rickofudall
Posted: Wed May 02, 2012 10:01 am Post subject: Hour meter ground |
I have finished all the wiring of using Z-17 for a Rotax 582 powered LSA. The last thing I have is to install is the hour meter. It's a Westach 2C10-2 that I want to run off the AC side of the voltage regulator. Can I use the instrument panel ground bus or should I give it its own ground. Should I put a diode on the instrument panel ground? Should I use a shielded wire for the power connection?
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Wed May 02, 2012 10:17 am Post subject: Hour meter ground |
At 12:56 PM 5/2/2012, you wrote:
| Quote: | I have finished all the wiring of using Z-17 for a Rotax 582 powered
If you run it directly off the two AC wires from
the PM alternator. No grounding necessary. No shielding
necessary. Don't the instructions for it describe
an AC connection?
rickofudall
Posted: Wed May 02, 2012 11:47 am Post subject: Hour meter ground |
Bob, Yes, as you can see they show one side of the AC leg going to ground.
Rick
On Wed, May 2, 2012 at 1:14 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | I have finished all the wiring of using Z-17 for a Rotax 582 powered LSA. The last thing I have is to install is the hour meter. It's a Westach 2C10-2 that I want to run off the AC side of the voltage regulator. Can I use the instrument panel ground bus or should I give it its own ground. Should I put a diode on the instrument panel ground? Should I use a shielded wire for the power connection?
an AC connection?
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
143.51 KB |
3181 Time(s) |
Bob McC
Posted: Wed May 02, 2012 4:23 pm Post subject: Hour meter ground |
Not exactly. Read the Note on the drawing you provided. They say IF one leg of the AC is grounded then pin 5 should go to the grounded leg. It doesn’t say that it should be grounded, only that if it is then pin 5 is the grounded pin.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Wednesday, May 02, 2012 3:46 PM
Subject: Re: AeroElectric-List: Hour meter ground
Rick
an AC connection?
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
_________________ Bob McC
Falco #908
(just starting) |
rickofudall
Posted: Wed May 02, 2012 7:14 pm Post subject: Hour meter ground |
Thanks, Bob, I didn't catch the note.
Rick
On Wed, May 2, 2012 at 7:21 PM, Bob McCallum
<robert.mccallum2(at)sympatico.ca>wrote:
[quote] ** ** **
*Not exactly. Read the Note on the drawing you provided. They say IF one
the grounded pin.*
*Bob McC*
*From:* owner-aeroelectric-list-server(at)matronics.com [mailto:
owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Richard
Girard
*Sent:* Wednesday, May 02, 2012 3:46 PM
*To:* **aeroelectric-list(at)matronics.com**
*Subject:* Re: Hour meter ground****
Posted: Wed May 02, 2012 8:15 pm Post subject: Hour meter ground |
At 02:46 PM 5/2/2012, you wrote:
| Quote: | Bob, Yes, as you can see they show one side of the AC leg going to ground.
Rick
Hmmm . . . separate winding for the tachometer. Your
AC power to the rectifier/regulator cannot be grounded
on one side so that you can have full-wave rectification.
This tach coil is a very low power source. Do you have
an electronic tach reading this output too? In any case,
exactly where it grounds (if at all) is of little
consequence. These two systems are neither potential
antagonists nor victims. Does your tach wiring call out
grounding of one side of the signal wire?
rickofudall
Posted: Thu May 03, 2012 6:30 am Post subject: Hour meter ground |
On Wed, May 2, 2012 at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
The tach has its own signal wire. None of the Rotax wiring diagrams for the various regulators has an AC going to ground. As pointed out, the note on the drawing for the hour meter says if one of the AC feed wires is grounded that wire is used for pin 5 on the meter. Otherwise the two AC wires feed the meter and it makes no difference which goes to the meter connections. |
Rick
Rick
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
