capedavis(at)yahoo.com Guest
Posted: Mon Feb 20, 2012 2:54 pm Post subject: rotax377 |
KOLBERS, I am in search of an engine to replace the 447 the Firefly was designed for that doesnt cost $5000 I was looking at 377s for sale did google search and ended up at Ski Do sites on Ebay and Craigslist ETC They are selling ski do's with 377s some with electric start for $250 to $450 ! are these the same cases that the aircraft 377s come in? will a reduction gear bolt on to them?If they are and need to be rebuilt they will still be a lot cheaper than the $5000 engines I have been looking at like the MZ-201 !Any input will be appreciated. Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Dana
Posted: Mon Feb 20, 2012 5:20 pm Post subject: rotax377 |
At 05:53 PM 2/20/2012, chris davis wrote:
| Quote: | | KOLBERS, I am in search of an engine to replace the 447 the Firefly was designed for that doesnt cost $5000 I was looking at 377s for sale did google search and ended up at Ski Do sites on Ebay and Craigslist ETC They are selling ski do's with 377s some with electric start for $250 to $450 ! are these the same cases that the aircraft 377s come in? will a reduction gear bolt on to them?If they are and need to be rebuilt they will still be a lot cheaper than the $5000 engines I have been looking at like the MZ-201 !Any input will be appreciated. |
How about a Cuyuna? 35HP, They go for a lot less than a Rotax, parts are cheap, and IMHO their bad reputation is largely undeserved.
-Dana
Giving money and power to government is like giving whiskey and car keys to teenage boys.
Posted: Mon Feb 20, 2012 8:52 pm Post subject: rotax377 |
Thanks Dana I will look into it . do you know anything about the ski do rotax 377s ?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Monday, February 20, 2012 8:18 PM
Subject: Re: rotax377
-Dana
=nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List
Ducati SS
Posted: Tue Feb 21, 2012 5:54 am Post subject: Re: rotax377 |
It was so many years ago that I worked on the 377 I can not tell you for certain about any extra mounting points on the PTO end of the engine. But I really doubt you would be able to mount a gearbox. the sleds of that era almost all mounted the engine from the bottom and only needed an internally threaded crankshaft to mount the clutch. You may be able to use one of the plate mounted belt drives. The 377 was a good running engine but I will pass along one big warning. We sold some 377 powered Ski-Doos 2 of which returned at the start of their 2nd season not running.
They both had the worst internal corrosion of any engines I have seen in 35 years of repair work. I have a theory as to what happened but I can not explain why it only happened to the 377. I believe the failure was caused by a combination of synthetic oil and oil injection. Oil injection works off both rpm and throttle opening. The system pumps very little at closed throttle low rpm. On the other hand pre mix always carries enough oil for the engines highest demand. So on shut down with premix the engine is pulling in more oil than needed, its not burned as the ignition is off, so it is left to coat the inside of the engine. Oil injection backs oil delivery way off at shut down and may not be coating internal parts as well. combine this with synthetic oils reduced resistance to corrosion and it ruined the top end of the 2 engines. Now I don't know about other parts of the country but in this part of the northeast snowmobiles are often among the most neglected machines on earth. Many times they appear to be left right where the snow melts out from under them. They would come in the shop full of leaves and mice and with the seat covers rotted from sunshine. I do not think I would buy any airplane engine sight unseen unless the deal included at least a short term return policy.
mburdge39
Joined: 24 Sep 2011 Posts: 18 Location: Brookville PA
Posted: Thu Feb 23, 2012 2:12 pm Post subject: Re: rotax377 |
I have a 377 on my Firefly. The provision 4 takes an "A" gearbox while the provision 8 takes a "B" gearbox(plus others). The Ski-doo snowmobiles have neither provision and you must use a belt reduction drive.
127.81 KB |
16284 Time(s) |
_________________ Mike
Firefly |
Posted: Fri Feb 24, 2012 7:35 am Post subject: rotax377 |
Thank you Mike
How does the 377 perform ,what is your climb rate? take off distance etc / thanks again you are the first 377 flyer of any aircraft that I have heard from!
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Thursday, February 23, 2012 5:12 PM
--> Kolb-List message posted by: "mburdge39" <mburdge(at)windstream.net (mburdge(at)windstream.net)>
Firefly
http://forums.matronics.com/viewtopic.php?p=367094#367094
http://forummatronics.com/Navigator?Kolb-List" target=_blank>http://www.matronics.com= &nbs===================
mburdge39
Posted: Fri Feb 24, 2012 5:50 pm Post subject: Re: rotax377 |
I bought the firefly last year and have not flown it myself yet. I do have a video on CD of take-offs and landings with the 377 from the former owner. I would gladly send you a copy of the video.
I have an extra 447 waiting to swap on if needed, but the former owner/builder said he loved the 377 as it was a smooth running engine with plenty of power for the Firefly.
Shoot me a message with your address and I will get a copy of the CD in the mail to you. I might even have an economical engine for you!
Firefly |
flykolb(at)pa.net Guest
Posted: Fri Feb 24, 2012 8:35 pm Post subject: rotax377 |
Chris,
As best I can recall, there was not much difference between the 377 and 447.
Dennis
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of chris davis
Sent: Friday, February 24, 2012 10:35 AM
Subject: Re: Re: rotax377
Thank you Mike
Chris Davis
KXP 503 492 hrs
Glider Pilot
From: mburdge39 <mburdge(at)windstream.net (mburdge(at)windstream.net)>
Firefly
| Quote: | | http://www.matronics.com/Navigator?Kolb-List | 01234567
Thom Riddle
Posted: Sat Feb 25, 2012 5:40 am Post subject: Re: rotax377 |
I've owned two early Firestars. The first one was built very light and ran a 377. Its climb performance was as good or better than the 2nd one which was built heavy and ran a 447. A suspect a light Firefly would have excellent performance with a 377.
BTW, for reasons unknown to me, the 377 was far less persnickety regarding prop pitch and mixture tweaks to get proper EGT readings under various flight regimes, than the 447. I think others have had similar experience. If I didn't need the extra 5 hp, the 377 would be my preference.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Feb 25, 2012 10:11 am Post subject: rotax377 |
Thanks for that Dennis I respect you opinion. Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Friday, February 24, 2012 11:34 PM
Subject: RE: Re: rotax377
Chris,
Dennis
Thank you Mike
Chris Davis
KXP 503 492 hrs
Glider Pilot
Firefly
8
Thanks Thom I will put that in my book !
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Saturday, February 25, 2012 8:40 AM
--> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Truth is what stands the test of experience.
- Albert Einstein
http://forums.matronics.com/viewtopic.php?p=367217#367217
http://www.matronics.com/Navigator?-= &-->
gyrodude
Joined: 15 Nov 2011 Posts: 16 Location: Stanfield N.C.
Posted: Wed Feb 29, 2012 11:55 am Post subject: Re: rotax377 |
I have a Firestar with a 377 on it. I'm a lightweight toping out at 135lb. The plane has all the power I will ever need. I'd say takeoff is about 100'. Throttle foward, tail up and it's ready to fly. Cruise is in the 50-60mph range. Fuel burn is 2.5-3 gal an hour at cruise. Steve Beatty at Airscrew Performance in Glendale, Arizona has 377's and parts. I started my ultralight career many years ago flying a Teratorn TA with a 377 on it. I've never had a problem with the 377.
Posted: Wed Feb 29, 2012 4:40 pm Post subject: rotax377 |
Dude, Thank you I think the 377 is the engine for me I am around 200 lbs but the Firefly is quite a bit lighter than the Firestar. What is your rate of climb? I flew a 330 lb Firestar KXP for about 10 years with a 503 single carb the climb rate was over 1000ft/min jus wondering about a comparison . thanks again Chris
Sent: Wednesday, February 29, 2012 2:55 PM
--> Kolb-List message posted by: "gyrodude" <gsafrit1(at)carolina.rr.com (gsafrit1(at)carolina.rr.com)>
http://forums.matronitp://www.matronics.com/Navigator?Kolb-List" bsp; ==================
wakataka
Posted: Wed Sep 19, 2012 12:44 pm Post subject: Re: rotax377 |
I've just recently purchased an original model Firestar with a 377. Empty weight is about 325# and I weigh about 200#. I need to take some pitch out of the prop because the engine is only turning about 6100 rpm at full throttle, but I'm still getting better than 600 feet per minute on climb. It's the smoothest running 2-stroke I've ever flown. Also, it runs cool compared to a 447. Even in the current over-propped condition CHT is about 315 in cruise and never exceeds 400 in climb out. On cross country flights, my fuel burn is just slightly more than my buddy who flies a 277. From my experience so far, I don't believe I would want to trade it for a 447.
_________________ There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact.
Mark Twain |
rickofudall
Posted: Wed Sep 19, 2012 5:39 pm Post subject: rotax377 |
You don't say what your engine's EGT's are running, but if you take out some pitch your CHT will go down. Is your full throttle reading on climb or in level flight? If you're getting that RPM in climb you might want to consider just leaving it alone. The numbers you're getting are very similar to the last 447 I did the break in and first flights on.
Rick Girard
On Wed, Sep 19, 2012 at 3:44 PM, wakataka <wakataka(at)charter.net (wakataka(at)charter.net)> wrote:
| Quote: | --> Kolb-List message posted by: "wakataka" <wakataka(at)charter.net (wakataka(at)charter.net)>
Mark Twain
http://forums.matronics.com/viewtopic.php?p=383552#383552
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
