kheindl(at)msn.com Guest
Posted: Mon Jun 25, 2012 10:46 am Post subject: Contact detail & Help |
Hi Frans,
I have been following your developments with great interest and I think that the end result is just plain amazing. Your Europa must be the slickest and fastest in this Universe.
Now, top speed is very useful for testing drag improvements, but you don't cruise at those speeds, do you ? When you are touring, what are your preferred settings regarding speed, MP, rpm etc., and exactly what is your fuel consumption then.
If the rest of us mortals wanted to implement some of your changes without too much expense, what would you recommend ? Speed isn't all that important to me, but improvements in cooling and under-cowl temperatures would be very beneficial. What is the part number for the heat exchanger and exactly where did you install it ?
I recently had a look at a CT with 912s. It has a very neat fwf package. I noticed that it also has larger rads back-to-back, tucked in under its belly ahead of the exhaust, but at an angle of 45 degrees. I also noticed an oil thermostat, and a pulsation damper on top of the engine for the fuel flow gauge (I could never get that to work on my engine). It had 800 hours on it but still looked brand new. It also had a very small (8AH?) battery.
Karl
| Quote: | Date: Sun, 24 Jun 2012 13:31:53 +0200
Subject: Re: Re: Contact detail & Help
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl>
On 06/23/2012 12:01 AM, Bud Yerly wrote:
> Lovely design...
Thanks!
> However, my comments are based on an installation that is stock. Takes
> 40 hours from openning the box to engine fully installed and ready for
> start and is reapeatable with only the parts in the box.
My solution would be even faster to build, if they would change the
contents of the box of course. It puzzles me why the contents of the box
has not been changed long time ago, when people started to complain
about inadequate cooling.
> Many do not care to have any auto systems such as heat exchangers which
> may malfunction.
There is no auto system involved. The heat exchanger is just two fluid
channels thermo coupled to each other. No moving parts, no electronic
parts, just similar to a radiator, but now with two fluid channels
instead of one fluid and one gas channel.
> By all means, an extra hundred hours and cost will get you those extra 9
> knots. It just costs money and time.
This argument is silly. Then why applying a finish on the airplane and
not painting the raw fabric? It just costs money and time to apply a
finish, for only 9 knots of speed or so.
9 knots of speed:
1) The difference between a mono and tri gear.
2) equals to 10% fuel savings when flying with equal speeds.
10% fuel saving means:
1) About 10% lower operational costs.
2) About 5 Kg's (10 lbs) of weight saving for the same flying distance
because you need to carry less fuel.
3) A 10% larger range on a full tank.
> The airplane is 20,000 compromises flying in close formation....Choose
> your changes wisely.
If I wanted a stock airplane and didn't care about speed, I would
probably be flying a Cessna 152.
> Archive Search & Download, 7-Day Browse, Chat, FAQ,
frans(at)privatepilots.nl Guest
Posted: Mon Jun 25, 2012 12:15 pm Post subject: Contact detail & Help |
Hi Karl,
| Quote: | I have been following your developments with great interest and I think
Thanks!
| Quote: | Now, top speed is very useful for testing drag improvements, but you
I found the sweet spot of the aircraft is with 27 inch MAP, where it
usually cruises with a speed somewhere between 120 and 130 KIAS,
depending on C of G and some other obscure factors. Fuel consumption
used to be 16 to 17 liters per hour, but I have observed this year that
the fuel consumption has increased to 18 liters per hour. Maybe the
carbs need an overhaul or so.
RPM is usually between 4800 and 5000 RPM, this feels best for the
engine. I have a two blade prop and at lower RPM's it feels less smooth.
Of course actual settings depend on various circumstances. With a strong
head wind we usually advance the throttle a bit, with a tail wind we
enjoy the lower fuel consumption of a lower power setting. We fly 90% of
our cruising with power between 26 and 28 inch.
With higher power settings the fuel consumption goes up faster than the
gain in speed. Other than in a car, a higher speed doesn't give any
other feeling than a lower speed, it just gives the same sensation. One
hour flying is still one hour flying. On a 3-hour trip I rather enjoy an
additional 10 minutes flying and have a free meal than just cranking up
the fuel consumption, paying more for less fun. AVGAS can be close to 3
Euro's per liter over here, so saving 10 liters on a trip can save
enough money to have a dinner for two! I love telling friends that
flying there isn't more expensive than getting there by car.
| Quote: | If the rest of us mortals wanted to implement some of your changes
There isn't much money involved actually. The radiator costs about 300
Euro's, the heat exchanger a bit less. You can do without the heat
exchanger, I have been flying one summer with the stock oil radiator fed
by a 2" Scat tube via a wedge diffuser. Apart from the long warm up time
it was quite an improvement over the tandem setup. Best thing to do is
to scrap the stock coolant radiator, dog house, duct and associated
hardware and just install a thin radiator in a 45 degree angle in front
of the exhaust and turbo.
The main hurdle here is to shape a new underside of the cowling. You
have to be brave enough to cut the dog house away, and then insert a
block of blue foam and start cutting, rasping, sanding until you have
the shape you desire. Anyone who wants to make a mold out of my cowling
is welcome to do so, provided I'm allowed to use that mold to make a new
light weight carbon cowling for myself.
BTW I'm not the only one who devised something like this. See the
attached picture. This is another configuration with a thin radiator in
a 45 degree angle, although it lacks a cowl flap and heat exchanger for
the oil. (Oil is cooled by a radiator, fed by a NASA duct on the port
side, you can see it on the picture). Also this owner claims very good
results with his setup on his 914 engine. The key really is to use a
thin radiator and mount it at the belly so the "used" air can take the
heat of the exhaust with it, and enjoy the benefits of a very sleek
cowling, excellent cooling, low pressure losses, and minimal cooling drag.
Anyway, my cooling design is not an exclusive invention of me but the
combination of ideas and experiments of multiple Europa owners who
believed that the cooling of the Europa could be improved other than by
using draggy brute force solutions.
| Quote: | What is the part number for the
See picture, taken from under the engine. The heat exchanger is mounted
behind the engine. This was the first setup, with the stock coolant
radiator, hence the configuration of the coolant hoses pointing
downwards. In the current design the hose routing has been changed to
accomodate for the thin belly radiator.
If you really want to go this way, contact me privately for more info.
One caveat though: this heat exchanger has very thin canals and is not
compatible with Evans coolant due to its viscosity. I use it with 50/50
without problems.
| Quote: | It also had a very
I also have a small 8Ah battery, never needed anything more than that.
But I have a second alternator (mounted on the vaccuum pad) so I don't
need the battery as a backup during flight, I just need it for starting.
Frans
579.03 KB |
4083 Time(s) |
64.35 KB |
4083 Time(s) |
max.cointe(at)eliops.fr Guest
Posted: Tue Jun 26, 2012 5:10 am Post subject: Contact detail & Help |
Hi Frans,
I'm a bit puzzle by your first picture: are the blue pipes directly
connected to that flat radiator? I think these end at the bottom level of
the exhaust, so what is the shape of the radiator...
Other question: have you experienced (or do you think there is) differences
on that topic between 914 and 912?
Max Cointe
F-PMLH TriGear Kit #560
912ULS Airmaster 420 hours
mcointe(at)free.fr
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Frans Veldman
Envoyé : lundi 25 juin 2012 23:10 À : europa-list(at)matronics.com Objet : Re:
Hi Karl,
Thanks!
I found the sweet spot of the aircraft is with 27 inch MAP, where it usually
cruises with a speed somewhere between 120 and 130 KIAS, depending on C of G
and some other obscure factors. Fuel consumption used to be 16 to 17 liters
per hour, but I have observed this year that the fuel consumption has
increased to 18 liters per hour. Maybe the carbs need an overhaul or so.
RPM is usually between 4800 and 5000 RPM, this feels best for the engine. I
head wind we usually advance the throttle a bit, with a tail wind we enjoy
the lower fuel consumption of a lower power setting. We fly 90% of our
With higher power settings the fuel consumption goes up faster than the gain
in speed. Other than in a car, a higher speed doesn't give any other feeling
than a lower speed, it just gives the same sensation. One hour flying is
still one hour flying. On a 3-hour trip I rather enjoy an additional 10
minutes flying and have a free meal than just cranking up the fuel
consumption, paying more for less fun. AVGAS can be close to 3 Euro's per
liter over here, so saving 10 liters on a trip can save enough money to have
a dinner for two! I love telling friends that flying there isn't more
exchanger, I have been flying one summer with the stock oil radiator fed by
a 2" Scat tube via a wedge diffuser. Apart from the long warm up time it was
quite an improvement over the tandem setup. Best thing to do is to scrap the
stock coolant radiator, dog house, duct and associated hardware and just
install a thin radiator in a 45 degree angle in front of the exhaust and
turbo.
The main hurdle here is to shape a new underside of the cowling. You have to
be brave enough to cut the dog house away, and then insert a block of blue
foam and start cutting, rasping, sanding until you have the shape you
desire. Anyone who wants to make a mold out of my cowling is welcome to do
so, provided I'm allowed to use that mold to make a new light weight carbon
cowling for myself.
BTW I'm not the only one who devised something like this. See the attached
picture. This is another configuration with a thin radiator in a 45 degree
angle, although it lacks a cowl flap and heat exchanger for the oil. (Oil is
cooled by a radiator, fed by a NASA duct on the port side, you can see it on
the picture). Also this owner claims very good results with his setup on his
914 engine. The key really is to use a thin radiator and mount it at the
belly so the "used" air can take the heat of the exhaust with it, and enjoy
the benefits of a very sleek cowling, excellent cooling, low pressure
combination of ideas and experiments of multiple Europa owners who believed
that the cooling of the Europa could be improved other than by using draggy
radiator, hence the configuration of the coolant hoses pointing downwards.
In the current design the hose routing has been changed to accomodate for
without problems.
But I have a second alternator (mounted on the vaccuum pad) so I don't need
Frans
Posted: Tue Jun 26, 2012 5:57 am Post subject: Contact detail & Help |
Hi Frans,
Thank you for the additional information. I will follow your advice, but probably not until next year.If you are going to publish in the flyer, then some good pictures please of the radiator installations.Also, a source for the rads.
You mentioned that the prop is not as smooth at lower rpm's. I have the same prop and I discovered a long time ago that the carbs need to be in sync 100% for a two-bladed prop. With three blades the carbs would need to be out of sync quite a bit before you would notice. I know, because I tried it by putting my original Warp Drive back on.
Karl
[quote] Date: Mon, 25 Jun 2012 23:09:34 +0200
Hi Karl,
Thanks!
cowlng, excellent cooling, low pressure losses, and minimal cooling drag.
without problems.
> It also had a very
Posted: Tue Jun 26, 2012 7:37 am Post subject: Contact detail & Help |
Karl
3 blades will always be smoother because when the 2 blades are horizontal each blade sees a
different AoA, especially with high angles of attack. This causes different thrist on the blades resulting
in yawing oscillation of the airplane.
Graham
Sent: Tuesday, 26 June 2012, 14:57
Subject: RE: Re: Contact detail & Help
Hi Frans,
Karl
| Quote: | Date: Mon, 25 Jun 2012 23:09:34 +0200
Hi Karl,
Thanks!
without problems.
> It also had a very
Frans
[quote]http://www.matronics.com/Naviet="_blank" href="http://forums.matronics.com/">http://forums.matronics-> [b]
Posted: Tue Jun 26, 2012 9:36 am Post subject: Contact detail & Help |
Graham, In my innocence I thought that the plane was
designed so that in normal cruise attitude the engine axis
was horizontal and the blades at equal AOA
Regards, David Joyce, G-XSDJ
On Tue, 26 Jun 2012 16:37:01 +0100 (BST)
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com> wrote:
| Quote: | Karl
Graham
Hi Frans,
Drive back on.
Karl
> From: frans(at)privatepilots.nl
> To: europa-list(at)matronics.com
> Hi Karl,
> Thanks!
>touring, what are
>and exactly what
>MAP, where it
>130 KIAS,
>consumption
>this year that
>hour. Maybe the
>best for the
>feels less smooth.
>tail wind we
>faster than the
>doesn't give any
>sensation. One
>rather enjoy an
>just cranking up
>can be close to 3
>trip can save
>car.
>your changes
>costs about 300
>without the heat
>oil radiator fed
>long warm up time
>thing to do is
>associated
>angle in front
>cowling. You
>then insert a
>until you have
>out of my cowling
>mold to make a new
>this. See the
>thin radiator in
>heat exchanger for
>duct on the port
>claims very good
>is to use a
>air can take the
>very sleek
>of me but the
>owners who
>stock coolant
>pointing
>been changed to
>for more info.
>canals and is not
>use it with 50/50
> without problems.
> > It also had a very
>more than that.
>pad) so I don't
> need the battery as a backup during flig=====
Posted: Tue Jun 26, 2012 10:28 am Post subject: Contact detail & Help |
Hi David
Yes it probably is, but it's at low speeds and high power on climb out that the vibration is worst.
With multi blade props the problem isn't as bad. I'm not good enough at maths to explain why
but I am just reiterating what Bruno Guimbal said years ago. He designed a very attractive looking helicopter I once saw at
the RSA Rally years ago. He seems to have moved on, haven't heard anything for years. Very experienced aerospace engineer
who built a Vari Eze around 1978 which he flew to Leicester when our rally was there in 1979 I think.
Graham
Sent: Tuesday, 26 June 2012, 18:35
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Graham, In my innocence I thought that the plane was designed so that in normal cruise attitude the engine axis was horizontal and the blades at equal AOA
GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
| Quote: | Karl
Graham
From: Karl Heindl <kheindl(at)msn.com (kheindl(at)msn.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) Sent: Tuesday, 26 June 2012, 14:57
Hi Frans,
Karl
> From: frans(at)privatepilots.nl (frans(at)privatepilots.nl)
> Hi Karl,
> Thanks!
> without problems.
> > It also had a very
> ne//www.matronics.com/Navigator?Europa-List" target="_blank">http://www.mat="http://forums.matronics.com/" target="_blank">http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Posted: Tue Jun 26, 2012 12:58 pm Post subject: Contact detail & Help |
On 06/26/2012 03:09 PM, Max Cointe (Eliops) wrote:
| Quote: | I'm a bit puzzle by your first picture: are the blue pipes directly
As I wrote, this picture was taken when I was still using the stock
radiator. The hose routing has been changed when I upgraded to the flat
radiator. Actually I now use aluminium pipes for the coolant for most of
the routing, because of the close proximity of the exhaust.
| Quote: | Other question: have you experienced (or do you think there is) differences
I have no 912, but as far as I know the 914 is the most difficult engine
to cool, so if it works on a 914 it should work well on a 912.
Frans
Posted: Tue Jun 26, 2012 1:05 pm Post subject: Contact detail & Help |
Hi Karl,
| Quote: | You mentioned that the prop is not as smooth at lower rpm's. I have the
I agree with you. My carbs are 100% balanced, so the whole setup runs
very smooth. However, it just feels the engine runs best at 5000 RPM. I
called it "smooth" in my previous post, but it has nothing to do with
vibrations, it is just the general impression that the engine gives. At
RPMs below 4700 it just sounds a bit as if the engine is labouring, hard
to describe precisely what I mean as English is a foreign language for me.
On the ground the prop sounds very mean, especially if the wind is not
precisely at front. I guess the inner part with lots of twist just
stalls out if there is not enough airspeed. Once airborn the prop is
very silent.
Do you also have the large twist prop?
Frans
Posted: Tue Jun 26, 2012 1:40 pm Post subject: Contact detail & Help |
Frans,
My prop is the identical model to yours; I was the first to install one, which prompted Woodcomp to make the first 10 inch spinner.It (the prop) makes a very nice low frequency sound when you listen to it from outside the aircraft.
Karl
[quote] Date: Wed, 27 Jun 2012 00:00:11 +0200
Hi Karl,
Posted: Tue Jun 26, 2012 10:52 pm Post subject: Contact detail & Help |
The Diamond Katana has a 2 blade Hoffman (doesn't it?) which makes the Rotax sound more like a quiet Lycoming!
Graham
Sent: Tuesday, 26 June 2012, 22:39
Frans,
Karl
| Quote: | Date: Wed, 27 Jun 2012 00:00:11 +0200
Hi Karl,
very silent.
Do you also have the large twist=
[quote]http://www.matronics.com/Navigator?Europa-Listhttp://=======================
budyerly(at)msn.com Guest
Posted: Sat Jun 30, 2012 8:04 am Post subject: Contact detail & Help |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> To all,
From testing with the Airmaster AP420 vs 332 a couple of notes on prop vibration/noise.
I do not intend to comment on the different brands, only the differences between a three and two blade prop both designed for and tested on the Europa..
A two blade AP420 with Sensenich Blades vs. three blade AP332 with Warp Drive Blades non tapered. Engine 914, Aircraft Europa XS Trigear.
First, at cruise the Rotax only turns nominally 2050 RPM prop speed and the prop length is limited to 64 inches, so the tip compression or mach whack noises are minimized. The limited cruise RPM really degrades the performance of a propeller. The gear box limit of 2.43 reduction imposes a problem in cruise, but allows longer blades and the ability to deliver more torque to a prop. In essence, the slow prop shaft RPM and limited length means the prop angle at cruise must be increased to absorb the torque of the engine. The higher angle of attack of the blade makes for some interesting problems for the blade designer. Takeoff, vs. climb performance vs. cruise performance will be significantly different conditions and design criteria for the blades and the downwash off the blades as they pass the cowl are different.
The next thing is that the area of the blades must be near equal for proper comparisons.
Finally, the Europa thrust line has a near zero angle at cruise, but nearly 8 degrees during initial climb at max climb speeds of 65 and 75 for angle and rate.
Comment: Quality propeller blade manufacturers have very consistent mass balance and airfoil sections blade to blade, so vibrations due to balance are minimal. Hand cut or custom props, or defective props (yes we had one Sensenich go out of balance due to an internal balloon failure) must be sorted out. The slightest profile difference makes a difference in both noise and vibration.
The two blade pulses, due to AOA during climb, does give a change in sound outside the aircraft as well as inside. The power pulses of each blade passing through the windshield arc allows the two blade to make an audible (somewhat irritating) pulse across the windshield and cowl face.
The three blade prop increases the frequency of the power pulses and smooths out the pulses affects and although the decibels aren't terribly different, the noise (what is irritating to the ear) is less for the three blade. Tapered tips are less noisy than square tips. Cutoff tips give a sharp tip sound when compared to a swept tip. Swept tips have lower initial inertia and lower tip drag at higher prop speeds.
At or near cruise, this pulsing noise is diminished significantly at the shorter blade lengths. Long blade lengths tend to be noisier due to their effect on more of the aircraft, most noticeably is the windscreen pulsing noise transferred into the cockpit and to your ears.
On tests with the 76 inch long blades, the two blade is very loud in comparison, diminishing with a shortening of the blade length.
The 76 inch long two blade requires ANR headsets for comfort, and the windscreen in the Rans and Kitfox actually moves like a drum as the blade passes. The two blade at the long lengths is faster on top end as I approached the aircraft's VNE. High altitude performance was a bit better with the two blade also. This is, in my opinion, not not due to the differences in two vs three blade as much as the difference in blade areas, thickness and taper plus the slight advantage in efficiency of any two blade over a three blade (remembering the most efficient prop is a single blade). The Sensenich blades are thicker and wider of chord on the longer blades. The Warp Drive blades of that length were tapered tips because of the very long length and the difference in rotational inertia. We went to the wide chord blade on the 332 at 76 inches (not good for the sprag clutch on the Rotax with its higher inertia on start) but it still was a bit slower at top end and had only a tiny decrease in static thrust than the 76 inch long Sensenich blades on the 420.
Tip design also has an effect. A swept tip tends to be quieter on the very long props, but is less effective on the shorter props. A number of designers have toyed with better blade designs but the problem is each experimental is different. What works on a Vari Eze is not going to work for a Ran's or Europa even with the same engine...
I talked with Steve and Mike at Sensenich about the 64 inch two blade, but they had to admit, it isn't working as well as they would like. The twist, area profile, taper and airfoil section have got to be tweaked to get the most out of the Europa/914 combo. How many blades will we sell to pay for all the tweaking and testing that comes into the blade manufacture equation. Yes, mass produced blades must operate efficiently but also sell. Right now the Sensenich market is in the LSA market which doesn't need all that tweaking because they only go 120 Knots. We in the Europa commuity are looking for 150 Knots at 10,000, which is a totally different blade design. Not that the casual observer would notice the difference, but to those of us flying efficient glass aircraft, we notice the difference. Again, I am not getting into whose manufactured prop is better, because tests have to be done on the same aircraft, same CG, same conditions to be valid. My Europa is significantly faster (15 knots) than another XS in the shop. Same airplane, landing gear, engine, and prop, just different in oh so many little ways... CG, wheel pants, cowl seals, door fit, trim of the aircraft, flap droop, wing gap seals, engine isolation mount age, etc.
Another area of vibration is the wind angle during taxi, compression braking with the prop at high speed, resonance effects, Rotax gearbox (straight cut verses taped cut). There are certain aircraft where the vibration of the prop in one, or all of the above is quite irritating. The Warp Drive, does drive me nuts during taxi with a quartering tail wind as my engine /prop combo sounds terrible during taxi and if I dive into the pattern with the prop at cruise (5000) at 130 Knots and lower the power setting further, I can feel the prop and gearbox lash and rattling noise. Entering the pattern at "Takeoff" setting diminishes that as does entering the pattern at lower speed.
Pusher designs have noticeable differences from the tractor types due to air flow disturbance across the blades, especially if a tail boom is below the prop. Even the addition of an augmenter exhaust to only one side of the aircraft makes a difference in feel.
In my summary to Airmaster, I saw no difference in performance between the AP332 vs the AP420 in the Europa (64 inch prop length) but a noticeable difference in the longer 76 inch blades on the Kitfox / Rans S6 aircraft. The two blade was lighter, easier to get the cowl off and on, and a bit noisier on the Europa. Longevity of the blades depends on how much grass you intend to mow.
Have a great weekend,
I'm off to the shop.
Bud Yerly
