Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Feb 10, 2011 4:56 pm Post subject: Static Port |
For those of you who installed the dynon pitot/AOA tube - where did you install the static port? Did you go with one or two?
Cessnas usually install the ports on the side of the fuselage, just behind the cowling. That makes for a short run to the instrument panel. In other aircraft I have also seen them installed on the tailcone.
Recommendations?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
don.honabach(at)pcperfect Guest
Posted: Thu Feb 10, 2011 5:25 pm Post subject: Static Port |
I tried the pilot side of the fuselage - had bad readings, tried the passenger side, had better but still bad. Tried to tee them together - had better still yet but still a bit off. Opened up to the cockpit and have just about perfect - go figure!!!
Don
mhubel
Posted: Thu Feb 10, 2011 5:40 pm Post subject: Static Port |
Tim,
I used the Grumman approach and used two ports midway back on the
fuselage. The result seems to be very well behaved in a slip.
On 02/10/2011 7:56 PM, Tim Juhl wrote:
Recommendations?
______________
CFII
Champ L16A flying
Tearing wings apart for modification
http://forums.matronics.com/viewtopic.php?p=330531#330531
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
jeffrey_davidson(at)earth Guest
Posted: Fri Feb 11, 2011 12:44 am Post subject: Static Port |
I used the Cessna 172M position initially. I got lots of airspeed errors. These were corrected by moving the static ports to a location on the fuselage forward of the horizontal tail. I used ports on both sides to account for slips. The results are good.
Jeff D.
601-HD
dgardea(at)gmail.com
Joined: 26 Mar 2007 Posts: 50 Location: Indianapolis, IN
Posted: Fri Feb 11, 2011 6:53 am Post subject: Re: Static Port |
Tim, I installed two static ports on either side of the fuselage just below the aft portion of the canopy about in line with the 601XL step. From there it was easy to route both lines to the Dynon ADAHRS and forward up the center console. I have not flown yet so don't know what results this will yield.
_________________ Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html |
chuck960
Posted: Fri Aug 17, 2012 7:57 am Post subject: Re: Static Port |
I started with the static ports half way between the flap and stabilizer on both sides of the fuse. I compared airspeed with the GPS and I am slow by 12 mph. I disconnected the static line from the back of the Dynon and I am fast by 12 mph. I was thinking of trying the fuse sides in front of the instrument panel.
Someone must have a good location.
Chuck
psm(at)att.net Guest
Posted: Fri Aug 17, 2012 8:17 am Post subject: Static Port |
Hi Chuck,
I don't know which model 601 you have and it probably matters a lot.
On the XL the static port on the drawings is about half way out on the
bottom of the wing. It is on a tube that runs parallel to the pitot
tube. This works well. I haven't done a formal calibration but the GPS
speed and Dynon airspeed always seem quite close.
The fuselage on the XL doesn't have any points where its side runs
parallel to the line of flight. This means there is no "Neutral"
position for static ports. It also means there is no yaw stability
until the rear end gets more than 11 degrees from straight ahead (the
rear fuselage forms a 22 degree angle at the aft end).
Good luck,
Paul
XL about done with phase I flight test.
On 8/17/2012 8:57 AM, chuck960 wrote:
Chuck
http://forums.matronics.com/viewtopic.php?p=381080#381080
Ron Lendon
