arplnplt(at)gmail.com Guest
Posted: Mon Aug 06, 2012 6:52 am Post subject: Brake seals |
I noticed on McMaster Carr while looking up the Viton brakes seals, they also offer a silicone seal with a wider temp range, and similar hardness. Any reason to not use silicone seals in the brakes?
Dave Leikam
Kellym
Posted: Mon Aug 06, 2012 7:06 am Post subject: Brake seals |
Unless they give you a durometer spec equal to the Viton, most silicone
is softer and less desirable in this application. I use flourosilicone
o-rings for fuel caps, but there is no sliding piston like a brake caliper.
On 8/6/2012 7:51 AM, David Leikam wrote:
| Quote: | I noticed on McMaster Carr while looking up the Viton brakes seals,
hardness. Any reason to */not/* use silicone seals in the brakes?
Dave Leikam
KCHD |
speckter(at)comcast.net Guest
Posted: Mon Aug 06, 2012 11:44 am Post subject: Brake seals |
You would be the beta tester. Let us know how they work.
Gary Specketer
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Sent: Monday, August 6, 2012 9:51:34 AM
Subject: Brake seals
Dave Leikam
