ssssskippy
Posted: Mon Mar 12, 2012 12:14 am Post subject: Cockpit cleaning advice |
Hi All
I'm tryng to remove the dirt stucked down In my yak52 . It s very difficult to vacuum it because of the mixing with oil....
I'm using a brush but I need some advice to improve the cockpit bottom cleaning .....
Some ideas ?
Olivier
Le 11 mars 2012 à 23:33, "Chris Wise" <wise(at)txc.net.au (wise(at)txc.net.au)> a écrit :
[quote] <![endif]--> <![endif]-->
I notice that Yakdrive is looking for a set of prop blades for his 18T (?)
Alex from GT Propellers has a set of 2.5 Diam GT Blades for sale in the US.
I fitted a set of GT blades to my Yak 18T and the increase in performance was immediately obvious.
Shorter take off distance, better climb and hence a better cruise speed at the same power settings as with the original V-350 prop.
Alex can be contacted at info(at)gt-propellers.com (info(at)gt-propellers.com)
Cheers,
Chris.
(Down Under. Australia)
//www.matronics.com/Navigator?Yak-List
cs.com
matronics.com/contribution
Pete Fowler
Posted: Tue Mar 13, 2012 8:10 am Post subject: Re: Cockpit cleaning advice |
My CJ was filthy down there when I got it. I had to take the seats out, sit there knotted up like a pretzel with a scrub brush and WD/40 to soften/scrub all that stuff out, then wiped it, lubed it and got a shop vac down in there for the loose stuff.
It's a despicable job.
threein60(at)yahoo.com Guest
Posted: Tue Mar 13, 2012 8:36 am Post subject: Cockpit cleaning advice |
I chose media blasting..
Larry Pine
N8181C
CJ6/m14p
Pete Fowler <pfdesign1(at)cox.net> wrote:
--> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net>
http://forums.matronics.com/viewtopic.php?p=368355#368355
_-============================================================
_-= - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Yak-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
