tdawson-townsend(at)auror Guest
Posted: Wed Apr 18, 2012 9:52 am Post subject: iPad in the cockipt |
iPad users:
I'm more inclined to have the iPad in the RV-10 cockpit up in front by the dash somewhere, rather than as a kneeboard.
What experience have others had? Is a RAM mount clamped on the edge of the glareshield rigid enough? Other mounting ideas?
N52KS
amekler
Posted: Wed Apr 18, 2012 10:13 am Post subject: iPad in the cockipt |
Tim,
I have mine mounted on the tunnel just in front of the fuel valve.
Alan
On Apr 18, 2012, at 1:51 PM, "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
[quote] iPad users:
N52KS
jeff(at)westcottpress.com Guest
Posted: Wed Apr 18, 2012 10:41 am Post subject: iPad in the cockipt |
Any though given to mounting it to the center post along the windscreen? It could double as a sun visor.
Jeff Carpenter
40304
On Apr 18, 2012, at 11:12 AM, Alan Mekler MD wrote:
[quote]Tim,
Alan
| Quote: | iPad users:
N52KS
href="3D"http://www.matronics.com/Navigator?RV10-List"">http://www.matronics.com/Navigator?RV10-List
href="3D"http://forums.matronics.com"">http://forums.matronics.com
href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
Posted: Wed Apr 18, 2012 11:11 am Post subject: iPad in the cockipt |
That would be perfect dual sun visor iPads when not using the iPad function but needing the visor you just turn on the rear camera and you get forward facing view while still blocking the sun. Patent anyone?
Robin
Sent from the new iPad
On Apr 18, 2012, at 11:49 AM, "Jeff Carpenter" <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote] Any though given to mounting it to the center post along the windscreen? It could double as a sun visor.
Jeff Carpenter
40304
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Apr 18, 2012 11:43 am Post subject: iPad in the cockipt |
I went to recurrent training at flight safety with the Niles owner of rosen visors. He said they were working on iPad visors. The problem I have is not being able to tighten them enough and with the weight of the iPad plus turbulence it might be difficult.
On Apr 18, 2012, at 12:11, Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)> wrote:
[quote] That would be perfect dual sun visor iPads when not using the iPad function but needing the visor you just turn on the rear camera and you get forward facing view while still blocking the sun. Patent anyone?
Robin
| Quote: | Any though given to mounting it to the center post along the windscreen? It could double as a sun visor.
Jeff Carpenter
40304
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
aerosport1
Posted: Wed Apr 18, 2012 11:52 am Post subject: iPad in the cockipt |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Wed Apr 18, 2012 12:00 pm Post subject: iPad in the cockipt |
Plus, having the iPad in the sun causes it to heat up and lock up (won't let you on until it cools down). I think mounting it on the tunnel with an extension that holds it up at the height of an armrest would be best, but I haven't used one mounted to the panel. I think that would be nice as well. I usually use it on the armrest. As a kneeboard it gets in the way of my stick way too much.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Apr 18, 2012, at 3:42 PM, Seano wrote:
[quote]I went to recurrent training at flight safety with the Niles owner of rosen visors. He said they were working on iPad visors. The problem I have is not being able to tighten them enough and with the weight of the iPad plus turbulence it might be difficult.
| Quote: | That would be perfect dual sun visor iPads when not using the iPad function but needing the visor you just turn on the rear camera and you get forward facing view while still blocking the sun. Patent anyone?
Robin
Jeff Carpenter
40304
Posted: Wed Apr 18, 2012 12:07 pm Post subject: iPad in the cockipt |
Saaweeet!
Robin
Jeff Carpenter
40304
aerosport1
Posted: Wed Apr 18, 2012 12:33 pm Post subject: iPad in the cockipt |
Last email did not go thru lets try again.
I have been working on a pop up shelf that will hold a phone under the IPad. I have
had this in the airplane for over a year and really like it. I do not use it
on take off or landing usually. It can be popped up or down very quickly. I am still refining
but getting close.
FWIW
Geoff
Geoff Combs
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
Sent: Wednesday, April 18, 2012 4:06 PM
Subject: Re: iPad in the cockipt
Saaweeet!
Robin
Jeff Carpenter
40304
| Quote: | Tim,
Alan
N52KS
href="3D"http://www.matronics..com/Navigator?RV10-List"">http://www.matronics..com/Navigator?RV10-List
href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/c3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
ics.com
..matronics.com/contribution
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics..com/Navigator?RV10-List
167.29 KB |
8171 Time(s) |
166.07 KB |
8171 Time(s) |
168.02 KB |
8171 Time(s) |
399.8 KB |
8171 Time(s) |
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Wed Apr 18, 2012 4:42 pm Post subject: iPad in the cockipt |
I like that!
I'm using a knee board and it's working well but is less than ideal.
My instrument instructor uses a suction cup on the windshield but I don't see that working for the left seat pilot. Plus I don't like the idea of blocking out any of the view (ironic since no matter where you put it, the time spent looking at it effectively blocks the view).
I'm working on a center console to enclose an O2 bottle. I'm thinking that a hardpoint for a swivel mount that would enable the ipad to hover over my right knee would be ideal. In the end, that position seems best since it doesn't block any instruments and is comfortable for right hand operation.
Bill "old glider guider" Watson
http://youtu.be/JYKubzq9r18
On 4/18/2012 3:11 PM, Robin Marks wrote: [quote] That would be perfect dual sun visor iPads when not using the iPad function but needing the visor you just turn on the rear camera and you get forward facing view while still blocking the sun. Patent anyone?
Robin
johngoodman
Posted: Thu Apr 19, 2012 6:06 am Post subject: Re: iPad in the cockipt |
Isn't there an FAR that prohibits sunvisors that block the view out of the windshield?
Bob Turner
Posted: Thu Apr 19, 2012 4:03 pm Post subject: Re: iPad in the cockipt |
"Isn't there an FAR that prohibits sunvisors that block the view out of the windshield?"
Cessna built 1000's of aircraft with solid (like a car) sunvisors, so I think the answer is "no".
_________________ Bob Turner
RV-10 QB |
