fredorosa(at)gmail.com Guest
Posted: Mon Jun 18, 2012 4:41 am Post subject: seat belts |
I'm at the seat belt installation stage with my TR-4 and it looks like the only option is to use 4 point shoulder and lap straps.They would have to be anchored in the ceiling above the seat backs. How did some of you handle this installation?
Photos would help.
Al Rosa
galinhdz(at)gmail.com Guest
Posted: Mon Jun 18, 2012 4:55 am Post subject: seat belts |
That is how the seat belts are installed in mine.
[img]cid:ii_137ffa723b401eff[/img]
On Mon, Jun 18, 2012 at 7:40 AM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
| Quote: | I'm at the seat belt installation stage with my TR-4 and it looks like the only option is to use 4 point shoulder and lap straps. They would have to be anchored in the ceiling above the seat backs. How did some of you handle this installation?
Photos would help.
Al Rosa
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
431.38 KB |
2658 Time(s) |
Posted: Mon Jun 18, 2012 5:05 am Post subject: seat belts |
That's what I'm talking about but I can't make out the method of anchoring.
On Mon, Jun 18, 2012 at 8:53 AM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
| Quote: | That is how the seat belts are installed in mine.
Photos would help.
Al Rosa
431.38 KB |
2658 Time(s) |
kentpyle(at)iland.net Guest
Posted: Wed Jun 27, 2012 6:08 pm Post subject: seat belts |
Al, I used tinnerman washers and a lot of fiberglass cloth. After blending it in you can not notice the “lump” on the out side of the fuselage.
Kent
Sent: Monday, June 18, 2012 8:04 AM
Subject: Re: seat belts
[img]cid:3ED6E9D5149941E499572594E11F241D(at)n302km[/img]
Photos would help.
Al Rosa
431.38 KB |
2614 Time(s) |
Posted: Thu Jun 28, 2012 5:12 am Post subject: seat belts |
Building up the outside of the fuselage sounds a little extreme. I think what I'll do is build up a portion of the "roll bar"structure on the inside ceiling and fill it with flox mixture from a hole drilled in the outside skin. then it would be solid enough to take a bolt through the "roll bar" from front to back and not penetrate to the outside.
By the way, I decided on a non retractable 1 piece lap/shoulder belt anchored at 3 points like most cars are equipped.
I was thinking of a retractable belt but read that they have to be mounted on the vertical and wont work roof mounted.
I'll send pics when finished.
Al
On Wed, Jun 27, 2012 at 10:05 PM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
| Quote: | Al, I used tinnerman washers and a lot of fiberglass cloth. After blending it in you can not notice the “lump” on the out side of the fuselage.
Kent
Photos would help.
Al Rosa
431.38 KB |
2610 Time(s) |
