Converting to externally reg alternator
Goto page 1, 2  Next
fvalarm(at)rapidnet.net
PostPosted: Sun Apr 01, 2012 8:19 pm    Post subject: Converting to externally reg alternator Reply with quote
I have seen it but can't find it right now. Can you point me to an
instruction for converting an internally regulated alternator to external?
Bevan
mrspudandcompany(at)veriz
PostPosted: Mon Apr 02, 2012 3:52 am    Post subject: Converting to externally reg alternator Reply with quote
Bevan
Here is one at the EAA site which might help you.
http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.66 KB
 Downloaded:  850 Time(s)
Eric M. Jones
PostPosted: Mon Apr 02, 2012 5:43 am    Post subject: Re: Converting to externally reg alternator Reply with quote
Eric is easily amused...
try:
http://lmgtfy.com/?q=Converting+to+externally+regulated+alternator
But here is where I will annoy Bob N.: Consider the fact that if automobile alternators had a lower failure rate if they were externally regulated, auto makers would use them. The fact is that BRAND NEW (not rebuilt) Nippon Denso alternators seem to have a nearly-zero failure rate.
Then make your decision. I have had several builders send me their external regulators for examination. This cemented my opinion permanently.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
email(at)jaredyates.com
PostPosted: Mon Apr 02, 2012 5:57 am    Post subject: Converting to externally reg alternator Reply with quote
I think Bob will say that the failure rate is less important than the failure mode. At least that is what I would say.
try:
But here is where I will annoy Bob N.: Consider the fact that if automobile regulators had a lower failure rate if they were externally regulated, auto makers would use them. The fact is that BRAND NEW (not rebuilt) Nippon Denso alternators seem to have a nearly-zero failure rate.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=369828#369828
Ed Anderson
PostPosted: Mon Apr 02, 2012 6:11 am    Post subject: Converting to externally reg alternator Reply with quote
I have been flying over 12 years on a Bosch (rebuilt) alternator with
internal regulator - with no problems. The only downside I can see is that
once it has bootstrapped itself, removing voltage to the field coil does not
stop the output. So if I had a runaway alternator it could theoretically
fry my electronics - on the other hand, in all my life of driving
automobiles and the one or two alternator failures (failed diodes), I've
never had a runaway alternator failure mode.
FWIW
Ed
Edward L. Anderson
Anderson Electronic Enterprises LLC
305 Reefton Road
Weddington, NC 28104
http://www.andersonee.com
http://www.eicommander.com
Sent: Monday, April 02, 2012 9:43 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Re: Converting to externally reg alternator
try:
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com
PostPosted: Mon Apr 02, 2012 6:35 am    Post subject: Converting to externally reg alternator Reply with quote
failure rate.
Eric,
I believe that perhaps Bob does agree with you, in that the
internally regulated alternator has "nearly-zero" but NOT ZERO failure.
Apparently there have been some cases of catastrophic over voltage with no
way to shut it down, when in the air. Have you found this to be the case
with the externally regulated alternators? With the external regulator,
when you shut off power to the regulator it positively shuts down the
alternator.
I personally feel that the risk is very low with the
internal regulation, but also wonder why TC aircraft have continued to use
external regulation.
Roger
winmail.dat
 Filesize:  3.96 KB
 Downloaded:  858 Time(s)
bob.verwey(at)gmail.com
PostPosted: Mon Apr 02, 2012 7:27 am    Post subject: Converting to externally reg alternator Reply with quote
Does the crowbar module not offer enough protection? With a VFR day
only, electronic ignition setup, minimal elctrogizmos, does not the
reserve battery power give a safe reserve?
Bob Verwey
failure rate.
Eric,
alternator.
Roger
PostPosted: Mon Apr 02, 2012 8:14 am    Post subject: Converting to externally reg alternator Reply with quote
Bob Verwey
The Conventional crowbar module is used with the external
regulator. The internal regulator does not work with the external crowbar
circuit.
Roger
winmail.dat
 Filesize:  3.39 KB
 Downloaded:  795 Time(s)
PostPosted: Mon Apr 02, 2012 8:47 am    Post subject: Converting to externally reg alternator Reply with quote
My internally regulated plane power alt has crowbar ov protection.
On Apr 2, 2012, at 12:12, "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net> wrote:
Bob Verwey
circuit.
Roger
<winmail.dat>
PostPosted: Mon Apr 02, 2012 9:41 am    Post subject: Converting to externally reg alternator Reply with quote
Wow, I didn't think my question would hit such a sensitive nerve. In the same league as a primer war.
My question was about the "how" but many of you are interested in discussing the "why". Here's where I'm coming from.
For better or worse, the decision was made a long time ago to configure my electrical system for external regulation ala Bob M. Now I'm getting close to needing an alternator and looking at the options. I will have an SD-8 backup alternator and therefore don't consider the main alternator as being required to be of the absolute best quality. It just needs to have a failure mode that does not affect other more expensive electronics. As far as I know, there are no "100% guaranteed to work for ever" alternators anyway. So my theory is to have a spare in the hangar ready to go or to be brought to me when/if a failure occurs. I'm thinking I would rather have two $100 alternators that I have converted to external regulation and tested than one $595 alternator and no spare.
When, converting two to external regulation I will learn something and decide whether I can do this when away from my regular tool box. I may be too far from my spare and have to buy an internally regulated one and convert it out in the field. I seem to recall that it's not too difficult of a process. More like a removal of unnecessary parts. Something I am usually pretty good at. I plan on keeping some maintenance papers in the plane's tool bag anyway, one of which could be the alternator process.
My thoughts only. You may have another opinion and that's fine with me.
Bevan
"I like to build and fix things"
_____________________________________________
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of ROGER & JEAN CURTIS
Sent: Monday, April 02, 2012 9:12 AM
Subject: RE: Re: Converting to externally reg alternator
Bob Verwey
      The Conventional crowbar module is used with the external regulator. The internal regulator does not work with the external crowbar circuit.
      Roger
longg(at)pjm.com
PostPosted: Mon Apr 02, 2012 10:32 am    Post subject: Converting to externally reg alternator Reply with quote
Beven,
According to Mr. Google, this should take about 30 minutes. http://www.wallaceracing.com/alt-conversion.html
It looks like it's more popular to covert externals to internals (at least in the automotive world where the externals always failed).
Funny, I don't see too many folks lying under their cars on the turnpike pulling out their internally regulated jobs. I've run many a car well past 100k and never had the alternator go. That's why I've got an IR in my bird. I took have an SD-8. Wouldn't leave home without it.
Occasionally I talk to pilots who piss and moan about how they had to fly their so and so to the alternator shop so they could have Mr. Alternator specialist provide a special part for their regulator. No Thanks
Cut those wires and go fly. It's summer time.
Glenn, N57
PostPosted: Mon Apr 02, 2012 10:40 am    Post subject: Converting to externally reg alternator Reply with quote
Eric,
Very funny. But even this google search did not turn up what I was looking
for. It seems that your search result was to convert an old car to
internally regulated alternators. So I say "very funny". I know how to do
a google search. What I was looking for was a step by step documented
procedure I had seen on someone's build site.
Could it be that automotive manufactures may have gone to internal
regulation because is was more reliable via a solid state design with all
components contained within one housing therefore easier to install in the
vehicles coming down the assembly line? Were the voltage regulators that
you took apart and didn't like, mechanical regulators? I seem to recall my
1971 chev truck had a mechanical regulator mounted on the fender.
Bevan
PostPosted: Mon Apr 02, 2012 11:16 am    Post subject: Converting to externally reg alternator Reply with quote
Bevan,
Was this not the information you were looking for??
Bevan
Roger
winmail.dat
 Filesize:  3.93 KB
 Downloaded:  849 Time(s)
PostPosted: Mon Apr 02, 2012 12:09 pm    Post subject: Converting to externally reg alternator Reply with quote
Yes but,
I seem to recall a modification procedure that did not require machining any part of the case. It also did (as I recall) have you completely remove the internal regulator. So the process of conversion was different as I recall. All accomplished with simple hand tools. Perhaps Bob will chime in with his recommendation.
Bevan
Sent: Monday, April 02, 2012 12:12 PM
Subject: Converting to externally reg alternator
Bevan,
Bevan
Here is one at the EAA site which might help you. http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp
Roger [quote][b]
raymondj(at)frontiernet.n
PostPosted: Mon Apr 02, 2012 2:59 pm    Post subject: Converting to externally reg alternator Reply with quote
FWIW. I found this one in my files. Hope it's useful.
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 04/02/2012 03:09 PM, B Tomm wrote:
Yes but,
Bevan
*From: * owner-aeroelectric-list-server(at)matronics.com
[_mailto:owner-aeroelectric-list-server(at)matronics.com_] *On Behalf Of*
ROGER & JEAN CURTIS
*Sent: * Monday, April 02, 2012 12:12 PM
*To: * aeroelectric-list(at)matronics.com
*Subject: * Converting to externally reg alternator
Bevan,
Bevan
_http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp_
Roger
denso_alternator_mod_923.pdf
 Filename:  denso_alternator_mod_923.pdf
 Filesize:  383.27 KB
 Downloaded:  2075 Time(s)
PostPosted: Mon Apr 02, 2012 3:01 pm    Post subject: Converting to externally reg alternator Reply with quote
At 03:09 PM 4/2/2012, you wrote:
Yes but,
Bevan
A successful mod has more to do with understanding the
manner in which MOST internally regulated alternators
are wired, deducing the precise mechanics that accomplish
this in YOUR alternator of choice and then doing the
minimum chop, hack and solder to achieve that end.
Most commercial off-the-shelf alternators have one brush
wired to a (+) source of power internal to the alternator.
Identifying and isolating the (+) brush connection is key
to the mod.
http://tinyurl.com/8a9uuns
PlanePower no doubt breaks this connection and brings it to
the outside world so that external power can be routed inside
by way of a circuit breaker upstream of a crowbar ov module.
In this case, they leave the (-) brush wired to the pull-down
collector or drain of the built in regulator so that it can
continue to function at what it does best.
If you want to run a classic pull-up regulator with this
alternator, then you permanently ground the (-) lead,
you still bring the (+) lead out to the external regulator.
Here's the 'rub' . . .
[img]cid:.0[/img]
Most if not all "regulators" are housed in some
molded enclosure that includes brush holders. Identifying,
exposing brush connections, making reliable connection to,
and bringing leads out is not something one can write
a detailed, step-by-step instruction for. I could
probably mod about any alternator in 30 minutes but
that's based on a good working knowledge of alternators
in general. Take care that you do not alter the
spring geometry that keeps the brush in contact
with the slip rings at an optimized pressure for the
design.
I could write s-b-s instructions for any particular
model and brand . . . but suppose YOUR model and brand
is different?
I'm fairly certain that a mod can be done to about
any alternator without having to machine the case.
It's been 20+ years now so I'm not sure I recall why
the B&C mods DO machine the case. I think it's to
effect a nice mechanical connection of the (-) brush
with case ground using a spacer and screws. You don't
have to go that route, wires work too.
THEN . . . after slaying the (+) (-) brush problem,
you need to decide what, if anything, is best to be
done with the internal regulator. Simply isolated it
and leave in place -OR- pry it out and put jumper
wires in to take the brush holder wiring to the
outside world through the stock terminals on the
back of the alternator. I think you may find that
alloys used to fabricate bond-wire tabs for the
internal regulator's electronics assembly are not
very solderable . . . at least with our favorite 63/37
electronic grade stuff.
It has been suggested that the reason I don't offer
instructions for such mods on aeroelectric.com is
because I'm protecting a friend's market for modified
alternators. In fact, any article offered by me on anyone
else will be specific to one series of alternator of one brand.
I have oft suggested over the years that local alternator
shops could probably mod about any alternator you would
bring in the door. It's their business to have practical
knowledge of MANY alternators . . . which is beyond the
'scope of what I want to spend time on. If you study
and understand the alternator you have in hand, the
chances are you'll craft your own successful mod. But
just as weeks were spent fine-tuning the B&C offering
in search of the elegant solution, you'll spend a
significant amount of time doing yours for the first time
as well.
A great opportunity to learn something. If anyone
carries out a successful mod and bothers to photograph
the various steps, I'd be pleased to publish the
sequence on aeroelectric.com
Be sure to identify the 'victim' . . . preferably
by Lester number. This will greatly increase chances
of your efforts being useful to others.
 Filesize:  57.53 KB
 Viewed:  18349 Time(s)
PostPosted: Mon Apr 02, 2012 3:35 pm    Post subject: Converting to externally reg alternator Reply with quote
Roger
This appears to be a mod on a ND alternator. The guts
exposed in these pictures are familiar to me. You can
probably accomplish the job without a milling machine
or lathe but some judicious sculpting with a Dremel motor
and cut-off wheel will speed the process up a bunch.
Bob . . . [quote][b]
PostPosted: Mon Apr 02, 2012 3:38 pm    Post subject: Converting to externally reg alternator Reply with quote
Yes but,
See attached! Is this, perhaps the one you
are looking for?
Roger
winmail.dat
 Filesize:  1.08 MB
 Downloaded:  900 Time(s)
PostPosted: Mon Apr 02, 2012 7:19 pm    Post subject: Converting to externally reg alternator Reply with quote
Thanks Roger,
That's what I was looking for.
Bevan
Sent: Monday, April 02, 2012 4:11 PM
      Yes but,
          See attached! Is this, perhaps the one you are looking for?
Roger << File: Alternator Ext. Reg..pdf >> [quote][b]
eschlanser
PostPosted: Tue Apr 03, 2012 7:18 am    Post subject: Re: Converting to externally reg alternator Reply with quote
Roger or forum users,
I cannot seem to open the attachment. It appears on my screen as a winmail.dat file rather than an adobe pdf or other file that my computer can open. I am seeing the file in the aeroelectric forum at the matronics lists.
Thanks for any help,
Eric
mrspudandcompany(at)veriz wrote:
Yes but,
are looking for?
Roger
Goto page 1, 2  Next
Page 1 of 2
