sean(at)stephensville.com Guest
Posted: Thu Jun 28, 2012 5:43 am Post subject: Brake Back Plate Bolts Not Drilled? |
Assembling the brakes on the mains the other day and I noticed that the
two bolts that came with the brake assemblies which attach the back
plate were not drilled head bolts. Every plane I've seen has these two
bolts safety-wired.
Did others get non-drilled head bolts with their brake assemblies, or is
it just me?
I believe that those two bolts are AN4-20? Is that what others replaced
them with for safety wiring?
-Sean #40303 (Overhead Console)
dmaib@me.com
Posted: Thu Jun 28, 2012 5:56 am Post subject: Re: Brake Back Plate Bolts Not Drilled? |
They are not drilled head bolts. The DAR noticed this during our AW inspection and asked about it. We looked in the plans and found that they do not call for drilled heads. He was surprised, but OK with it since it was per plans. I decided to go ahead and install drilled head bolts and safety wire for peace of mind.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Kellym
Posted: Thu Jun 28, 2012 5:56 am Post subject: Brake Back Plate Bolts Not Drilled? |
Having drilled head bolts there is a belt and suspenders approach. In
most Cleveland brake calipers the bolts go into self locking threads and
need no additional retention. The Cessna 170/172 Cleveland retrofit kits
don't have drilled bolts either...flew with them for 20+ years with no
problems.
On 6/28/2012 6:42 AM, Sean Stephens wrote:
the two bolts that came with the brake assemblies which attach the
back plate were not drilled head bolts. Every plane I've seen has
these two bolts safety-wired.
is it just me?
replaced them with for safety wiring?
Checked by AVG - www.avg.com
KCHD |
Kelly McMullen
Posted: Thu Jun 28, 2012 7:17 am Post subject: Brake Back Plate Bolts Not Drilled? |
Note that it is Cleveland that supplies the brakes without drilled head bolts. I don't recall which variety of self locking they use, but the calipers definitely have self locking on those bolts. You cannot back a bolt out 1/2 turn and then hand turn bolt as you could if they were ordinary threads.
On Thu, Jun 28, 2012 at 6:56 AM, dmaib(at)me.com (dmaib(at)me.com) <dmaib(at)me.com (dmaib(at)me.com)> wrote:
[quote] --> RV10-List message posted by: "dmaib(at)me.com (dmaib(at)me.com)" <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=376775#376775
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu Jun 28, 2012 7:33 am Post subject: Brake Back Plate Bolts Not Drilled? |
Another area that could be addressed is that Cleveland uses nylock nuts to secure the guide pins. I've seen the plastic melted away after the brakes get hot. That's a good place for a metal nut. Not that there's a huge chance of the guide pins falling out but it couldn't hurt.
Dave Saylor
831-750-0284 CL
On Thu, Jun 28, 2012 at 6:56 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote] --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Having drilled head bolts there is a belt and suspenders approach. In most Cleveland brake calipers the bolts go into self locking threads and need no additional retention. The Cessna 170/172 Cleveland retrofit kits don't have drilled bolts either...flew with them for 20+ years with no problems.
| Quote: | --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Assembling the brakes on the mains the other day and I noticed that the two bolts that came with the brake assemblies which attach the back plate were not drilled head bolts. Â Every plane I've seen has these two bolts safety-wired.
Did others get non-drilled head bolts with their brake assemblies, or is it just me?
I believe that those two bolts are AN4-20? Â Is that what others replaced them with for safety wiring?
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Posted: Thu Jun 28, 2012 7:40 am Post subject: Brake Back Plate Bolts Not Drilled? |
Yes, the non-drilled bolts come with the kit from Parker/Cleveland. I
noticed that locking effect when I was removing the bolts. It would
seem to prevent the bolt from backing out under most if not all
vibration scenarios when torqued to the spec on the calipers.
I was just wondering if some folks but on their belt and suspenders and
swapped them out for AN4H-20A.
On 6/28/12 10:17 AM, Kelly McMullen wrote:
| Quote: | Note that it is Cleveland that supplies the brakes without drilled
On Thu, Jun 28, 2012 at 6:56 AM, dmaib(at)me.com <mailto:dmaib(at)me.com>
<dmaib(at)me.com <mailto:dmaib(at)me.com>> wrote:
<mailto:dmaib(at)me.com>" <dmaib(at)me.com <mailto:dmaib(at)me.com>>
David Maib
RV-10 #40559
Transition Trainer
le, List Admin.
rv10pro(at)gmail.com Guest
Posted: Thu Jun 28, 2012 8:18 am Post subject: Brake Back Plate Bolts Not Drilled? |
the wheel assemblies are supplied by MATCO. Matco has changed to Nordlock washers as the fastener of choice. The AN4H (with hole in the head) has been replaced with Nordlocks.
Johnny Horizon
Assembling the brakes on the mains the other day and I noticed that the two bolts that came with the brake assemblies which attach the back plate were not drilled head bolts. Every plane I've seen has these two bolts safety-wired.
I believe that those two bolts are AN4-20? Is that what others replaced them with for safety wiring?
le, List Admin.
Posted: Thu Jun 28, 2012 8:32 am Post subject: Brake Back Plate Bolts Not Drilled? |
My "main" wheels and brake kits are from Parker Cleveland. It came with
AN4-20A bolts to attach the back plate.
The nose wheel axle has the Nordlock washers, not the main
wheels/brakes. At least on my kit.
-Sean #40303
On 6/28/12 11:16 AM, John Cox wrote:
| Quote: | the wheel assemblies are supplied by MATCO. Matco has changed to
Johnny Horizon
<mailto:kellym(at)aviating.com>> wrote:
<kellym(at)aviating.com <mailto:kellym(at)aviating.com>>
<sean(at)stephensville.com <mailto:sean(at)stephensville.com>>
Checked by AVG - www.avg.com <http://www.avg.com>
le, List Admin.
Kelly McMullen
Posted: Thu Jun 28, 2012 1:26 pm Post subject: Brake Back Plate Bolts Not Drilled? |
Has Van's changed from Cleveland wheels/brakes for the mains? When I got my finish kit 18 mo ago it was all Cleveland on the mains. The Clevelands do not use drilled head bolts.
Kelly
40866
On Thu, Jun 28, 2012 at 9:16 AM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
[quote] the wheel assemblies are supplied by MATCO. Matco has changed to Nordlock washers as the fastener of choice. The AN4H (with hole in the head) has been replaced with Nordlocks.
Johnny Horizon
KCHD |
tsts4
Posted: Thu Jun 28, 2012 1:50 pm Post subject: Re: Brake Back Plate Bolts Not Drilled? |
Hmmm. I got my finish kit back in the Fall and my brakes were Grove and the bolts came drilled. Has Van's been changing suppliers?
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
Sstella(at)incisaledge.co Guest
Posted: Thu Jun 28, 2012 2:35 pm Post subject: Brake Back Plate Bolts Not Drilled? |
I just got my finish kit on Tuesday and the brakes were also Grove.
Steve Stella
#40654
521RV (reserved)
Finishing
Bob Turner
Posted: Thu Jun 28, 2012 4:27 pm Post subject: Re: Brake Back Plate Bolts Not Drilled? |
I think I read that Vans had changed the main wheels.
Are the Grove brake pads less expensive than the $18 each Clevelands?
_________________ Bob Turner
RV-10 QB |
tsts4
Posted: Thu Jun 28, 2012 6:57 pm Post subject: Re: Brake Back Plate Bolts Not Drilled? |
| Bob Turner wrote: | I think I read that Vans had changed the main wheels.
Are the Grove brake pads less expensive than the $18 each Clevelands? |
Appears to be. From the Grove Website, the pads for the the 36-2M caliper that came in my kit:
066-105 Brake Pad
Each - P/N: 066-105 - $7.45
Kit - P/N: 066-105K - $26.50
Includes 4 pads and 8 rivets
5.77 KB |
12884 Time(s) |
RV-10 N728TT -- Flying |
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Fri Jun 29, 2012 4:25 am Post subject: Re: Brake Back Plate Bolts Not Drilled? |
In looking at the differences between the Grove and Cleveland brakes the Grove's appear to be a bit stronger. The Grove's are rated at 7000lbs with 186792 lb-ft and the Cleveland's are rated 6000 lbs with 185000 ft-lbs. Not that the Cleveland brakes are all that bad, but I sure am glad they moved in the right direction by beefing them up just a bit.
Noticed the other night we are approaching 400 hours - how time flies when you're, well, flying!
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
