Posted: Thu Aug 16, 2012 5:27 am Post subject: Mooney Alternator woes |
My hangar neighbor is trying to figure out why his alternator occasionally drops off line - requiring a weird reset sequence. He has to shut off the battery and field, then go to a low power setting and bring it back up again. Something about resetting an overvoltage protection device.
It is an M20S with Cont 550 and gear driven alternator. The first regulator lasted only a couple of years before giving up the ghost and the replacement was a special from Mooney.
My first line of thinking is to locate the regulator and test it. Nobody knows where it is hiding.
(I'm in DC - the plane is in DE...I'll be home next weekend to help more.)
Meanwhile, does anyone have an electronic copy of the Light Plane Maintenance article on troubleshooting alternators...and the Mooney M20S maintenance manual?
If we can find it, I'm hoping that we can determine if the regulator is the culprit.
Thanks in advance,
Ralph
RV6A N822AR in N06 - waiting for my engine/prop to come back from overhaul after being hit by a flying hangar door!
Posted: Thu Aug 16, 2012 5:45 am Post subject: Mooney Alternator woes |
At 08:27 AM 8/16/2012, you wrote:
<recapen(at)earthlink.net>
protection device.
is the culprit.
If it takes a southern Slobovian switch-dance to
bring it back on line, it's almost certain to be
something electronic. Is the successful reset sequence
something different than what is called for in the
POH as a response to an OV trip?
I've not had any contact with Mooney in 25+ years. I
bid an alternator controller for them while at
Electro-Mech . . . we didn't get the job. I think
Electrodelta out of White Oak, TX got it. It would
have been a Mooney-unique product. ED has changed
hands and/or moved several times over the years.
The guy who ran ED is still hanging around the
Wichita area. He MIGHT be a resource for help
wrestling with your problem.
The LPM article is not likely to be much help. It
will be VERY generic. If it were my airplane, I'd
jeep another regulator in place of the original to
see if the problem goes away. Given the rarity of
that regulator, I'd probably go for a one-time
STC to install something more contemporary and
available. There's nothing magic about alternator
controllers . . . only the institutionalized and
market driven B.S. in which they reside.
B&C regulators are used elsewhere on current production
airplanes . . . the FAA might look kindly upon
substitution of B&C product for what's already
installed.
Kellym
Posted: Thu Aug 16, 2012 5:55 am Post subject: Mooney Alternator woes |
There are a couple Mooney email lists that have experts that likely can
help, including factory tech support. The S model isn't all that old, so
there should be good info available.
Mapalist mailing list..which requires membership in MAPA.
Mapalist(at)lists.mooneypilots.com <mailto:Mapalist(at)lists.mooneypilots.com>
http://lists.mooneypilots.com/listinfo.cgi/mapalist-mooneypilots.com
<http://lists.mooneypilots.com/listinfo.cgi/mapalist-mooneypilots.com>
Mooney Tech list which is open to all:
http://lists.aviating.com/mailman/listinfo/mooney-tech,
mailto:mooney-tech-request(at)aviating.com?subject=subscribe
On 8/16/2012 6:44 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
protection device.
more.)
is the culprit.
installed.
Checked by AVG - www.avg.com
KCHD |
Posted: Thu Aug 16, 2012 6:04 am Post subject: Mooney Alternator woes |
Thanks - first step is find the installed regulator. I could probably sub-in the B&C one from my 6A on a temp basis to see if it works - that'll be a good starting place...good idea.
I'll ask about the reset sequence to see if it is in the POH.
Thanks - we'll sign up for them as a resource.
Posted: Fri Aug 17, 2012 7:47 am Post subject: Mooney Alternator woes |
Will my B&C LR3C-14 regulator properly control the Continental's alternator? I can easily set this up for a ground-run test....
Are there different regulators based on current output capability?
Thanks again!
Posted: Fri Aug 17, 2012 8:41 am Post subject: Mooney Alternator woes |
At 10:45 AM 8/17/2012, you wrote:
Yes
| Quote: | Are there different regulators based on current output capability?
Generally no. The smallest of 35A alternators draws
about 3A max . . . so does a 100A machine. There's
an advantage for keeping field currents low (control
of internally dissipated heat). Larger machines just
get more magnetic flux by more turns of larger wire
and keeping the field current manageable.
Further, unlike generators, the closed loop dynamics
of alternators fall into a much smaller universe of
characteristics such that regulators can be quite
generic. The B&C linear regulator was optimized for
the B&C alternators and may not be as nimble footed
for transient response on a 'foreign' alternator but
not bad enough to raise risk for the success of the
experiment.
glastar(at)gmx.net Guest
Posted: Fri Aug 17, 2012 2:59 pm Post subject: Mooney Alternator woes |
| Quote: | > Will my B&C LR3C-14 regulator properly control the Continental's
Yes
Just wonder, Ralph you've told, that your B&C is from a RV-6? That would
probably be a 14V system where the Mooney has a 28V System, just
carefully check.
Cheers Werner
Posted: Sat Aug 18, 2012 5:45 am Post subject: Mooney Alternator woes |
At 05:58 PM 8/17/2012, you wrote:
> Yes
would probably be a 14V system where the Mooney has a 28V System,
just carefully check.
Excellent catch Werner! I didn't perceived he was talking
about an LR3C-14, of course he would need the -28. Thanks!
Posted: Sun Aug 26, 2012 6:28 am Post subject: Mooney Alternator woes |
Thanks - I joined both lists and have posted my question there.
