Chevy Volt electrics
mrspudandcompany(at)veriz
PostPosted: Thu May 10, 2012 10:41 am    Post subject: Chevy Volt electrics Reply with quote
Here is an article on how the Chevy Volt electrical system is put together.
Some on the list may be interested.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  2 MB
 Downloaded:  507 Time(s)
PostPosted: Thu May 10, 2012 4:09 pm    Post subject: Chevy Volt electrics Reply with quote
Didn't see either a link or an attachment.
Can you re-send?
henador_titzoff(at)yahoo.
PostPosted: Thu May 10, 2012 5:32 pm    Post subject: Chevy Volt electrics Reply with quote
I tried opening the winmail.dat file with Word, Adobe PDF Reader, EditPlus, Notepad and one more program, but none worked; therefore, I tried the last resort:
1. Saved winmail.dat to the desktop
2. Went to http://www.winmaildat.com/
3. Clicked on Choose File to choose what file I wanted to convert. I chose winmail.dat
4. Clicked on Send file to send winmail.dat to the converter
5. Clicked on the extracted file (PDF), which is right below the winmail.dat uploaded file
6. Selected Keep and where to put it when the browser offered
 7. Go to save location and open with your favorite PDF reader
The file appears to be legit. I'm gonna attach it to this email, though, so everyone doesn't have to do the above.
Henador Titzoff
Sent: Thursday, May 10, 2012 8:05 PM
Subject: Re: Chevy Volt electrics
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Can you re-send?
ectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List========================<brsp; &=======================
Teardown_reveals_Chevy_Volt_s_electronic_secrets_PDF.pdf
 Filename:  Teardown_reveals_Chevy_Volt_s_electronic_secrets_PDF.pdf
 Filesize:  1.99 MB
 Downloaded:  1775 Time(s)
PostPosted: Thu May 10, 2012 5:55 pm    Post subject: Chevy Volt electrics Reply with quote
Can you re-send?
My return of the posting showed it with an openable
attachment. Here is a link also:
http://www.edn.com/article/521722-Teardown_reveals_Chevy_Volt_s_electronic_s
ecrets.php?cid=Newsletter+-+EDN+Weekly
Roger
winmail.dat
 Filesize:  3.84 KB
 Downloaded:  511 Time(s)
PostPosted: Thu May 10, 2012 7:33 pm    Post subject: Chevy Volt electrics Reply with quote
Can you re-send?
Thanks! The link wraps so a bit fussy for cut-n-paste.
Here's a tinyurl
http://tinyurl.com/6vnhyox
Bob . . . [quote][b]
Allen Fulmer
PostPosted: Thu May 10, 2012 8:11 pm    Post subject: Chevy Volt electrics Reply with quote
For what it’s worth the original attachment worked for me.
Allen Fulmer
RV7
_____________________________________________
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of ROGER & JEAN CURTIS
Sent: Thursday, May 10, 2012 1:32 PM
Subject: Chevy Volt electrics
Here is an article on how the Chevy Volt electrical system is put together. Some on the list may be interested.
<< File: 26349-Teardown_reveals_Chevy_Volt_s_electronic_secrets_PDF[1].pdf >>
Roger [quote][b]
RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL
lists(at)stevet.net
PostPosted: Fri May 11, 2012 5:10 am    Post subject: Chevy Volt electrics Reply with quote
The winmail.dat file is a proprietary file produced by Microsoft Outlook. Outlook is the only program that can open it. If you use any other mail program, you're kinda outta luck. There are some programs that will interpret it. The Outlook user that sent this file should change the settings in Outlook to attach native files rather than the winmail.dat file.
Steve Thomas
Roger
<winmail.dat>
PostPosted: Fri May 11, 2012 6:27 am    Post subject: Chevy Volt electrics Reply with quote
Steve Thomas
Can you point me in the right direction to change my Outlook
to send native files? I can't seem to find it in the help files.
Roger
winmail.dat
 Filesize:  3.55 KB
 Downloaded:  538 Time(s)
lists(at)stevet.net
PostPosted: Fri May 11, 2012 7:38 am    Post subject: Chevy Volt electrics Reply with quote
I switched to Mac a number of years ago and haven't used Outlook in just as long. I don't remember where to find that setting. I'm sure that there must be some Outlook users out there that can help. But I do know that there is a setting where you can switch that "feature." Also, if you are connected to a Windows server using Exchange, the setting may be at the Exchange level.
Any windows experts out there?
Steve Thomas
Steve Thomas
Roger
<winmail.dat>
rob(at)hyperion-ef.com
PostPosted: Fri May 11, 2012 10:15 am    Post subject: Chevy Volt electrics Reply with quote
All is explained at: http://support.microsoft.com/kb/138053
Best regards,
Rob Housman
Irvine, California
Europa XS
Rotax 914
S/N A070
Airframe complete
Avionics soon
Sent: Friday, May 11, 2012 7:26 AM
Subject: RE: Chevy Volt electrics
Steve Thomas
      Can you point me in the right direction to change my Outlook to send native files? I can't seem to find it in the help files.
      Roger
Bob McC
Roger;
According to Microsoft, this problem arises (automatic conversion to .dat files) when you try to send e-mails in “rich text format”. Their solution is to use either “plain text format” or “HTML format”. Different versions of Windows and Outlook make these selections differently, but on my combination there is a selection box on the toolbar where the “send” button is located which allows me to make that distinction. Your e-mails have always looked different than everyone else’s on my computer and this may be why. In typing this response my computer automatically selected “rich text” because that is the format of your original. That would seem to lend credence to Microsoft’s explanation. I’ve changed this reply manually to “HTML” because that’s what I normally use for e-mail.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ROGER & JEAN CURTIS
Sent: Friday, May 11, 2012 10:26 AM
Subject: RE: AeroElectric-List: Chevy Volt electrics
Steve Thomas
Roger
Bob McC
Falco #908
(just starting)
PostPosted: Fri May 11, 2012 11:06 am    Post subject: Chevy Volt electrics Reply with quote
Best regards,
Rob Housman
Roger;
Bob McC [quote]Thanks Rob & Bob, I will start using only HTML!  Not sure why I got into the habit of using Rich Text but if changing to HTML will solve the problem, I’m all for it.  â˜ș  â˜ș                Roger[b]
Kellym
PostPosted: Fri May 11, 2012 12:21 pm    Post subject: Chevy Volt electrics Reply with quote
The better choice for most email is plain text. Every email program
handles it cleanly, the file size is kept to a minimum. Many listservs
will automatically strip HTML from a message, leaving you shooting blanks.
Best regards,
Rob Housman
*Roger;*
*According to Microsoft, this problem arises (automatic conversion to
because that’s what I normally use for e-mail.*
*Bob McC*
Thanks Rob& Bob,
Roger
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
tonybabb(at)alejandra.net
PostPosted: Fri May 11, 2012 10:27 pm    Post subject: Chevy Volt electrics Reply with quote
In Outlook 2010 there appear to be two places that might affect this. In Outlook go to File/ Options
You’ll see this:
Scroll down a bit further and you’ll see this, look under “Message Format”:
Tony
Velocity SEFG 62% done, 78% to go
www.alejandra.net/velocity
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com] ([email][mailto:owner-aeroelectric-list-server(at)matronics.com][/email]) On Behalf Of Bob McCallum
Sent: Friday, May 11, 2012 11:14 AM
Roger;
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com] ([email][mailto:owner-aeroelectric-list-server(at)matronics.com][/email]) On Behalf Of ROGER & JEAN CURTIS
Steve Thomas
Roger
[b]http://www.matronics.com/Navigator?AeroElectric-List
 Filesize:  19.35 KB
 Viewed:  7737 Time(s)
 Filesize:  79.38 KB
