ttweedy
Posted: Mon Aug 20, 2012 11:46 am Post subject: Is Rotax 80 hp enough? |
Hi,
I'm looking at a used 701 with a Rotax UL 80hp.I welcome opinions on whether or not this engine is adequate for the STOL performance for which the 701 is designed.The plane is a 1100# MTOW model.
dougsnash
Posted: Mon Aug 20, 2012 12:11 pm Post subject: Is Rotax 80 hp enough? |
I have the 80 hp 912/ 3 blade warp on my 701 and it is adaquate on wheels. I'm surrounded by water and plan on building a set of amphibs in a year or two and will have to upgrade the powerplant before I try flying two-up with floats. Lets face it, there is no such thing as enough power on a float plane.
What would I gain with the 100hp? Probably a couple of MPH in cruise and might get off the ground a little faster when heavy. I would not rule out a 701 just because it only had the 80hp. The 80hp is actually a better engine than the 100hp, not as hard on the airframe. Yes, it has less power but is thus a bit smoother.
I guess it really depends on what you are trying to do with the plane. I think you'll find both engines give pretty good STOL performance on the 701.
Doug M
CH-701 from scratch
NW Ontario, Canada
Sent: Monday, August 20, 2012 2:46:21 PM
Subject: Is Rotax 80 hp enough?
--> Zenith701801-List message posted by: "ttweedy" <ttweedy1954(at)gmail.com (ttweedy1954(at)gmail.com)>
Hi,
http://forums.matronics.com/viewtopic.php?p=381391#381391
http://forums.matronics.com</ -Mats.com/contribution" =======
ronlee
Posted: Mon Aug 20, 2012 12:33 pm Post subject: Re: Is Rotax 80 hp enough? |
One consideration is the mandatory use of 91+ octane fuel in the 100 hp if using auto gas and Rotax wants it fresh and in season. Not many cars today really need premium fuel so it can be a bit hard to get it fresh in a small town. I live near a couple of retirement communities where there are a lot of high end cars that use premium, so it's not a problem for me. Where my plane is hangared, which is a small town someone bought premium for their Rotax powered gyro and when they started dumping it in the plane it stunk and was like lumpy. With the 80 HP you can use regular.
_________________ Ron Lee
Tucson, Arizona |
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Mon Aug 20, 2012 1:13 pm Post subject: Is Rotax 80 hp enough? |
Personally, I think the 100 hp Rotax is almost too much for the 701. That is, if you can have too much horsepower.
On Mon, Aug 20, 2012 at 2:46 PM, ttweedy <ttweedy1954(at)gmail.com (ttweedy1954(at)gmail.com)> wrote:
[quote]--> Zenith701801-List message posted by: "ttweedy" <ttweedy1954(at)gmail.com (ttweedy1954(at)gmail.com)>
Hi,
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
le, List Admin.
_________________ Tommy Walker
N25A - Anniston, AL |
sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Mon Aug 20, 2012 1:50 pm Post subject: Re: Is Rotax 80 hp enough? |
I have had the 80 hp for 5 years, and have never wanted or needed anything larger. Uses regular gas, and it really is a short takeoff plane.
This video on YouTube which has gotten 10,000 hits shows a no-wind 80 hp takeoff at 1000 foot elevation. I did not rotate until 50 mph. Could have rotated much sooner (35).
http://www.youtube.com/watch?v=BQ3XEDrGJQs&list=UUa96-6jPxciXbixBk9eTjew&index=9&feature=plcp
Fred
Posted: Mon Aug 20, 2012 2:13 pm Post subject: Is Rotax 80 hp enough? |
Also depends on what altitudes you intend to fly at. My home airport is at about 6ooo ft and is surrounded by 10 to 11 thousand foot peaks.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Tommy Walker
Sent: Monday, August 20, 2012 2:13 PM
Subject: Re: Is Rotax 80 hp enough?
Hi,
le, List Admin.
| Quote: | | http://www.matronics.com/Navigator?Zenith701801-List | 01234567
ggower_99(at)yahoo.com Guest
Posted: Mon Aug 20, 2012 4:10 pm Post subject: Is Rotax 80 hp enough? |
I fly similar altitudes like Craig does... And sincerely, In some very few particular occasions, I will love to have a 914, and also a foot more span in each wing will also help...
But I think there are too much gadgets to go wrong in the 914...
I rather fly, planning out in advance with the 100 hp.
About 400 hrs with no problems, only the normal mantainance and fun...
Gary.
Sent: Monday, August 20, 2012 5:12 PM
Subject: RE: Is Rotax 80 hp enough?
-- Craig
Hi,
le, List Admin.
8
Posted: Mon Aug 20, 2012 4:14 pm Post subject: Is Rotax 80 hp enough? |
The big diference is in climb, and in high landing strips, highr cruise speed is not a goal, is Not a racing airplane...
Gary.
To: "zenith701801-list(at)matronics.com" <zenith701801-list(at)matronics.com>
Sent: Monday, August 20, 2012 3:11 PM
Doug M
CH-701 from scratch
NW Ontario, Canada
Hi,
[quote]f="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matro="nofollow" target="_blank" href="http://forums.matronics.com/">http:/www.matronics.com/contribution">http://www.matronics.com/contribution============
n801bh(at)netzero.com Guest
Posted: Mon Aug 20, 2012 4:52 pm Post subject: Is Rotax 80 hp enough? |
You can have TOO much horsepower... Don't ask how I know..<GG>
Ben Haas
N801BH
www.haaspowerair.com
Tommy Walker
Posted: Mon Aug 20, 2012 5:05 pm Post subject: Is Rotax 80 hp enough? |
Ben, are you still flying that ford powered chariot? That was the ultimate 801...
Beautiful plane too, if a 701/801 can be considered good looking.... Sort of like a camel.....
Tommy
Sent from my iPad
On Aug 21, 2012, at 12:50 AM, "n801bh(at)netzero.com (n801bh(at)netzero.com)" <n801bh(at)netzero.com (n801bh(at)netzero.com)> wrote:
You can have TOO much horsepower.. Don't ask how I know..<GG>
Ben Haas
N801BH
Posted: Mon Aug 20, 2012 5:19 pm Post subject: Is Rotax 80 hp enough? |
Yup......
Coming up on 500 hours and it still has not killed me............. yet..(:>)
do not archive.
Ps.. I LOVE my toy......
Ben Haas
N801BH
dougsnash
Posted: Mon Aug 20, 2012 5:41 pm Post subject: Is Rotax 80 hp enough? |
Yes Ben but that's just cause you're crazy... but in a good kind of way.
Gotta love that Ford power.
Doug M
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Sent: Monday, August 20, 2012 7:50:02 PM
Ben Haas
N801BH
