N127ZP Europa Monowheel Classic Kit#12 FLYS!
jeffrey-j-paris(at)excite
PostPosted: Wed May 16, 2012 4:51 am    Post subject: N127ZP Europa Monowheel Classic Kit#12 FLYS! Reply with quote
Hello Europaphiles,
Yesterday I flew N127ZP! A Jabiru powered 3300 Europa Monowheel Classic build kit #12 at Williamson- Sodus Airport KSDC. The airplane flew beautifully! Unfortunately, I had some engine issues and upon landing my engine seemed to have seized up. In hindsight possibly due to the gear up failure last June which resulted in a prop strike during run-up testing may have finally figmented itself into a real problem under flight loads: But better it happened on the ground than in the air!
Although under great duress and stress to get down quickly, the airplane flew as advertised, my adrenaline rush made my first solo monowheel landing a thing of beauty or so I am told by my ftest flight crew. Well I have the engine off the airplane to be sent back for inspection and probably a major tear down and I will have to sort out some issues with the engine airframe combination before I get N127ZP back in the air again.
Living Experimental Aviation to the fullest...
Cheers,
Jeff Paris
Macedon NY
 Filesize:  361.81 KB
 Viewed:  3545 Time(s)
ivanshaw(at)btinternet.co
PostPosted: Wed May 16, 2012 5:20 am    Post subject: N127ZP Europa Monowheel Classic Kit#12 FLYS! Reply with quote
Congratulations.
Sounds like you had an exciting first flight.
Kindest Regards
Ivan
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jeffrey J Paris
Sent: 16 May 2012 13:50
Subject: N127ZP Europa Monowheel Classic Kit#12 FLYS!
Hello Europaphiles,
Cheers,
Jeff Paris
Macedon NY
rlborger(at)mac.com
PostPosted: Wed May 16, 2012 7:12 am    Post subject: N127ZP Europa Monowheel Classic Kit#12 FLYS! Reply with quote
Jeff,
Congratulations on the first flight. Good luck with the engine issues.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On May 16, 2012, at 7:50 AM, Jeffrey J Paris wrote:
Hello Europaphiles,
Cheers,
Jeff Paris
Macedon NY
<IMG_3738.jpg>
stephen vestuti
PostPosted: Thu May 17, 2012 8:31 am    Post subject: Re: N127ZP Europa Monowheel Classic Kit#12 FLYS! Reply with quote
Jeff,
well done and happy flying,
Steve.
