carlossa52(at)gmail.com Guest
Posted: Sun Jul 08, 2012 4:00 pm Post subject: CH601-HD(S) fuselage assembly |
Hello, folksMy aluminum stack is finally starting to resemble an aircraft (if you have a lot of imagination, that is): http://www.zenith.aero/photo/img-6058When I put the front side skins in place (just to have an idea of what it would look like), I noticed the interference between the side skins, heel support and floor (the rolled end of the floor). The attached pics show the offending area.The instructions simply say "trim as required" (or something like that). To me, it seems I'll have to remove a semi-circle one or two inches in diameter - as I haven't seen any comments about this, I am a little concerned. I also have looked at a few of the CH601 sites still on-line, but I did not find any picture or comment that would clarify this. Thanks in advance for your comments / suggestions CarlosCH601-HD, plans
1.92 MB |
3657 Time(s) |
1.75 MB |
3657 Time(s) |
jaybannist(at)cs.com Guest
Posted: Tue Jul 10, 2012 8:07 am Post subject: CH601-HD(S) fuselage assembly |
When building, I was amused by some of ZAC's dimensions, such as 25.2mm or 33.7mm. The sharpest Sharpie (Ultra Fine) mark I have is about 0.5mm wide and the "fat" Sharpie (Fine) is about 2mm wide. I defy anyone to measure 25.2mm, mark that with a Sharpie and be confident that they have a 0.2mm accuracy..
Posted: Tue Jul 10, 2012 8:16 am Post subject: CH601-HD(S) fuselage assembly |
Very well said (written) !!!
On 10 July 2012 12:04, Jay Bannister <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
[quote]When building, I was amused by some of ZAC's dimensions, such as 25.2mm or 33.7mm. The sharpest Sharpie (Ultra Fine) mark I have is about 0.5mm wide and the "fat" Sharpie (Fine) is about 2mm wide. I defy anyone to measure 25.2mm, mark that with a Sharpie and be confident that they have a 0.2mm accuracy..
steve.freeman(at)syntaxds Guest
Posted: Tue Jul 10, 2012 8:45 am Post subject: CH601-HD(S) fuselage assembly |
We are not building the Space Shuttle here folks!
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Carlos Sa
Sent: Tuesday, July 10, 2012 9:14 AM
Subject: Re: CH601-HD(S) fuselage assembly
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 01234567
psm(at)att.net Guest
Posted: Tue Jul 10, 2012 9:01 am Post subject: CH601-HD(S) fuselage assembly |
I certainly hope not! Space shuttles have a bad history of killing people.
Paul
Steve [b]
Posted: Tue Jul 10, 2012 9:33 am Post subject: CH601-HD(S) fuselage assembly |
We aren't?!? Darn ! What do I do with all those thermal tiles now?
On 10 July 2012 12:42, Steven Freeeman <steve.freeman(at)syntaxds.com (steve.freeman(at)syntaxds.com)> wrote:
Steve
