flight surfaces control lock
benson.barry(at)gmail.com
PostPosted: Mon May 21, 2012 6:05 am    Post subject: flight surfaces control lock Reply with quote
Has anyone developed an inside cabin flight surfaces control lock that uses the control stick and rudder pedals to hold both the rudder and ailerons in a safe and secure position during high winds when airplane is tied down outside? I am picturing in my mind a control lock similar to the kind used in Mooneys -- the York Loc . Thanks, Barry
merlin
PostPosted: Mon May 21, 2012 6:34 am    Post subject: flight surfaces control lock Reply with quote
I don't see any need for the Rudder lock since the weight on the nose wheel prevents the rudder from moving on the ground.
JW
Sent: Mon, May 21, 2012 10:12:35 AM
Subject: flight surfaces control lock
PostPosted: Mon May 21, 2012 1:45 pm    Post subject: flight surfaces control lock Reply with quote
Thanks for getting back to me.  I really appreciate it.  I guess the only thing needed then is to secure the control stick, which can be done with the seat belt.  Thanks again, Barry
On Mon, May 21, 2012 at 10:34 AM, JEFFREY WEBB <cw4jasper(at)bellsouth.net (cw4jasper(at)bellsouth.net)> wrote:
[quote]I don't see any need for the Rudder lock since the weight on the nose wheel prevents the rudder from moving on the ground.
JW
From: Barry Benson <benson.barry(at)gmail.com (benson.barry(at)gmail.com)>
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
tp://forums.matronics.com
klondike(at)megalink.net
PostPosted: Mon May 21, 2012 3:09 pm    Post subject: flight surfaces control lock Reply with quote
not true in high winds
merlin
PostPosted: Mon May 21, 2012 4:02 pm    Post subject: flight surfaces control lock Reply with quote
That may be true and then even a rudder pedal lock wouldn't do the trick. In that case I would probably use some sort of external control lock on the rudder itself.
JW
Sent: Mon, May 21, 2012 7:10:08 PM
Subject: Re: flight surfaces control lock
--> Zenith601-List message posted by: "fritz" <klondike(at)megalink.net (klondike(at)megalink.net)>
bryanmmartin
PostPosted: Mon May 21, 2012 4:14 pm    Post subject: flight surfaces control lock Reply with quote
I cut a piece of polyethylene foam that fits around the stick to prevent side to side motion and a short piece of nylon rope with a couple of "S" hooks to hold the stick forward against the foam block.
On Mon, May 21, 2012 at 10:34 AM, JEFFREY WEBB <cw4jasper(at)bellsouth.net> wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus re-drive.
Bryan Martin
do not archive.
PostPosted: Mon May 21, 2012 8:11 pm    Post subject: flight surfaces control lock Reply with quote
Bryan, The foam block idea is interesting.  BB
On Mon, May 21, 2012 at 8:12 PM, Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)> wrote:
[quote]--> Zenith601-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)>
Bryan Martin
N61BM, CH 601 XL,
st" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
http://forums.matronics.com
le, List Admin.
DaveG601XL
PostPosted: Tue May 22, 2012 8:12 am    Post subject: Re: flight surfaces control lock Reply with quote
Barry,
I don't tie my 601XL down very much outside, but when I do, such as at Oshkosh, I use a ratchet strap. It hooks from one rudder pedal on the right to another on the left with a loop around my center control stick. It is a little clumsy to put on, but I only do it once in a great while, so I don't mind it. The only picture I could find was one I took a Oshkosh, but it only shows where it loops around the stick.
Good luck,
 Filesize:  182.43 KB
 Viewed:  11897 Time(s)
David Gallagher
Cincinnati, OH area
PostPosted: Tue May 22, 2012 10:02 am    Post subject: flight surfaces control lock Reply with quote
Thanks, Dave.  Regards, Barry
On Tue, May 22, 2012 at 12:12 PM, DaveG601XL <david.m.gallagher(at)ge.com (david.m.gallagher(at)ge.com)> wrote:
[quote]--> Zenith601-List message posted by: "DaveG601XL" <david.m.gallagher(at)ge.com (david.m.gallagher(at)ge.com)>
Barry,
Good luck,
David Gallagher
Zodiac 601 XL-B: flying, 200+ hours now
Next project under construction: Aircamper
http://forums.matronics.com/viewtopic.php?p=373575#373575
http://forums.matronics.com//files/2009flightline_28_107.jpg
le, List Admin.
wood23(at)sasktel.net
PostPosted: Tue May 22, 2012 10:24 am    Post subject: flight surfaces control lock Reply with quote
I suffered considerable damage to ailerons and rudder last summer when a 70 mph wind caught my plane from behind. The rudder damage was probably caused due to the tail tie down pulling out. I had been using the bungee cord control stick tie down method for a number of years but the wind from behind shredded the aileron at the control horn on both sides.
The control surfaces have been rebuilt and as the aircraft is tied down out side I wanted a gust lock that didn’t put a load on the aileron at the control horn. My solution was to make a frame from PVC pipe that fits into the gap at the wing tip. I tried attaching a photo, hope you can see it. Another PVC pipe gust lock is attached to the elevator.
For the rudder I’m relying on ratchet straps and better ground stakes.
If anybody's interested I can get more pictures of the gust locks next time out to the airport.
Ron Wood
C-FJFH CH 601 HDS
Stratus Subaru
 Filesize:  330.64 KB
 Viewed:  11886 Time(s)
PostPosted: Tue May 22, 2012 2:25 pm    Post subject: flight surfaces control lock Reply with quote
not a good way to do it.
PostPosted: Tue May 22, 2012 2:32 pm    Post subject: flight surfaces control lock Reply with quote
you'd be smart to listen to this guy (Ron Wood)--- he knows what he is
talking about.
garybuster(at)hotmail.com
PostPosted: Tue May 22, 2012 4:22 pm    Post subject: flight surfaces control lock Reply with quote
Sent from my Verizon Wireless Phone
Ron Wood
C-FJFH CH 601 HDS
Stratus Subaru
paulrod36(at)msn.com
PostPosted: Wed May 23, 2012 9:34 am    Post subject: flight surfaces control lock Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I'd be very concerned about wedging something in the space under the aileron as a gust lock. I've seen people use two flat pieces of wood, 6 to 8 inches long, with a non-skid facing, at top and bottom of the aileron-flap gap, holding it all together with a threaded rod and a couple of wing nuts. It comes apart quickly, and stows in a small bag.
Paul R
PostPosted: Wed May 23, 2012 10:12 am    Post subject: flight surfaces control lock Reply with quote
two thumbs up !!!!!!!!!!!!!!!!!!
