Small engines
williamtsullivan(at)att.n
PostPosted: Thu Mar 08, 2012 9:22 am    Post subject: Small engines Reply with quote
  Now that Rotax is doing away with their smaller 2-stroke engines, what is the Kolb factory looking at for a suggested stock engine on the Firefly?
                                             Bill Sullivan
                                             Windsor Locks, Ct
herbgh(at)nctc.com
PostPosted: Thu Mar 08, 2012 9:42 am    Post subject: Small engines Reply with quote
Strikes me that Mr. Hart up in Indianny...has already done the
research for them...? Those engines or a half Vw...at 84 lbs...Herb
the Firefly?
Bill Sullivan
Windsor Locks, Ct.
FS 447
capedavis(at)yahoo.com
PostPosted: Thu Mar 08, 2012 9:45 am    Post subject: Small engines Reply with quote
They . the Kolb factory that is just set up Phils Firefly with a mz 201 but he is the Guinea pig for this one I dont know what they will recommend.Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
From: william sullivan <williamtsullivan(at)att.net>
To: kolb list <kolb-list(at)matronics.com>
Sent: Thursday, March 8, 2012 12:21 PM
Subject: Small engines
        Bill Sullivan
        Windsor Locks, Ct.
    FS 447
Dralle, List Adm======
phactor9
PostPosted: Thu Mar 08, 2012 9:46 am    Post subject: Small engines Reply with quote
I am a couple of months (maybe sooner) away from firing up my CRE mz201 for my new Firefly, which I've been building all winter. Here's a page I posted a month or two back:
http://phactor.com/Kolb/201/201.htm
By last calculations, the total dry engine weight is approaching 82lbs, but that's including things I don't have on that page, and not including a battery.
http://phactor.com/eng_a.jpg
Phil H
FF11-4-00076
To: "kolb list" <kolb-list(at)matronics.com>
Date: Thursday, March 8, 2012, 12:21 PM
                                             Bill Sullivan
                                             Windsor Locks, Ct
Mike Welch
PostPosted: Thu Mar 08, 2012 10:07 am    Post subject: Small engines Reply with quote
Herb,
Half VW engine?? Cutting a VW engine in half, and leaving two of the cylinders back in your shop, would be like
planting corn on the last 500 feet of your 800 foot runway. Don't meck no sentz a'toll. Just sayin'......
hahaha
Mike Welch
On Mar 8, 2012, at 11:41 AM, Herb Gayheart wrote:
[quote]--> Kolb-List message posted by: Herb Gayheart <herbgh(at)nctc.com (herbgh(at)nctc.com)>
Strikes me that Mr. Hart up in Indianny...has already done the research for them...? Those engines or a half Vw...at 84 lbs...Herb
    Bill Sullivan
    Windsor Locks, Ct.
    FS 447
herbgh(at)nctc.com
PostPosted: Thu Mar 08, 2012 10:59 am    Post subject: Small engines Reply with quote
Some time ago...maybe next to the last Homecoming, a fellow from Tenn. brought his Firestar with a loaner half vw .. Homer looked it over and remarked that it sure does vibrate a lot!! His "loaner buddy" down near Knoxville.Tenn. flies a 45 hp super stroker on his Fly..all praise...Haven't talked to him in a year , so I do not know currrent status..
I have two Global, half vw's and one is on an N3 Pup...Idles well at 6 to 700 rpm...but vibrates a lot at 2850 to 2900 cruise... The crank and other rotating and reciprocating parts can be balanced to yield a decent 35 to 45 hp engine.. My case is purpose cast and has proper front and rear seals...engine runs on a single mag though some have installed dual ign. using gm hei modules and an electric system or waste energy.. I surely got comfortable flying behind it...mixture control and less than 2 gph...at abt 63 mph...
Never had a problem with a 447 on the Firefly either... Herb
At 12:06 PM 3/8/2012, you wrote:
[quote]Herb,
hahaha
Mike Welch
Bill Sullivan
Windsor Locks, Ct.
FS 447
http://www.matronics========================http://www.matronics.com/co =================
Dennis Thate
PostPosted: Thu Mar 08, 2012 3:33 pm    Post subject: Re: Small engines Reply with quote
Shucks ! I should not have given my "love Bug" engine away ...
KdF Wagen. KdF stood for "Kraft durch Freude" which meant "Strength through Joy." [Minus the vibration and extra weight.]
 Filesize:  36.55 KB
 Viewed:  5680 Time(s)
