rv8ch
Posted: Sat Aug 04, 2012 12:28 pm Post subject: Starter contactor leaking voltage |
Thanks Bob, Gents, for the feedback on this. I have done it the way the plans show, and you suggested, and put the starter contactor on the FW.
New question (yes, I'm building very slowly) - I have the Van's starter contactor (Part Number = ES 24021) and when I apply 12v to the battery connection, I get about 0.4v on the starter connection. This is before it is energized. When I apply the 12v to the 'S' terminal, I get the full 12v on the starter terminal.
Is it normal for some voltage to "leak" even when the device is "idle"? My battery contactors don't do this, and I don't have another starter contactor to test with.
Mickey
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Sun Aug 05, 2012 4:18 am Post subject: Re: Starter contactor leaking voltage |
Theoretically there should be NO leakage through the starter contactor. But the insulation used in the contactor is not perfect. There could be some insignificant leakage. Digital voltmeters have a very high input impedance which allows them to measure insignificant voltage. Try shorting the output terminal to ground with your fingers of one hand while measuring the voltage. Or use an old analog voltmeter which will give more meaningful measurements in this situation. Or use a very small 12v test lamp, the type used for automotive instrument illumination.
I do not think there is enough leakage to worry about.
Joe
_________________ Joe Gores |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sun Aug 05, 2012 6:48 am Post subject: Re: Starter contactor leaking voltage |
repost
As others have mentioned, the problem is in how you use your tools...like the voltmeter.
Imagine that you have a voltmeter that is infinitely sensitive (infinite impedance). Now it will measure the battery voltage even thru an open switch. In fact, it will measure 500 volts between your belt buckle and your shoe laces. And the top of your hat will be 1000 volts higher than the soles of your New Balance sneakers. You can actually extract some tiny amount of power this way.
So meter impedance is not a lack of quality in a meter, it is a necessary and useful characteristic of the measuring device. And in a solid state circuit (like a diode), there will almost always be a voltage on the output that is similar to the input voltage even when the meter is off. And in fact the "leakage voltage" will not be able to light even the tiniest LED...so ignore it.
I once designed a Cmos circuit where somebody (okay, me...) forgot to add the power trace to the IC. Years later, an inquisitive technician, tracing an unrelated fault discovered it, but all the shipped product had worked just fine.
So just don't make voltage measurements like this.
See attached for a better way.
 Download |
| Filename: |
Diode test.pdf |
79.23 KB |
| Downloaded: |
585 Time(s) |
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Sun Aug 05, 2012 6:52 am Post subject: Starter contactor leaking voltage |
New question (yes, I'm building very slowly) - I have the Van's starter contactor (Part Number = ES 24021) and when I apply 12v to the battery connection, I get about 0.4v on the starter connection. Â This is before it is energized. Â When I apply the 12v to the 'S' terminal, I get the full 12v on the starter terminal.
Is it normal for some voltage to "leak" even when the device is "idle"? Â My battery contactors don't do this, and I don't have another starter contactor to test with.
Mickey
At 07:18 AM 8/5/2012, you wrote:
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com>
Joe
My thoughts exactly. This thread illustrates
a measurement conundrum that has existed since
day one in the study and diagnosis of electron
flow. The ideal measurement technique should be
transparent to quantities being explored. The
earliest precision voltmeters (ammeters with resistors
in series) were excellent demonstrations of the
best-we-knew-how-to-do at the time.
[img]cid:.0[/img]
Note the label at the bottom of the scale=plate that
says "1000 ohms per volt". This is another way of saying
that this instrument has a basic sensitivity of 1 milliampere
full scale and when making a reading on the 150 volt
scale, the instrument presents a "load" to the circuit
being measured of 1000 x 150 or 150,000 ohms. It will
"draw" 1 milliampere of current from the measurement node
at 150 volts.
These instruments were a grade trade off between
sensitivity, accuracy, linearity and calibration drift
due to temperature and age. But an instrument like
this is fitted with a 'mirrored scale'. The observer
lines up the pointer with the reflection of the pointer
so as to drive parallax error to zero. This instrument
could be both read and relied upon for readings with
certainty of 1% or better.
If you had measured the "output" from your open starter
contactor with such a device, no doubt the reading would
be zero . . . and commensurate with your expectations.
The day I got hired into Boeing (at $86/week) I
went down to Interstate Electronics and bought
a Triplett 630 multimeter. It was a 20,000 ohm/volt
instrument (50 microamp movement) and exemplary
technology for run-of-the-mill bench test
instruments. It replaced a 1000 ohm/volt meter
that somebody had given me some 5 years earlier.
I still have the 630. It was 20 times more sensitive
than the earlier instrument and offered accuracies
on the order of 2%.
But no doubt the Triplett would also say that
your contactor was working as expected.
Such devices were useless for many investigations into
the function of vacuum tubes. The source impedance of
many voltages of interest were so high that probing
the node with this voltmeter would also show zero
volts . . . and the circuit under test would cease
to function at all.
Probing through sensitive circuitry added new
requirements for sensitivity and isolation. This
was achieved with some form of amplification. A
exemplar instrument is shown here:
[img]cid:.1[/img]
This Heathkit product has an input circuit that
looks like this:
[img]cid:.2[/img]
Notice the voltage divider of resistors that total up to
more than 9 megohms. Notice too a 1 meg resistor built
into the probe. The input impedance for this instrument
is over 10 megohms. Further, probing a node with a
combination of DC volts of interest that also carries
some signal (perhaps even high frequency RF) is only
very slightly affected by the probe. This instrument
is several hundred times more sensitive than the
device at the top of the page.
This kind of instrument may also have produced an
anomalous reading in the de-energized condition.
Modern digital voltmeters have input impedances on
the order of 20 megohms. Further, they do not provide
any isolation for probe-effects when measuring 'busy
circuits'. I have crafted a x10 probe for my Fluke
multimeter from an low capacity, oscilloscope probe
to conduct the kinds of measurements I used to do
with my Heathkit VTVM. Also, I have some load resistors
I can stack onto the voltmeter's test lead jacks that
deliberately degrade instrument sensitivity so that
readings are not influenced by small leakages.
The point of this soliloquy is to remind us
that not all observations provide good data
. . . but all data can be filtered through a
healthy level of skepticism supported by an
understanding of the circuit under test along
with the measuring device's limits.
179.39 KB |
8168 Time(s) |
309.51 KB |
8168 Time(s) |
123.22 KB |
8168 Time(s) |
rv8ch
Posted: Sun Aug 05, 2012 10:56 am Post subject: Starter contactor leaking voltage |
Joe, Eric, Bob,
Thanks so much for the feedback - I tried the lamp, and of course it did not light up. Also used an older analog instrument, and it showed no indication of voltage. Thanks to your help and a bit of time reading up on impedance, I have a better understanding what is happening here. I'm really happy to have run across this "problem" as it allowed me to learn some new stuff. Thanks again!
Mickey
On Sun, Aug 5, 2012 at 4:51 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | New question (yes, I'm building very slowly) - I have the Van's starter contactor (Part Number = ES 24021) and when I apply 12v to the battery connection, I get about 0.4v on the starter connection. Â This is before it is energized. Â When I apply the 12v to the 'S' terminal, I get the full 12v on the starter terminal.
Mickey
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
[img]cid:.0[/img]
at 150 volts.
on the order of 2%.
to function at all.
[img]cid:.1[/img]
looks like this:
[img]cid:.2[/img]
Mickey Coggins
309.51 KB |
8160 Time(s) |
123.22 KB |
8160 Time(s) |
179.39 KB |
8160 Time(s) |
henador_titzoff(at)yahoo. Guest
Posted: Sun Aug 05, 2012 12:00 pm Post subject: Starter contactor leaking voltage |
Eric,
This has nothing to do with aviation other than avionics are built with ICs. I would just like to know how not including the power supply trace from pin to circuitry allows the chip circuitry to work as advertised (datasheet)? I've never heard of a chip that worked without intended power. Since it was CMOS and CMOS is very conservative with power, did it somehow derive its power from IO signals?
You must be an Analog Devices kind of guy. I worked at Teradyne for several years. It was a lot of fun riding the train to South Station every weekday.
Henador Titzoff
--- On Sun, 8/5/12, Eric M. Jones <emjones(at)charter.net> wrote:
Subject: Re: Starter contactor leaking voltage
Date: Sunday, August 5, 2012, 7:48 AM
--> AeroElectric-List message posted by: "Eric M. Jones" <[url=/mc/compose?to=emjones(at)charter.net]emjones(at)charter.net[/url]>
repost
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=380088#380088
http://forums.matronics.com//files/diode_test_745.pdfhttp://www.matronics.com/Navigator= - MATRONICS cs.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution [quote][b]
Posted: Sun Aug 05, 2012 1:54 pm Post subject: Starter contactor leaking voltage |
At 01:54 PM 8/5/2012, you wrote:
| Quote: | Joe, Eric, Bob,
lamp, and of course it did not light up. Â Also
no indication of voltage. Â Thanks to your help
here. Â I'm really happy to have run across this
"problem" as it allowed me to learn some new stuff. Â Thanks again!
Mickey
I've taken this posting to the List and fixed
some syntax/spelling issues, converted to a pdf
and posted it to AeroElectric.com article archives.
The cleaned up document is available at:
http://tinyurl.com/8oe5wbj
Posted: Sun Aug 05, 2012 4:32 pm Post subject: Re: Starter contactor leaking voltage |
Many troubleshooters have come to the wrong conclusion when testing a circuit with a voltmeter without the circuit being loaded. The troubleshooter might think, "The voltmeter reads 12 volts. Therefore everything up to this point must be OK." Without a load, that hypothesis could be incorrect. No load means no current. No current means no voltage drop. So a voltmeter will read normal voltage even if there is unwanted high resistance in the circuit. The high resistance could be due to a bad switch or a loose connection or corrosion or whatever. Without current flowing through that resistance, there will be no voltage drop across it. A voltmeter could read normal voltage when no current is flowing in a problem circuit.
Joe
