which one to cut out?
fireflier
PostPosted: Mon Jul 30, 2012 2:05 pm    Post subject: which one to cut out? Reply with quote
Looking for some advice and help if possible?
I have been marking the cockpit module to trim and cut out etc. However when it came to marking for the rudder cable access holes I have a problem and don't know which one to cut out.
On the port side of the cockpit module there is 2 lots of trim lines one is hatched the other isn't. There is only one marked on the starboard side, this again has the hatched lines through it.
The attached photo will give a better understanding of the problem I have.
I'm leaning towards the hatched one being the correct one to cut out as this matches the one on the starboard side of the module.
Any help as to determining the correct one to cut out would be much appreciated.
Kind regards
Donald
 Filesize:  116.76 KB
 Viewed:  2909 Time(s)
Fireflier
rparigoris
PostPosted: Mon Jul 30, 2012 2:34 pm    Post subject: which one to cut out? Reply with quote
Hi Donald
"> Looking for some advice and help if possible? > > I have been marking the cockpit module to trim and cut out etc. However > when it came to marking for the rudder cable access holes I have a problem > and don't know which one to cut out."
You can have a look at a few pics of my Mono XS:
http://www.europaowners.org/main.php?g2_itemId=86921
Ron Parigoris
rlborger(at)mac.com
PostPosted: Mon Jul 30, 2012 2:54 pm    Post subject: which one to cut out? Reply with quote
Donald,
Here's a picture from below of what I believe are the openings in the cockpit module you write about.
[img]cid:ABB6DDFA-88F8-4996-8393-B6A348AD3A94[/img]
They are cut out in the most outboard locations.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jul 30, 2012, at 5:05 PM, fireflier wrote:
--> Europa-List message posted by: "fireflier" <fireflier(at)btinternet.com (fireflier(at)btinternet.com)>
Kind regards
Donald
Fireflier
http://forums.matronics.com/viewtopic.php?p=379634#379634
http://forums.matronics.com//files/rudder_cable_access_holes_897.j - The Europa-List --> &n========================<b -   &nbs --> ========================
 Filesize:  77.15 KB
 Viewed:  2907 Time(s)
