Posted: Mon Jul 02, 2012 7:39 am Post subject: Dolly (was Building order) |
Thanks Jim
Also a smart idea
BR
Carlos
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: segunda-feira, 2 de Julho de 2012 15:10
Subject: Re: FW: Building order
With regards to making a dolly to move the fuselage around. I adapted some tires during construction to allow me to roll the fuselage around.
Pictures are attached.
Fuselage remained low to make it easy to work on and It was easily moved around.
Jim Combs
N312F
I gave these to someone on the list to use and forward to another builder when then finished.
jeff(at)westcottpress.com Guest
Posted: Mon Jul 02, 2012 10:50 am Post subject: Dolly (was Building order) |
I'm in the printing business, so we have a lot of pallets sitting around. The larger ones, with big runners, make perfect platforms for building the fuse. I put a set of wheels on one and it was quite handy. When it came time to lift the plane up to put it on the gear, or to lift it off the ground (once on the gear) to fit the wheel pants, I just slid a scissor jack under the pallet and up she went:
[img]cid:08746D5C-8983-44BB-8E72-36CDD21861FF[/img]
[img]cid:DC21DC72-9423-4E42-A492-261369A39213[/img]
[img]cid:5EDBFE64-C028-4272-A71D-A3D30C1F4C7E[/img]
[img]cid:5648D3D9-11CF-494A-95C3-C2E5D05AE758[/img]
Jeff Carpenter
40304
On Jul 2, 2012, at 8:38 AM, Carlos Trigo wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Thanks Jim
Also a smart idea
BR
Carlos
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jim Combs
Jim Combs
N312F
82.43 KB |
1796 Time(s) |
64.1 KB |
1796 Time(s) |
68.95 KB |
1796 Time(s) |
90.48 KB |
1796 Time(s) |
