tc1917(at)bellsouth.net Guest
Posted: Sun Aug 19, 2012 12:52 am Post subject: Kolb-List Digest: tail wheel |
I installed a matco tailwheel on my slingshot. Had a lot of trouble ground looping cause the wheel would 'break' too easily. In the archives it describes how to fix this and make it custom to your desires. It just requires you to grind the channel longer where the ball bearing rides. Works great. The slingshot with big wheels has a high stance with short coupling. Makes for a wild ride if the wheel breaks and you start sliding. Just my opinion. Ted Cowan slingshot 912ul zoomzoom
On Aug 19, 2012, at 2:01 AM, Kolb-List Digest Server <kolb-list(at)matronics.com> wrote:
[quote] *
Today's complete Kolb-List Digest can also be found in either of the
of the Kolb-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 12-08-18&Archive=Kolb
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 12-08-18&Archive=Kolb
Kolb-List Digest Archive
Total Messages Posted Sat 08/18/12: 7
Today's Message Index:
1. 02:01 AM - Re: Kolb-List Digest: 11 Msgs - 08/17/12 (George Bearden)
2. 02:03 AM - Re: Kolb-List Digest: 11 Msgs - 08/17/12 (George Bearden)
3. 10:39 AM - Re: A swivel tailwheel question (Dennis Thate)
4. 04:59 PM - Re: Re: A swivel tailwheel question (Gary Aman)
5. 05:16 PM - Re: Re: A swivel tailwheel question (David Peters)
6. 06:38 PM - Re: Tail Post supports (Ellery Batchelder Jr)
7. 07:18 PM - Re: Re: New Firestar II owner - question about elevator oscillations (Richard Girard)
________________________________ Message 1 _____________________________________
Time: 02:01:46 AM PST US
Subject: RE: Kolb-List Digest: 11 Msgs - 08/17/12
> The 50 ohm dummy load is not going to do you any good with your antenna.
Of course not. I used it to take the antenna away as a variable. A
dummy-load can be useful to your antenna *SYSTEM* though.
> It is only designed to help you with your transmitter.
My screwdriver is designed to turn screws but I use it for all kinds of
things. What I suggested isn't good for this situation, as I noted, since
the asker isn't a radio person (neither am I) but since other folks read
these posts I mentioned how it COULD be used.
I thought the rest of your post was wonderful, however.
GeoB
________________________________ Message 2 _____________________________________
Time: 02:03:38 AM PST US
> an antenna analyzer is an other good tool.....
Yes! IMHO the analyzer is a much better tool for this.
GeoB
________________________________ Message 3 _____________________________________
Time: 10:39:59 AM PST US
Subject: Re: A swivel tailwheel question
Thanks for the helpful suggestions. I went with a Matco. The Kolb handles so much
better....more like a real taildragger.
on my narrow strip.
" I would recommend installing the tail post brackets on all Kolbs I just
Ellery Batchelder Jr. "
Can you show a picture of this tail post brackets ?
Both optimists and pessimists contribute to our society. The optimist invents
the airplane and the pessimist the parachute. ~Gil Stern
http://forums.matronics.com/viewtopic.php?p=381160#381160
http://forums.matronics.com//files/matco_tailwheel_143.jpg
________________________________ Message 4 _____________________________________
Time: 04:59:36 PM PST US
Subject: Re: Re: A swivel tailwheel question
Posted: Sun Aug 19, 2012 7:07 am Post subject: Kolb-List Digest: tail wheel |
easily. Ted C
Ted C/Kolbers:
Do you have differential braking?
I'd have a difficult time flying my mkIII without
differential brakes.
Sargents, Colorado
_________________ John Hauck
Titus, Alabama |
Dennis Thate
Posted: Sun Aug 19, 2012 7:55 am Post subject: Re: Kolb-List Digest: tail wheel |
John,
The only time I use my brakes in flight is just after lift-off. My wheels are spinning so fast that they set up a strong vibration which shakes the whole plane.
My tires are worn down considerable, hopefully this annoyance will cease when I get new better balanced tires on my Kolb.
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern |
Posted: Sun Aug 19, 2012 8:11 am Post subject: Kolb-List Digest: tail wheel |
<retroman(at)frontier.com>
lift-off. My wheel are spinning so fast that they set up a
Kolbers:
Golf cart, lawn mower, and other off road/slow speed tires
are not trued and balanced prior to leaving the factory.
Aircraft quality tires are trued and balanced prior to
delivery. Even then, aircraft tires and wheels will require
balancing after mounting.
Sargents, Colorado
Titus, Alabama |
Posted: Mon Aug 20, 2012 5:05 am Post subject: Kolb-List Digest: tail wheel |
At 09:04 AM 8/19/12 -0600, you wrote:
John,
Why do you need differential brakes for flying?
Jack B. Hart FF004
Winchester, IN
zeprep251(at)aol.com Guest
Posted: Mon Aug 20, 2012 5:12 am Post subject: Kolb-List Digest: tail wheel |
We call dem air brakes
Thom Riddle
Posted: Mon Aug 20, 2012 6:01 am Post subject: Re: Kolb-List Digest: tail wheel |
With a full swivel tailwheel and differential brakes, ground handling in tight places is very easy and I'm glad I have them on my Slingshot. Balancing wheels/tires is pretty simple with the go-kart wheel balancer.
160.78 KB |
11551 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Mon Aug 20, 2012 7:50 am Post subject: Kolb-List Digest: tail wheel |
Jack B. Hart FF004
Jack H/Kolbers:
I start logging flight time when I start the engine. Taxi,
takeoff, and landing, are part of the "big picture" of
flying. Sorry if you did not understand.
What did you think I meant?
Gary A: There are times when I wished I had had "dem air
brakes".
Sargents, Colorado
Titus, Alabama |
Posted: Tue Aug 21, 2012 5:34 pm Post subject: Kolb-List Digest: tail wheel |
At 09:47 AM 8/20/12 -0600, you wrote:
Jack B. Hart FF004
Jack H/Kolbers:
John,
I did understand. Again, why do you need differential brakes?
I hangar and fly from airports, and many of my testing actual flight times
are less than the accumulated time required to taxi in and out. Also, when
leaving from a flyin, the queue may be as much as a half hour long. I only
record actual flight time with a stick mounted timer to prevent inflating
actual flight time. Also, this gives me more reliable data from which I can
calculate a more accurate fuel consumption rate.
Jack B. Hart FF004
Winchester, IN
lcottrell
Posted: Tue Aug 21, 2012 6:00 pm Post subject: Kolb-List Digest: tail wheel |
I am not John, but let me tell you why I need differential brakes. Mine are not as fancy as John's, ( mine are the mechanical drums, with a homemade dual bicycle brake levers) but without them I am out in the weeds every time I want to turn around. I also use them when I am turning corners such as when I make a 90 degree turn to park inside the hanger. I suppose that I could do without them if I was operating on a nice pave runway that is wide enough for spam cans, but I don't. In other words they make my life a lot easier, and mean that I don't have to get out to turn the plane around.
Perhaps there are those who are skilled enough to manage without them, but alas, I am just a "brush" pilot. Plus I really don't give a shit how much they weigh.
Larry
On Tue, Aug 21, 2012 at 7:42 PM, Jack B. Hart <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)> wrote:
| Quote: | --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
>--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
>Jack B. Hart FF004
>Jack H/Kolbers:
John,
Jack B. Hart FF004
Winchester, IN
le, List Admin.
Posted: Tue Aug 21, 2012 6:12 pm Post subject: Kolb-List Digest: tail wheel |
brakes?
actual flight times are less than the accumulated time
required to taxi in and out. Also, when leaving from a
prevent inflating actual flight time. Also, this gives me
more reliable data from which I can calculate a more
Jack B. Hart FF004
Jack H/Kolbers:
I need the differential brakes to help me control the
aircraft on the ground.
Jack, you can legally log flight time from the time you turn
the prop until the time the prop stops after you land.
Start up and shut down are part of that flight.
If you want to log "actual in flight time", that is fine
with me.
In the event of an engine failure, do you punch the clock
off?
Sargents, Colorado
Titus, Alabama |
Thom Riddle
Posted: Wed Aug 22, 2012 3:56 am Post subject: Time in service vs flight time or engine running time. |
For what is worth, "time in service" records (for maintenance) should reflect airborne time. This is why some time recording meters/instruments begin recording based on airspeed and/or micro switches that activate when wheels are off the ground. Of course for experimental and UL aircraft this only matters if you care about the difference.
Buffalo, NY (9G0)
- Anonymous |
Posted: Wed Aug 22, 2012 5:04 pm Post subject: Kolb-List Digest: tail wheel |
Date: Tue, 21 Aug 2012 19:57:40 -0600
Larry,
I am not as fortunate as those of you who have your own grass strip with a
hangar. Thus I am forced to use an airport. The first one was 39 miles
away. Luckily the present one is only two miles away. When we bought the
present property it included a long narrow strip that could be used as an
800 foot runway, but it is going to take some earth moving to get it flat
and smooth enough to use with the FireFly.
I mounted drum brakes activated by a single handle because I found that
operating at an airport with out brakes was pure hell. The only way I could
stop and avoid running into the plane ahead of me was to taxi off the
asphalt into the grass or shut the engine down or jump out and hold it.
When the queue moved forward, I would have to taxi in the grass, or climb in
with out it running me down, strap in and move forward.
If you want to fly, you have to do what you have to do.
Jack B. Hart FF004
Winchester, IN
Posted: Wed Aug 22, 2012 5:07 pm Post subject: Kolb-List Digest: tail wheel |
At 08:09 PM 8/21/12 -0600, you wrote:
| Quote: | In the event of an engine failure, do you punch the clock
off?
John,
Yes, but not until the wheels touch the ground.
Jack B. Hart FF004
Winchester, IN
Posted: Wed Aug 22, 2012 5:16 pm Post subject: Kolb-List Digest: tail wheel |
off?
John,
Jack B. Hart FF004
Winchester, IN
Gee, what does that do to your fuel consumption
calculations?
Sargents, Colorado
Titus, Alabama |
