Gretz Pitot & Aileron Trim
fritzsch(at)eskimo.com
PostPosted: Wed Apr 25, 2012 3:06 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
Two questions:
1. Where have you mounted the Gretz control module? Ideally it would
be mounted so that the face of the wire connecting block and the screws
that hold the wire in place would be easily accessible from the
inspection opening. The location of the three attachment points on the
module make that a little difficult. I have placed the head mount in
the position called for by the plans. Access would seem to dictate
that it be mounted on the inspection hole side (outboard side) of the
rib with the pitot mount on the inboard side of the rib, but I can's
seem to find a position that would make both the connecting face and the
screws on the module easy to see and tighten.
2. It would appear to be much easier to install the aileron trim before
the bottom skin was attached. But as I read the instructions for the
trim servo, it looks like one has to wait until the ailerons are
attached to the wings and possibly the wings are attached to the
airplane. Is that correct?
Dave
Dave Fritzsche
40813
Puyallup, WA
Wings
rene(at)felker.com
PostPosted: Wed Apr 25, 2012 3:54 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
I mounted my Gretz control module to the inspection plate. Easy and
accessible.
I did my Aileron trim after the wing was on the airplane....but I think you
could do it after the bottom skin was on but before you put the wing on the
airplane.
Rene' Felker
N423CF
801-721-6080
carl.froehlich(at)verizon
PostPosted: Wed Apr 25, 2012 4:29 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
You can of course fit up the aileron trim servo mount onto the inboard left
wing inspection plate. You cannot fit the aileron trim spring attachments
to the aileron push tube until after the wings are on and the control
surfaces are rigged. The aileron push tube needs to first be correct,
"stick centered" position to determine where to put the spring attachments.
Remember that the push tube is easily removed via the wing tip once you mark
where the attachments go.
Carl
Pitot static test completed today - trying to get the FSDO out the first
week in May.
bwestfall
PostPosted: Wed Apr 25, 2012 6:10 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
I thought it would be easier to install the gretz using molex connectors for
the wires so I mounted the assembly just inside of the wing rib inside the
inspection plate. I split the wires leading from the pitot to the control
unit and added appropriately sized molex connector. The thought being that
installing the pitot is just a matter of snapping the molex connector tight
instead of trying to work those little screws while upside down.
Not flying yet so as to effectiveness and reliability.... WAG.
Ben Westfall
40579
Portland, OR
 Filesize:  102.12 KB
 Viewed:  2553 Time(s)
mara(at)leasenet.net
PostPosted: Wed Apr 25, 2012 7:16 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
Dave, I don't normally post but I think my installation worked out well.
I have posted three different views. I would not place the controller
outboard of
the rib. The two AN3's are easily reached thru the access cover.
Ron Mara
Addison, Texas
 Filesize:  2.18 MB
 Viewed:  2549 Time(s)
 Filesize:  2.11 MB
PostPosted: Wed Apr 25, 2012 7:17 pm    Post subject: Gretz Pitot & Aileron Trim Reply with quote
Sorry, size restriction... here's the third photo.
 Filesize:  2 MB
