for the change, I should be able to use any battery. So, we're considering a PC-680 or a lithium ion battery such as the Aerovoltz. Otherwise, we'll us a RG-35AXC.
Comments?
Stan Sutterfield
Port Orange, FL
Posted: Wed Aug 22, 2012 4:48 am Post subject: Adding an electrical system |
Any gotchas?
What are your design goals for the installation and
how do you envision it will be used operationally?
Will this airplane be used for cross-country flight?
Is it parked in a location serviced by AC mains power?
Keep in mind that cranking an engine from the
typical battery takes only 5% or so of that
battery's capacity. Transponders take typically
2 amps to operate when generating lots of replies.
If I recall correctly, the Becker was designed
for battery only ops in gliders. It's power
demans are:
Standby" reception mode £ 70 mA
Reception mode £ 500 mA
Transmission mode £ 2.5 A
Energy demands for this instance are trivial.
Further, it has a low voltage warning built
in set to trigger at 10.5 volts.
http://tinyurl.com/9upvqxg
An RG-35 is a beast of a battery . . . 30+
pounds as I recall. B&C did some cranking tests
on the SMALLER cousin to the PC-680 and found
that it would do a 10-blade crank of a high
compression engine (aerobatic aircraft), 5
times in a row (with about a minute cool down
between events). The PC-680 should do better
yet.
How about NO generator, a PC-680 as the only
battery and a Battery Minder plugged in while
the airplane is parked? Li-FePOH batteries
are low risk because you're not going to charge
it at a high rate while airborne . . . and it
can be recharged at a benign rate while hangared.
But take care also that you do not heavily discharge
it between flights as they're more sensitive to
deep cycle damage than their SVLA cousins.
Bob . . . [quote][b]
Speedy11(at)aol.com Guest
Posted: Thu Aug 23, 2012 6:50 am Post subject: Adding an electrical system |
Bob,
Your points are all well taken.
But, the customer wants a complete electrical system installed including some type of charging system. I suggested to him that the demand on the battery will be nominal for the short 1 hours flights he plans in the airplane. There will be no long distance flights. I suggested a battery only electrical system and charging the battery between flights. But, he insists on a system with charging capability. So, the only option is to install an external wind generator for recharging.
Do I need a voltage regulator for this setup?
As mentioned, the airplane will be flown only occasionally and only locally. It will be in a flying museum in Chile. We will install a charging point for the battery so it can be maintained to full charge between flights.
I am considering the RG-35 battery only because it was used in a previous 337-approved PT-22 installation so reapproval will be much easier by using the same battery.
From my experience, a single PC-680 battery will just barely turn over my IO-390. I have two in the plane and have to connect both to get good rotation of the engine.
The PT-22 has a radial (not sure yet which one) and I'm not sure that the PC-680 will have enough juice to spin it well.
Since we are installing a starter on the engine, we can afford some weight in the aft fuselage (behind seat) for the battery weight.
I'm planning to use #2 wire from the battery forward.
The power demands from the Becker radio and transponder are minimal. Your numbers are for the VHF radio.
Standby" reception mode 70 mA
Reception mode 500 mA
Transmission mode 2.5 A
The transponder requires only
Standby - 0.3A
Transmit - 1.1A
So, the inflight demand on the battery will be zero when the wind generator is producing 5A.
I agree that the RG-35AXC is a monster. It is very heavy which translates into extra weight for the stronger battery mount required. What do you think of using an Aerovoltz lithium battery? It has about 550CCA and shelf life is excellent (10% loss over one year). Otherwise, I will lean toward the PC-680 - or maybe a pair of them.
The main concern overall for this installation is that the cranking power must be sufficient to start the engine. All other demands on the system are achievable.
More thoughts?
Stan Sutterfield
In a message dated 8/23/2012 3:01:37 A.M. Eastern Daylight Time, aeroelectric-list(at)matronics.com writes:
| Quote: | I am adding an electrical system to a PT-22 per a
Any gotchas?
demans are:
Standby" reception mode =A3 70 mA
Reception mode =A3 500 mA
Transmission mode =A3 2.5 A
yet.
Posted: Thu Aug 23, 2012 7:12 am Post subject: Adding an electrical system |
Sounds like you have a plan. 5A applied to
an RG35 probably doesn't represent much of
an OV risk. But it would be easy to add
crowbar protection right on the b-lead
breaker.
