BobbyPaulk(at)comcast.net Guest
Posted: Mon Mar 19, 2012 12:27 pm Post subject: Oily Residue |
p { margin: 0; }List
We have two Jabiru 3300 in my area and both have shown a brown oily residue at the bottom six o'clock position middle of the cylinder. It is right at the point where the head joins the cylinders.The substance looks like oil but is a little more sticky and has blackened spots in it. It is on 5 of my cylinders ( 146 hrs ) and only on the #4 and #6 of the other engine with only 28 hrs. I believe it to be burnt oil leaking between the heads and cylinders. Has anyone else experienced this and know what it is. Should we be concerned???
Bobby ( age 73 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 285 Needle Jet
Status - Flying 146 hrs.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
matronics(at)rtist.nl Guest
Posted: Mon Mar 19, 2012 12:47 pm Post subject: Oily Residue |
That's blow by. Your head-to-cylinder surface is leaking. Perhaps your heads are not properly torqued up or they are warped due to overheating.
Rob
On 3/19/2012 9:25 PM, BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net) wrote: [quote] p { margin: 0; } p { margin: 0; } List
Bobby ( age 73 )
Zodiac 601 XL "B"
dons701
Posted: Tue Mar 20, 2012 7:18 pm Post subject: Re: Oily Residue |
Rob, Not long after purchasing my plane 3 years ago with 50 hours, I had noticed the same staining on the bottom of two cylinders. I found that these heads are easy to remove for inspection and cleaning. Once removed, gently scrape to remove the crusty oil deposits from the end of the barrel and inside the receiver groove of the head. On assembly I use a very thin film of an nickel anti-seize on the end of the barrel and on the head bolts and torque to spec. I have not had any problems ever since, just watch your head temps. Hope this helps...DonB
_________________ Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop |
