Show us your panels !
stephen vestuti
PostPosted: Sun Jun 03, 2012 6:16 am    Post subject: Show us your panels ! Reply with quote
Come on , lets see some of your panels, the iPad mount posting has got me wanting to see more, don't forget to talk about some of the instruments !
Steve.
rlborger(at)mac.com
PostPosted: Sun Jun 03, 2012 8:50 am    Post subject: Show us your panels ! Reply with quote
Steve,
FWIW:
Main panel, top row, left to right: Trim Indicator, EL Instrument Lighting control, 4 stand-by instruments; TruTrak Turn Coordinator, Altitude, Airspeed, Vertical Speed.
Row of lights, left to right: Hi/Lo Volt Warn (Yellow), EIS Warn (Red), 2 turbo warn lights (Orange & Red)
Just below the Volt Warn lamp is the press-to-test for the volt warn system.
Big screen is a Grand Rapids Technology Sport EFIS. To the left of the Sport is a USB port feeding the Sport. And an On/Off switch for the Sport as required by GRT.
Switch & Fuse panel, left to right: Master Switch (Red), A & B Ignition (Blue), Starter (Yellow), Starter Engaged Lamp (Yellow), Fuel Boost Pump (Green), Nav Lights (White), Strobes (White) & Instrument Lights (White). Then two rows of circuit breakers. The breaker with the Red Ring is for the trim. There is also a keyed switch that prevents anything working.
Recess between the panels: TCU Emergency Off Switch - Red Guard in the ON position & a 12 volt DC outlet.
Right panel, top to bottom: Air Gizmo mount & Garmin 396, Microair 760 Radio and Microair Transponder, GRT EIS 4000 for Rotax, UMA Differential Pressure Gage, Controls for the Airmaster Prop.
On top of the instrument panel are GPS antennas for the GRT Sport and the 396. Behind the iPad mount, in the corner of the shelf, is the XM Weather Antenna/Receiver for the 396.
I have not flown with this panel yet. Still trying to get the 914 running properly after a year of down time.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Steve.
http://forums.matronics.com/viewtopic.php?p=374578#374578
 Filesize:  127.69 KB
 Viewed:  8239 Time(s)
Fred Klein
PostPosted: Sun Jun 03, 2012 9:08 am    Post subject: Show us your panels ! Reply with quote
instruments !
Steve,
Photo below shows my effort to KIS and visually serene...still a work
in progress...instruments include the Dynon Skyview, UMA 2.25 ALT and
ASI backups, Gizmo for Garmin X96; small green screen is EMS
compatible w/ programmable ECU; space for ICOM 210 & xponder. I
extended the valence over the nav panel in an effort to enhance
visability of GPS screen; increased the size of the lip to conceal a
36" length of red LEDs for panel illumination.
Am considering mounting an iPad directly on the top of the control
stick...LOL...
Fred
 Filesize:  62.91 KB
rholder(at)avnet.co.uk
PostPosted: Sun Jun 03, 2012 9:43 am    Post subject: Show us your panels ! Reply with quote
This "old thing" on G-OWWW, does me, for now !
The ammeter and voltmeter sit on a sub panel which stays
in the aircraft when the panel is slid out. The space
neatly avoids the brake and throttle levers.
Richard
 Filesize:  195.72 KB
rparigoris
PostPosted: Sun Jun 03, 2012 10:22 am    Post subject: Show us your panels ! Reply with quote
Hi Richard
Thx. for sharing your panel with us.
Can you explain or show a shot of the other side of the red rubber band and steel? I imagine it clamps somehow onto the rudder pedals.
Another question, what is the T handle for by the choke? If not a parking brake can you explain your plumbing and routing of air.
Last question, it looks like you have some kind of paint protector for the door shoot bolt hole (port front). How does it work, what did you use?
Thx.
Ron Parigoris [quote][b]
PostPosted: Sun Jun 03, 2012 11:23 am    Post subject: Show us your panels ! Reply with quote
The red rubber band and steel is the control lock. The
other side goes to a "T-piece" that is goes into the
rudder pedals. It actually slides into the hollow pedals
(from between them) The red rubber bands are there as the
cylindrical shape isn't quite aligned with the top of the
stick so helps to keep it in place. UK residents will
recognise the red rubber bands as Royal Mail issue Smile
(Previously enjoyed)
The T handle is for my cowl flap which is behind the
radiators - blanking off the space when it is cold. When
pulled the shaft is marked with green and yellow and red
bands.
Parking brake is in front of the brake levers.
It is a piece of something (I didn't build that bit) maybe
SS, which provides an accurate hole for the shoot bolt and
protects the surrounding fibreglass.
HTH
Richard, ho would really like to be involved designing and
building panels following my logic.
PS, my logic says that every electrical joint is soldered
as crimping is a) a poor mechanical connection and b) a
poor electrical connection Smile Soldering is a very good
mechanical and electrical connection; I just make sure
there is no wicking of solder up the cable by minimising
the amount of solder and holding the joint the right way
when soldering.
[Stands back and waits for incoming flak]
g-iani(at)ntlworld.com
PostPosted: Mon Jun 04, 2012 1:55 am    Post subject: Show us your panels ! Reply with quote
For all of you suffering from "panel" envy.
You will find 33 on the bottom of the page "Building", "Panel and
instrument". This includes the three published this week.
If you would like yours added just put it on the Forum or send a copy direct
to me.
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
raimo.toivio(at)rwm.fi
PostPosted: Tue Jun 05, 2012 2:27 pm    Post subject: Show us your panels ! Reply with quote
-----Alkuperäinen viesti-----
Sent: Sunday, June 03, 2012 10:19 PM
Subject: Re: Show us your panels !
HTH
soldered
b) a
good
sure
minimising
right way
when soldering.
Do agree. I have soldered all the possible joints.
They will last forever.
Raimo
OH-XRT
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
PostPosted: Wed Jun 06, 2012 1:14 am    Post subject: Show us your panels ! Reply with quote
Raimo
Just to make you feel good. I prefer to crimp and solder anything less than
18 gauge.
frans(at)privatepilots.nl
PostPosted: Wed Jun 06, 2012 3:24 am    Post subject: Show us your panels ! Reply with quote
On 06/05/2012 11:46 PM, Raimo Toivio wrote:
Do agree. I have soldered all the possible joints. They will last forever.
Same here. I soldered almost everything. Using proper materials and
operation there is nothing wrong with soldering.
The only caveat is that you MUST protect solder joints from movements.
Judicious use of tie-wraps is the key. Wink
All the internal parts of avionics are soldered as well. I still need to
see the first GPS units where the internal parts are crimped rather than
soldered. Very Happy
Frans
paul.the.aviator(at)gmail
PostPosted: Wed Jun 06, 2012 4:48 am    Post subject: Show us your panels ! Reply with quote
Actually, I crossed over to the "dark side" on this one.  I was initially very skeptical about using crimping, but after doing some research I decided to give it a try.  The airplane has been flying since 2004 and I have not had any issues with crimps.
Just as an aside, a long time I ago I did a class called high reliability soldering.  One of the exercises we did was to cut a cross section of various solder joints and examine them under a metallurgy microscope.  It was quite surprising the number of joints that looked okay were in actual fact crystalline.
Paul
Frans
PostPosted: Wed Jun 06, 2012 7:28 am    Post subject: Show us your panels ! Reply with quote
Ian,
You did it. I feel so good that I will climb to
the roof and scream to the west "you are the best,
Ian".
Cheers, Raimo
Sent: Wednesday, June 06, 2012 11:41 AM
Subject: RE: Show us your panels !
<g-iani(at)ntlworld.com>
Raimo
18 gauge.
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
PostPosted: Wed Jun 06, 2012 7:52 am    Post subject: Show us your panels ! Reply with quote
All
I do for my business and to get some fuel to fly
for example all kinds of outdoor displays. I have
done since 1980 about 500.000 hand soldering
joints by myself. They all are outside in very
hard conditions; humidity 30-100%, sometimes under
water, temp varies -40...+100 (yes - you can fry
an egg there over the black aluminium plate), some
of them are a bit shakeing and so. None of them -
I repeat - none has ever broken. If a soldering
joint is well done, it is so forever. At least
when I complete it (or my wife)!
I wish I had a photo of my "main bus" and "sub
busses". Some of you will got a heart attack if
saw them. Buy your medicine - I will some day show
you.
Is not that strange that in aviation there are
many so old but still valid techs like this (to
crimp)?
For example it is awful that we have fuel in the
cockpit. Think about every Cessna´s or Piper´s
primer or those oil pressure gauges which bring
hot oil over your knees. And sometimes to your
knees. Our fuel filters under our ashes or that
grazy sight gauge. (Thanks Frans - I WILL
ELIMINATE IT ASAP).
Generating heat in a plane is easy to do from the
muffler. That is dangerous. I hate my heating
systems and have that is why a CO-detector. Should
make a heater via radiator. Next winter?
We - as an experimentalists - are the sharp point
of the development. Let´s be brave and do our job
as well as we can.
Of course I do understand: old way is usually more
safe than a pack full of new but not so much
experienced way.
Still, some habits should change - let us step
down from the elephant´s bone tower...
Raimo
Finland
OH-XRT
Sent: Wednesday, June 06, 2012 3:15 PM
<frans(at)privatepilots.nl>
Frans
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
graeme bird
PostPosted: Mon Jun 11, 2012 11:19 am    Post subject: Re: Show us your panels ! Reply with quote
Here is a my very simple panel,. Sorry no carpet, no leather. The base model. Ventrui AI and DI, Area 500 gps, iphone memorymap.
The middle panels can be removed and all instruments and fuse panel and wiring accessed without taking out the whole console.
I am already changing it, taking out the rotax tacho and clock and putting in the CS prop controller.
 Filesize:  363.06 KB
 Viewed:  8094 Time(s)
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
