Malcolmbru(at)aol.com Guest
Posted: Thu Jun 01, 2006 6:07 pm Post subject: radiator additive ? |
any body had any luck adding something to the radiator fluid to keep it
cooler ? mal
kingjohne(at)adelphia.net Guest
Posted: Thu Jun 01, 2006 7:44 pm Post subject: radiator additive ? |
I use a 50/50 mix of coolant and distilled water.
John King
Warrenton, VA
Malcolmbru(at)aol.com wrote:
cooler ? mal
Posted: Thu Jun 01, 2006 8:47 pm Post subject: radiator additive ? |
That was my question to Don S. last week. Apparently
nothing he changed or added worked except what he did
phsically to the radiator.
kurt S.
--- Malcolmbru(at)aol.com wrote:
| Quote: | any body had any luck adding something to the
cooler ? mal
dosmythe(at)cox.net Guest
Posted: Fri Jun 02, 2006 3:24 am Post subject: radiator additive ? |
Kurt,
That's true but, there are some small advantages to reducing the
antifreeze ratio to say, 70% water to 30% antifreeze. The product
"Waterwetter" will supposedly work wonders but only works it's best when
mixed with water only and no antifreeze. I talked with the Waterwetter
folks and they insured me that their product would provide all the
lubrication needed without any antifreeze. I wasn't willing to trust their
product without some antifreeze to lubricate the engine parts. Again,
Waterwetter did provide a little improvement.
Depending on what temps an engine is running, all these little extras
might be enough but I don't think they will provide enough help in an engine
that is running excessive high temps.
Don Smythe
