p-a.austin(at)xnet.co.nz Guest
Posted: Sun Aug 12, 2012 2:01 am Post subject: Jacking block |
| Quote: | I feel a need for a small, light, jacking block to use with most any jack
that
would be part of my tool kit in the aircraft.
Kevin
Kevin,
I made one out of Aluminium flat plate and angle welded together, the flat
plate has 4 holes that fit tight over the heads of the 4 bolts on the front
face of the swing arm, the angle is welded to the flat plate so one face is
parallel to the ground to which is welded a small stud to centre and stop
the jack from slipping off. This arrangement will accommodate any scissor
jack that all cars now carry. The only thing you need to source locally if
away from your home field is the jack and blocks of wood to sit the jack on
and the outriggers.
Peter
ZK-ZEB
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sun Aug 12, 2012 6:09 am Post subject: Re: Jacking block |
Sounds very similar to mine, except that mine is made from steel. You had more confidence than me, in that you made the four holes large enough to fit snugly around the four bolt-heads. Mine has the lower two holes sized for the bolt shanks, so I first have to remove the two bolts in order to clamp the piece to the swinging arm.
Therefore I must find tools for the nuts and bolts, as well as pieces of wood and a jack if I'm away from base.
Must be something about the Southern Hemisphere, causing NZ and SA builders to come up with very similar simple ideas.
klinefelter.kevin(at)gmai Guest
Posted: Sun Aug 12, 2012 12:10 pm Post subject: Jacking block |
Peter,
Thanks for that. I was playing with some alu angle too. The flat plate with holes to fit the bolt heads sounds good.
Kevin
On Aug 12, 2012, at 3:00 AM, "p-a.austin" <p-a.austin(at)xnet.co.nz> wrote:
> I feel a need for a small, light, jacking block to use with most any jack that
> Kevin
Kevin,
I made one out of Aluminium flat plate and angle welded together, the flat plate has 4 holes that fit tight over the heads of the 4 bolts on the front face of the swing arm, the angle is welded to the flat plate so one face is parallel to the ground to which is welded a small stud to centre and stop the jack from slipping off. This arrangement will accommodate any scissor jack that all cars now carry. The only thing you need to source locally if away from your home field is the jack and blocks of wood to sit the jack on and the outriggers.
Peter
ZK-ZEB
deford.dave(at)gmail.com Guest
Posted: Sun Aug 12, 2012 12:41 pm Post subject: Jacking block |
This jacking block is clear at the other end of the spectrum from some of
the engineering marvels that have appeared on this thread, requiring just a
couple of pieces of scrap wood, a bit of hardware, and half an hour of work.
It has traveled around in N135TD for 11 years and 800 hours without ever
being used away from home, but it is worth the pound of extra weight in
reduced worry over having a flat at another airport. The idea is not
original with us, having been passed around the Europa group many years ago.
Dave DeFord
N135TD
53.76 KB |
5486 Time(s) |
46.6 KB |
5486 Time(s) |
48.93 KB |
5486 Time(s) |
