Nonsense (WAS Airplane Building and Flying)
Deems Davis
PostPosted: Mon Jun 18, 2012 10:54 am    Post subject: Nonsense (WAS Airplane Building and Flying) Reply with quote
How about them Red Sox!!!
On Mon, Jun 18, 2012 at 11:40 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
It certainly does slow the build process but not as much as a permanent mount and an approriate gun sight for those pesky Cessnas in the pattern.
"switchin to guns"
dmaib@me.com
PostPosted: Mon Jun 18, 2012 12:01 pm    Post subject: Re: Nonsense (WAS Airplane Building and Flying) Reply with quote
Thanks Deems. I was beginning to think I had inadvertently logged on to something other than an RV-10 forum. Confused
BTW, did you see my info on VAF about the leaking Newton fuel caps? It seems that I've found the fix. New o ring for the center shaft of the cap mechanism. This requires taking the cap apart, and unless you have, or can fashion, a tool to get the red piece off without damaging it, will also require a new red piece.
Contact Robin Voice at Newton SPRL http://www.newtonsprl.co.uk/index.html and he will send you the parts. He is going to be at Oshkosh next month and will bring some parts with him, if you are planning to attend.
David Maib
RV-10 #40559
New Smyrna Beach, FL
Kellym
PostPosted: Mon Jun 18, 2012 12:37 pm    Post subject: Nonsense (WAS Airplane Building and Flying) Reply with quote
Sounds like Heat and Thunder to me after them Spurs and Celtics ran out of gas.
On 6/18/2012 11:53 AM, Deems Davis wrote:
[quote]How about them Red Sox!!!
"switchin to guns"
Kelly McMullen
KCHD
dlm34077(at)q.com
PostPosted: Mon Jun 18, 2012 1:13 pm    Post subject: Nonsense (WAS Airplane Building and Flying) Reply with quote
Maybe we that already have 500+ in our RV10s should leave the list. But you were the innovator in the owner generated mods?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: Monday, June 18, 2012 11:53 AM
Subject: Re: Re: Nonsense (WAS Airplane Building and Flying)
"switchin to guns"
dlm34077(at)q.com
PostPosted: Mon Jun 18, 2012 1:25 pm    Post subject: Nonsense (WAS Airplane Building and Flying) Reply with quote
Just got the N number reservation for the RV9A in the mail today so will be an infrequent poster in the future.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: Monday, June 18, 2012 2:13 PM
Subject: RE: Re: Nonsense (WAS Airplane Building and Flying)
"switchin to guns"
