Ed Anderson
Posted: Sat Mar 17, 2012 4:41 am Post subject: Source for Bakelite - 1/32" thick |
Here is some material that may serve as a stand-in for bakelite - appears to
be used as an arc insulator among other things.
http://www.mcmaster.com/#garolite/=gp981g
Ed
Sent: Saturday, March 17, 2012 7:48 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Source for Bakelite - 1/32" thick
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
rlborger(at)mac.com Guest
Posted: Sat Mar 17, 2012 4:43 am Post subject: Source for Bakelite - 1/32" thick |
Alfio,
Why bakelite? There are lots of much better (stronger, more durable, more easily worked) plastics available today.
I don't know about bakelite in particular, but McMaster-Carr has a large selection of plastics of various types and sizes.
http://www.Mcmaster.com/ > Raw Materials > Plastics
There is probably something suitable for your purpose.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Mar 17, 2012, at 6:48 AM, Alfio wrote:
I am building a Wingtip VOR Antenna, and am in need of 1/32" thick bakelite (3.25" x .8"). Any body have a source (mail order as reside in Canada) for this bakelite? Thanks.
Alfio
sprocket(at)vx-aviation.c Guest
Posted: Sat Mar 17, 2012 5:32 am Post subject: Source for Bakelite - 1/32" thick |
When all else fails, Aircraft Spruce. They only offer down to 1/16"
material, however. Search for Phenolic.
Beware: This stuff is toxic so be careful when machining it.
Also know as Micarta in some places.
V
Posted: Sat Mar 17, 2012 7:50 am Post subject: Source for Bakelite - 1/32" thick |
At 06:48 AM 3/17/2012, you wrote:
--> AeroElectric-List message posted by: "Alfio" <longeron(at)gmail.com>
Alfio
Bakelite is is the world's first synthetic plastic. It was the
material of choice for millions of molded shapes in the crafting
of consumer products back about 1933.
http://en.wikipedia.org/wiki/Bakelite
The stuff is still made but it's position in the marketplace is
more for historical authenticity or decorative purposes as opposed
to new product design. The stuff is brittle and in 1/32" thickness
would be VERY fragile. In fact, I sort of doubt that Bob's design
uses real Bakelite. I think he may have used the term to describe
the piece of plastic more as a historical recognition of its function
than for it's material. Bob is of my generation . . . many terms applied to
ideas common to our experience took on names that were more generic
than specific. I.e., all copy machines are 'xerox' machines, all
tissues are 'kleenex' etc.
The purist craftsman would recognize that this insulator
serves TWO purposes. First, it's a structural material that
maintains the position (.31" gap) between the two lower
pieces of aluminum. It's second function is to serve as
the dielectric in the capacitor formed between the lower
left and upper aluminum strips.
The exact value of that capacitor is a function of separation,
surface area and the dielectric constant of the insulating
material in the gap. This capacitor was no doubt 'tuned'
on the bench. Substitution of some plastic other than the
material used in the original design will change the value
of that capacitor.
[img]cid:.0[/img]
This particular technique for attaching a feedline to the
antenna is called a 'gamma match'. It is characterized by
a gamma rod that taps up from ground onto the radiating
element of the antenna. If the rod tapped onto the radiator
at the base, the impedance presented to the feedline is
zero ohms; if connected at the tip, it is thousands
of ohms.
Somewhere between the base and the tip, we find 50
ohms. Problem is, the gamma rod is not itself a
confined transmission line . . . it has an inductive
reactance that degrades the transfer of power between
the antenna and feedline.
We can put a capacitor in series with that inductance
to resonant it at the frequency of interest thus
creating a series-resonant circuit. This has the
net effect of putting a 'dead short' between the
end of the feedline and the tap on the antenna
in spite of the fact that they are separated from
each other by some distance.
Back in my much younger days, adjustment of a
gamma match involved moving the tap in search of
the impedance Nirvana followed by a re-tuning
a variable capacitor . . .
[img]cid:.1[/img]
to wash out the new value of inductive reactance
in the gamma rod. In fact, the last antenna I built
with this technology used a capacitor very much like
this one.
In the case before us, Bob Archer has deduced the
right place to tap the antenna for 50 ohms. He also
crafted the DIMENSIONS and MATERIALS for a
capacitor that most nearly cancels out the reactance
of the gamma-rod. In the capacitor above, the
dielectric (insulator) is air. In Bob's design,
the dielectric is 'Bakelite' . . . or something
he called by name.
The short answers come with two options:
(1) use any durable dielectric material of the
same thickness to craft a similar device
knowing that the 'match' will not be optimized.
I suspect that the resulting antenna will not
suffer so badly that degradation of performance
will be observable by a pilot in the cockpit.
Epoxy/Fiberglas (like etched circuit boards)
would be good.
(2) craft a new capacitor design that is
adjustable. You could use a small variable
capacitor like this . . .
[img]cid:.2[/img]
With an adjustable capacitor, the new match can be
optimized with the application of suitable test
equipment.
Even better, I might craft a new, optimized
but fixed capacitor as a double sided etched circuit
board and even add an SMA right angle connetor
to the assembly to make a more elegant termination
of the coax.
To make a reasonable approximation of Bob's original
design, look for any plastic material of the right
thickness. 1/32 is not going to be easy, thicker
material will be much easier but demand large changes
to other dimensions.
135.1 KB |
21228 Time(s) |
50.91 KB |
21228 Time(s) |
91.12 KB |
21228 Time(s) |
Posted: Sat Mar 17, 2012 3:43 pm Post subject: Source for Bakelite - 1/32" thick |
At 07:40 AM 3/17/2012, you wrote:
Looks like this comes in lots of flavors none
of which are named 'Bakelite' and include
some of the legacy g-type insulations that
were once popular for etch circuit boards.
These were in fact epoxy glass formulations.
There are a bunch of plastic materials that
could be substituted for the Bakelite. I
was just walking down the isles at Lowes
and found a number of plastic products or
containers for product that were fabricated
from 1/32" (or thereabouts) material. Some of
the bottles for stuff like liquid dishwasher
detergents looked like they could supply a
piece of pretty durable plastic of that
thickiness.
I thought about this on the way home from
Wichita and concluded that one handy solution
would be to craft the capacitor/insulator
assembly from a piece of single sided copper
clad. The copper would replace the top aluminum
plate. It would also provide nice 'solder pads'
for direct connection of the coaxial feedline.
The two nylon screws would be replaced by
bonding the under side of the ECB material
to the matching stub.
I've got some plans for some experiments on the
Medicine Lodge OBAM aircraft antenna range (my
back yard) to see if I can measure any performance
difference between a VOR antenna with versus one
without a BALUN. I can also craft the Archer
style VOR antenna and do the experiment to deduce
the proper change in dimensions to us 1/16" FR-4
ECB material in place of the Bakelite. I've got
probably 100 square feet of the ECB material and
a shear. I could provide .8" wide strips of the stuff
along with modified dimensions optimized to the
change of dielectric constant for the insulating
materials.
Does anyone have a B-A wing tip antenna kit that
they've not yet installed? It would be handy to
borrow it for the experiment . . . to be returned
in as-new condition.
dsvs(at)ca.rr.com Guest
Posted: Sat Mar 17, 2012 8:10 pm Post subject: Source for Bakelite - 1/32" thick |
I have one that has the wrong cap on it. I talked to Bob Archer and he told
me thet the cap belongs on one of his dipole ant rather than on the
monopole that it is installed on. He sent me a replacement cap that I have
not installed yet. I can ship the entire thing to you for the experiment.
You will also notice that the "Bakelite is different on each cap" Send me an
address via the email address that shows with my name.
Posted: Sun Mar 18, 2012 7:24 am Post subject: Source for Bakelite - 1/32" thick |
At 11:09 PM 3/17/2012, you wrote:
Interesting! You can send the stuff to me at
P.O. Box 130, Medicine Lodge, KS 67104-0130
or if you need to go UPS, then 209 Curry Lane
harrismarkr(at)hotmail.co Guest
Posted: Sun Mar 18, 2012 10:02 am Post subject: Source for Bakelite - 1/32" thick |
Hi Alfio
I am planning on doing the same do you have a drawing with the required dimensions on.The drawing I have dose not have the dimensions.
Mark
Rent our beautiful 3 bedroom luxury villa in Orlando, Florida.
View our virtual tour but book direct with us. See the link below:-
http://www.florida1strentals.com/property.php?id=21
Contact Emma and Mark Harris 01582 529820
harrisfloridavilla(at)hotmail.com
Posted: Wed Mar 21, 2012 4:14 pm Post subject: Source for Bakelite - 1/32" thick |
Package is on the way via Fedex. Open from the bottom marked open this
side.
Alfio
Posted: Tue Mar 27, 2012 3:48 am Post subject: Re: Source for Bakelite - 1/32 |
| harrismarkr(at)hotmail.co wrote: | Hi Alfio
Mark
Here are some dimensions (enclosed jpg), though some dimension information is still missing for the gamma match. I will probably just borrow an SWR meter and 'play'.
Thanks for all that responded. I'll be looking for paper phenolic xxx since it has low dielectric loss at high frequencies.
104.93 KB |
21117 Time(s) |
Posted: Tue Mar 27, 2012 6:25 am Post subject: Source for Bakelite - 1/32" thick |
| Quote: | Here are some dimensions (enclosed jpg), though some dimension
Here's a little clearer image that I think is
adequately dimensioned.
http://www.matronics.com/forums/viewtopic.php?t=89235
Alfio
Posted: Tue Mar 27, 2012 8:09 am Post subject: Re: Source for Bakelite - 1/32 |
Thanks Bob. I have that one as well. I am still looking for some dimensions on the gamma match though. The gap is identified, but not how far it is from the wingtip support for instance.
Posted: Tue Mar 27, 2012 6:05 pm Post subject: Source for Bakelite - 1/32" thick |
At 11:09 AM 3/27/2012, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Alfio" <longeron(at)gmail.com>
Did a little autocad layout and found that the top
capacitor plate doesn't come all the way to the end
of the capacitor di-electric. Given that it's
a 60-60-60 triangle with an inside dim of 5.00
inches, the details come out something like this:
http://tinyurl.com/7jatp88
Bob . . . [quote][b]
Posted: Tue Mar 27, 2012 8:54 pm Post subject: Source for Bakelite - 1/32" thick |
Did a little Autocad layout and found that the top
Just discovered that I had the elements of the gamma-match
swapped end for end in the drawing. Here's the corrected
version.
http://tinyurl.com/7wol3jx
Alfio
Posted: Wed Mar 28, 2012 2:04 am Post subject: Re: Source for Bakelite - 1/32 |
Bob . . . |
Just what I was looking for. Thanks.
Alfio
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Wed Mar 28, 2012 7:29 am Post subject: Re: Source for Bakelite - 1/32 |
Be careful when substituting non-reinforced plastic material for Micarta sheet. Often, you will need a phenolic laminate material with resin impregnated layers of linen cloth to provide support and to preserve electrical spacings at elevated temperatures. Many non-reinforced plastics will begin to flow when heated. Impregnated cloth or paper will maintain some electrical spacing even when charred.
Aircraft Spruce still sells “Grade L (linen base) phenolic sheet” 1/16 and thicker, which is the generic equivalent of Micarta.
_________________ Jerry King |
Posted: Wed Mar 28, 2012 8:04 am Post subject: Source for Bakelite - 1/32" thick |
At 10:29 AM 3/28/2012, you wrote:
Good thoughts. At least this case doesn't raise
critical questions as to structural integrity. The
parts being joined are exceedingly light.
The substitution problem here is two-fold. Structural
as you've correctly deduced PLUS electrical. The insulating
material is the dielectric for a high frequency capacitor
that is expected to TUNE out some reactive components of
the gamma-match elements.
A List member is sending me a store-bought antenna.
I'll mount it on a ground plane and get some SWR data.
Then I'll measure the VALUE of the as-purchased capacitor.
Then we'll have a basis for evaluating the electrical
qualities of any proposed substitution.
I'm thinking that we can fabricate the struts, insulator
and capacitor from a single piece of double-sided etched
circuit board material. I have lots of the material to
play with and can pretty easily test it against the store
bought design for optimal dimensions.
In fact, I'm considering a 'mod' to the design that
uses a variable capacitor soldered down to the ECB
material . . . which must be adjusted but it's pretty
easy to do with the ship's comm transmitter or a hand
held and an SWR meter.
