Posted: Sun Jul 29, 2012 9:27 am Post subject: Elevator in trail |
Just short of 30 hours on N7ZK. Attached photo is of the elevator horn in level flight. As you can see, the elevator trailing edge is slightly down. This implies the HS is creating too much downward force and the elevator is adding upward force to compensate. The question for the group is would it be worthwhile to add a shim under the forward HS spar – say .040” or so to correct for this, or is it close enough? This is solo, so any weight in the back would, I assume, make the issue more pronounced.
Carl
8.58 KB |
6517 Time(s) |
jchang10
Posted: Sun Jul 29, 2012 10:14 am Post subject: Elevator in trail |
That is perfectly normal. Looks identical to mine in cruise. Not an aeronautical engineer, but i believe the CG moves aft as speed increases. Also, i think it's designed that way for greater efficiency, as there is less downforce on the HS creating a greater net lifting force of the plane overall.
Jae
On 7/29/2012 10:26 AM, Carl Froehlich wrote: [quote] <![endif]--> <![endif]-->
Carl
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
do not archive[b]
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
Bob Turner
Posted: Sun Jul 29, 2012 12:35 pm Post subject: Re: Elevator in trail |
I'd urge caution. If you reduce the downward force the tail can generate you might find yourself landing nose wheel first, especially at forward cg.
_________________ Bob Turner
RV-10 QB |
Posted: Sun Jul 29, 2012 12:58 pm Post subject: Elevator in trail |
Thought about that, but as is solo (the most forward CG that I will have) I
have a lot of nose up trim left on landing.
Carl
woxofswa
Posted: Sun Jul 29, 2012 8:04 pm Post subject: Re: Elevator in trail |
I don't have one in front of me, but I seem to recall seeing ad pictures of the yellow RV10 demonstrator in magazines wherein you see a bunch of the elevator counterweight protruding up. I always thought that was odd.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Kellym
Posted: Sun Jul 29, 2012 9:08 pm Post subject: Elevator in trail |
Well, most every Mooney I have flown in has a more pronounced elevator
displacement during cruise. I don't think you are going to get
perfection on angle of incidence to the point you get rid of elevator
displacement. Maybe could be done for one specific wt and cruise speed,
but would be out for anything else.
On 7/29/2012 9:04 PM, woxofswa wrote:
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress.
http://forums.matronics.com/viewtopic.php?p=379549#379549
KCHD |
toaster73(at)embarqmail.c Guest
Posted: Mon Jul 30, 2012 4:41 am Post subject: Elevator in trail |
Consider a stabilator - all moving tail, I wonder how you tell where one of
those is supposed to be in cruise??
-Chris
N919AR
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Jul 30, 2012 5:21 am Post subject: Elevator in trail |
Stick force.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Kellym
Posted: Mon Jul 30, 2012 6:08 am Post subject: Elevator in trail |
The Mooney uses an all moving tail, including the vertical stab. It is
like any other tail setup, you trim for neutral forces.
Where the elevator winds up is apparently a function of c.g. mostly. To
have a longitudinally stable aircraft the tail has to be generating some
downforce, it can't be neutral.
-Chris
N919AR
KCHD |
rv10flyer(at)verizon.net Guest
Posted: Mon Jul 30, 2012 6:28 am Post subject: Elevator in trail |
Probably already covered. Been flying so not following this thread.
Tim made comment on this on his page-
http://www.myrv10.com/N104CD/maintenance/20080622/index.html
My plane flies great, don't lose too much time worrying about this.. keep
building!
rv10flyer
Posted: Tue Jul 31, 2012 4:44 pm Post subject: Re: Elevator in trail |
Solo or hauling the family, mine does not change position much. Like yours, slightly above at 160 ktas. I would leave it alone.
_________________ Wayne G. |
Posted: Thu Aug 02, 2012 5:51 pm Post subject: Elevator in trail |
My comment was tongue in cheek - hard to show on email.
-Chris
