CH601-HD(S) fuselage assembly
carlossa52(at)gmail.com
PostPosted: Sun Jul 08, 2012 4:00 pm    Post subject: CH601-HD(S) fuselage assembly Reply with quote
Hello, folksMy aluminum stack is finally starting to resemble an aircraft (if you have a lot of imagination, that is): http://www.zenith.aero/photo/img-6058When I put the front side skins in place (just to have an idea of what it would look like), I noticed the interference between the side skins, heel support and floor (the rolled end of the floor). The attached pics show the offending area.The instructions simply say "trim as required" (or something like that). To me, it seems I'll have to remove a semi-circle one or two inches in diameter - as I haven't seen any comments about this, I am a little concerned. I also have looked at a few of the CH601 sites still on-line, but I did not find any picture or comment that would clarify this. Thanks in advance for your comments / suggestions CarlosCH601-HD, plans
 Filesize:  1.92 MB
 Viewed:  4365 Time(s)
 Filesize:  1.75 MB
jaybannist(at)cs.com
PostPosted: Sun Jul 08, 2012 5:32 pm    Post subject: CH601-HD(S) fuselage assembly Reply with quote
Carlos,
I'm not sure when it started, but I discovered this problem (with my 601XL) in June 2006 and reported it to Zenith. They published a revised photo guide page, saying that it had to be trimmed. (I had already done that) I think they revised the part after that, but I really don't know if they ever revised the drawing for the part.
Jay
PostPosted: Sun Jul 08, 2012 5:40 pm    Post subject: CH601-HD(S) fuselage assembly Reply with quote
So it happens on the XL as well?! I'll take a look at XL pics, then Thanks, JayCarlos
On 8 July 2012 21:31, Jay Bannister <jaybannist(at)cs.com (jaybannist(at)cs.com)> wrote:
[quote] Carlos,
Jay
bryanmmartin
PostPosted: Mon Jul 09, 2012 3:43 am    Post subject: CH601-HD(S) fuselage assembly Reply with quote
I would trim the corner of the heel support, it's non structural. Trim the side skin only if necessary.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
Bryan Martin
do not archive.
PostPosted: Mon Jul 09, 2012 4:38 am    Post subject: CH601-HD(S) fuselage assembly Reply with quote
Thanks for the input, Brian
On 9 July 2012 07:42, Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)> wrote:
[quote]--> Zenith601-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)>
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.[b]
