Tom McCarthy
Posted: Sat Feb 25, 2012 5:19 am Post subject: 601HD comfort |
Now that I see some activity on the list I thought I would pose a question to the listers. I fly and enjoy a 601HD. I am 6' tall and around 210lbs, which I fit ok, if it were not for lower back problems. I had an occasion to sit in a 601XL last week, and it felt like I was in a Lazboy in comparison. I thought the only difference was the spar thickness, but it felt like the canopy was higher allowing for more padding in the seat. It also felt like there was more leg distance to the rudders, which I need as well. I have tried every combination of foam in my seats, but the pressure on my lower back when seated is just too much. My question is, has anyone tried to change the seat back for more room? Maybe cutting a curve in the deck and changing the seat pan? I have several ideas, but would like to hear from others that might have gone before me. I am aware that my ideas will affect the CG, but in my build, I have room to play.
Tom McCarthy
N514TM 601HD 300 hours [quote][b]
_________________ Tom McCarthy
N514TM Zenith 601HD
N414TM Kolb FireStar 1
N863GB Kolb Slingshot |
larrycmcfarland(at)gmail. Guest
Posted: Sat Feb 25, 2012 5:52 am Post subject: 601HD comfort |
Hi Tom,
There was some information on moving the edge of the tray back to afford a 2 to 3 inch advantage for tall people early on. I think you could easily revise the tray and re-angle the seat back structure to accommodate the clearance if you wanted to.
My HDS plans didn’t have that information at the time, so one could only thin the padding and seat back thickness to achieve the result. At 6’-1” and 197 lbs., my HDS is a fine fit and comfortable, but one could always use more space.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of McCarthy Tom
Sent: Saturday, February 25, 2012 7:19 AM
Subject: 601HD comfort
Tom McCarthy
N514TM 601HD 300 hours | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 01234567
psm(at)att.net Guest
Posted: Sat Feb 25, 2012 8:01 am Post subject: 601HD comfort |
Hi Tom,
My understanding is the XL is a foot longer than the HD. Perhaps this explains the additional room.
I have an XL and don't know exactly how the HD seat is done. In the XL there really is no seat back. Rather the rear of the seat is the same part as the front of the baggage compartment floor. I added a small sheet of plywood to fill in the "Back" of the seat, but this isn't really necessary.
I'm sorry this doesn't give you an answer to your back pain problem. Perhaps you need to trade your HD for an XL. If you do, make sure the upgrade is installed so the wings stay put.
Paul
Camas, WA
XL in flight test.
On 2/25/2012 5:18 AM, McCarthy Tom wrote: [quote]Now that I see some activity on the list I thought I would pose a question to the listers. I fly and enjoy a 601HD. I am 6' tall and around 210lbs, which I fit ok, if it were not for lower back problems. I had an occasion to sit in a 601XL last week, and it felt like I was in a Lazboy in comparison. I thought the only difference was the spar thickness, but it felt like the canopy was higher allowing for more padding in the seat. It also felt like there was more leg distance to the rudders, which I need as well. I have tried every combination of foam in my seats, but the pressure on my lower back when seated is just too much. My question is, has anyone tried to change the seat back for more room? Maybe cutting a curve in the deck and changing the seat pan? I have several ideas, but would like to hear from others that might have gone before me. I am aware that my ideas will affect the CG, but in my build, I have room to play.
Tom McCarthy
N514TM 601HD 300 hours [b]
jerryvmd
Posted: Sat Feb 25, 2012 9:13 am Post subject: 601HD comfort |
Tom,
After flying my 601 HD for a while I found the seat back too straight-up for my comfort. I moved the baggage shelf\angles, etc back about 2 inches. Remade all the seat supports and feel the comfort level is much better. I'm only 5'10" so except when seats are cold in the winter (my foam gets hard in cold, softens as it warms) I have plenty of head room. I did not consult Chris before I made the mod but saw him at Oshkosh this year, he took a look and said it was no problem.
Jerry
On 2/25/2012 8:18 AM, McCarthy Tom wrote: [quote]Now that I see some activity on the list I thought I would pose a question to the listers. I fly and enjoy a 601HD. I am 6' tall and around 210lbs, which I fit ok, if it were not for lower back problems. I had an occasion to sit in a 601XL last week, and it felt like I was in a Lazboy in comparison.
