samira.h(at)shaw.ca Guest
Posted: Wed Apr 04, 2012 12:37 pm Post subject: Voltage Regulator Replacement |
Gentlemen (-women),
finally I have received good news from
Zeftronics. They are offering a solid
state voltage regulator (with overvoltage
protection) what might be fit to replace
the obsolete Nanchang and YAK regulator.
For your information I have attached 2
pdf files.
If we get enough interest we could
save some money in placing a
collective/joint order, what do you
think?
cheers
Elmar
 Download |
| Filename: |
G1XX1P,_G2XX1P,_121311.pdf |
90.2 KB |
| Downloaded: |
808 Time(s) |
 Download |
| Filename: |
04042012-Elmar_Hegenauer-G2501P.pdf |
118.99 KB |
| Downloaded: |
1948 Time(s) |
GeorgeCoy
Posted: Wed Apr 04, 2012 1:03 pm Post subject: Voltage Regulator Replacement |
Interesting, I see two problems. First it is only good to 50 amps and our
gernerators are rated higher than that. Second, the 1 off cost is almost as
much as a replacement alternator with regulator.
Posted: Wed Apr 04, 2012 1:34 pm Post subject: Voltage Regulator Replacement |
Actually, there is nothing really wrong with the current Russian design,
and I like it myself because I understand it and can work with it. That
said, this unit would replace the TOTAL current electrical design, to
include not only the voltage pile regulator, but also the over-voltage
unit, along with the 200 "Combined Relay" device, although you might
want to keep the bucking transformer that would still be in there.
Our generators are in fact rated to about 100 amps, so the voltage
regulator described here would not allow the generator to develop full
output. That said, there are not too many people that are going to need
100 amps at 28 volts DC. That is one heck of a lot of current! But,
that's just one small point, there are more important ones to consider.
What you would be left with when doing this conversion would be a
Russian Generator (very old design) with a very modern ... and very
expensive .... control device. As long as the new unit was 100%
reliable with a good reputation for low failure rate, and as long as
Russian generators remain cheap, this might be an alternative worth
considering.
BUT!!!!!
Personally, I have now installed a number of B&C SK-35 and SK-50
alternators. You are looking at about the same price (plus or minus a
little) and you are getting not only a new LS1A voltage regulator, but
you are also getting a brand new 35 or 50 amp alternator. This
alternator is carefully built and balanced and does not have the
complexity of the generator, needing reverse current protection, etc.
Alternators are simply (in my opinion) a superior design as compared to
old generators.
I have no experience on converting CJ designs to B&C alternators, but
for the YAKS, if I am going to pull all this old junk out anyway, I
would strongly prefer the B&C alternators, versus keeping the existing
Russian generator and then using a $975 regulator.
Agreed that the price comes WAY down if you buy a bundle of them.
Just my 2 cents, appreciate the info very much.
Mark Bitterlich
I missed it. What was the cost?
Posted: Wed Apr 04, 2012 1:47 pm Post subject: Voltage Regulator Replacement |
George,
I have some questions regarding
your alternator conversion.
Is it rated for the same ambient
temperature in the engine compartment
as the original generator?
Are the installation costs of the whole
alternator system less than compared
to the replacement of a single voltage
regulator?
Can your alternation conversion be installed
with complying to the rules of authorities
in any other country but the US? Wouldn't
it require expensive LSTCs, e.g. in Canada?
Would your alternator conversion affect
the C of G of the aircraft outside of the
envelope?
Is your alternator solution more
reliable than the original generator?
Could you please post the spec sheet
what stipulates that the YAK 52 generator
has more than 50 Amps output.
Thank you in advance.
cheers
Elmar
GeorgeCoy
I forgot to mention that we have a draft service bulletin that was generated
for Yak Design bureau to "officially" replace the Yak-52 generator system
with the 50 amp alternator and regulator. Also saves about 30 lbs. I can
post a copy if anyone is interested. The Yak design bureau went in to
oblivion just as we were developing this.
Posted: Wed Apr 04, 2012 2:18 pm Post subject: Voltage Regulator Replacement |
I am not George. Sorry. I know that.
However, the original generator is spec'ed to as I remember 3KW output. Take 3000 and divide it by output voltage and that is the maximum current. 100 amps is darn close.
That is only with full cooling air flow applied to the generator. If you do not supply cooling air, rated output drops to about 20-25 amps or so. Specs can be found in any M-14P Operational manual and they are available on-line to anyone that wants to go look.
Interesting question regarding Canada.
Mark Bitterlich
Never mind, I looked them up for you. Here are your specs.
GENERATOR GSR-3000M, SERIES 4 - DESCRIPTION AND OPERATION
2.2. SPECIFICATIONS
Voltage ........................................................ .......................................28.5 V
Power (at 30 V) ................................................ ...................................3 kW
Load current ...............................................................................100 A
Speed of rotation .............................................. ..................................4000 to 9000 r/min
Duty ........................................................... .........................................Continuous
Permissible overloads:
Permissible current at 5000 to 8000 r/min during 1 min ......................150 A
Permissible current at 5600 to 8000 r/min during 5 a ......... ................200 A
Permissible load current without air blowing for 15 min ...... ...............30A
Nominal speed of rotation at load of 100 A and voltage
of 28.5 V with short shunt (without regulator)
when warmed up ............................................... .................................Up to 3600 r/min
Forced cooling is carried out by blowing with on-coming non-heated clean air.
Total air pressure at cooling inlet duct with dynamic
pressure at least 50 mm HnO .......... ...................................................At least 150 mm HpO
Air flow rate at barometric pressure of 760 mm Hg ............................. At least 35 dm /s
Mass ......................................................... ..........................................Up to 11.6 kg
Winding resistance at 20 °C:
Armature winding ............................................. ...................................0.024 ohm_M 0 %
Fie Id winding ................................................ .....................................2.20 ohms^6 %
Interpole winding ............................................ ....................................0.0122 ohm
Brushes:
Make ......................................................... ..........................................MGS-7I
Number ................................................................................................8 pea
Overall dimensions ........................................... ..................................7.2x12x25 mm
Generator offers trouble-free operation when exposed to the following environmental and mechanical
effects:
Relative humidity . ................................................................................Up to 98 %
Temperature variations .......................................................................From minus 60 to 50 °C
brian(at)lloyd.com Guest
Posted: Wed Apr 04, 2012 3:35 pm Post subject: Voltage Regulator Replacement |
On Wednesday, April 4, 2012, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E wrote:
| Quote: | --> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <[url=javascript:;]mark.bitterlich(at)navy.mil[/url]>
considering.
BUT!!!!!
old generators. |
Amen. The advantages of the alternator, i.e. reduced weight, reduced complexity, increased performance, and increased reliability, completely outweigh trying to repair a failed generator system.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Wed Apr 04, 2012 5:19 pm Post subject: Voltage Regulator Replacement |
George
I would appreciate a copy of it please as we are building our
airworthiness. It would be interesting to include such modification in it.
Thanks a lot
Didier
generated
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
cd001633(at)mindspring.co Guest
Posted: Wed Apr 04, 2012 5:53 pm Post subject: Voltage Regulator Replacement |
Hi Elmar,
I installed the B&C K-35 amp Alternator on my CJ-6A (M-14P engine, Whirlwind
Prop) about ten years ago - LOVE it! It comes with the Regulator as Mark
indicated and cost is about $1K for the complete system.
No problem with engine compartment temps. Naturally it was designed to
operate in that temp range.
Removal of old Generator and installing new Alternator took 35 minutes.
Cutting out and throwing away old regulator/filter and wiring another 30
minutes. Installing the Voltage regulator and new wiring including to the
light in cockpit - 3 hours.
Installing the B&C Alternator and Regulator saved a net 27 pounds.
Definitely affected CG... Since I removed about 160 pounds of old radios
from
The compartment behind the rear seat, the Alternator net weight savings
actually helped as I needed to put less Lead weight in the tail cone...
Old generator known to be very reliable - my 10 years with the B&C
Alternator pointing to a similar conclusion...
As to paperwork for the Alternator conversion outside the U.S - I don't
know...
My two cents (5 cents now adjusted for inflation)...
Sam Sax
CJ-6A
Miami, FL
