rflick(at)ovalinternet.ne Guest
Posted: Wed May 16, 2012 3:37 pm Post subject: fuel system |
hello i have a 601 hds with corvair eng and marshal sheibler carb. i may not use header tank due to maybe a problem with wt and bal so can i go from pump into carb without a pressure regulator in stead of pumping to header? also is anyone with the corvair in this plane haveing wt and bal problems? thanks a lot ralph
William Clapp
Joined: 20 May 2007 Posts: 22 Location: Valdosta Georgia
Posted: Wed May 16, 2012 3:49 pm Post subject: fuel system |
Hi Bill. Call me at 229-834-8996 tonight on your fuel question. Thanks
Bill Clapp
On May 16, 2012, at 7:36 PM, "Bill Flick" <rflick(at)ovalinternet.net (rflick(at)ovalinternet.net)> wrote:
[quote] hello i have a 601 hds with corvair eng and marshal sheibler carb. i may not use header tank due to maybe a problem with wt and bal so can i go from pump into carb without a pressure regulator in stead of pumping to header? also is anyone with the corvair in this plane haveing wt and bal problems? thanks a lot ralph
_________________ Check out my web site - see if I can help you in your dreams.... |
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Wed May 16, 2012 6:59 pm Post subject: Re: fuel system |
I'm finishing up building a 601XL and used the William Wynne book you can find at this link:
http://flycorvair.com/601im.html
I have that carb also and have fuel pump on the firewall feeding the carb no issues but ya gotta use the right pump. The book details these and many other things.
In the book he shows mounting the battery behind the passenger seat which should help with the W/B.
Get the book. it will help.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
BARRY CHECK 6
Posted: Fri May 18, 2012 8:55 pm Post subject: fuel system |
Ralph:
What is your safety system if you use an electric fuel pump 100% of the time?
What will happen if:
The battery fails?
What will happen if the pump fails?
Does the Corvair engine have a mechanical fuel pump?
Barry
On Wed, May 16, 2012 at 7:36 PM, Bill Flick <rflick(at)ovalinternet.net (rflick(at)ovalinternet.net)> wrote:
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
