Removing magnetic plug from Rotax 912 gearbox
Richard Lamprey
PostPosted: Sun Feb 19, 2012 12:49 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Does anyone know the best way to get this plug out? I burred the hexagonal inset, so hex key (allen key) no longer going to get it out. I have tried clonking gently with hammer (as per various instructions) to loosen, to no avail.
My plug replacement is of the new variety that can be removed with a ring-spanner. Just got to get the old out and check for filings.
Perhaps a left handed thread bolt/screw that self-taps into the burred inset??
Any ideas welcome.
Richard
Europa 168, Kenya
ward.t(at)xtra.co.nz
PostPosted: Sun Feb 19, 2012 1:14 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Richard,
I had the same problem and got it out with a metal chisel and burred a slot to force it anti clockwise with a hammer. Then replace it with a new type. Put some anti seize compound on the thread.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 19/02/2012, at 9:49 PM, "Richard Lamprey" <lamprey.richard(at)gmail.com> wrote:
Any ideas welcome.
Richard
Europa 168, Kenya
http://forums.matronics.com/viewtopic.php?p=366581#366581
craigb(at)onthenet.com.au
PostPosted: Sun Feb 19, 2012 2:09 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
You could use an Eazy_out. It requires you to drill a hole, Although, the
correct size easy_out may fit into the hole
Left from the allen key hole. You can normally buy a set of them for about
$20. Its like a left handed really coarse
Thread high tensile screw. Good quality easy-outs are tool steel, so they
will cut into the hole, to give a really
Good grip on the remnants of the bolt
Good luck
craig
kevinmarie(at)blueyonder.
PostPosted: Sun Feb 19, 2012 2:19 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
I wouldn't use an easy out as the magnetic bit could fall off when you drill for the easy out. A chisel and hammer to knock the plug round worked for mine.
Kevin
Good luck
craig
stabelvej9(at)gmail.com
PostPosted: Sun Feb 19, 2012 2:34 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Mine too ... Smile
Gert
Den 19/02/2012 kl. 11.18 skrev Kevin Challis:
Kevin
> Good luck
> craig
Ivor Phillips
PostPosted: Sun Feb 19, 2012 8:06 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Before using the chisel method us some localised heat from a needle jet butane gun, then a few sharp taps will see it out,
best wishes
ivor
2012/2/19 Gert Dalgaard Sørensen <stabelvej9(at)gmail.com (stabelvej9(at)gmail.com)>
[quote]--> Europa-List message posted by: =?iso-8859-1?Q?Gert_Dalgaard_S=F8rensen?= <stabelvej9(at)gmail.com (stabelvej9(at)gmail.com)>
Mine too ...  Smile
Gert
--> Europa-List message posted by: Kevin Challis <kevinmarie(at)blueyonder.co.uk (kevinmarie(at)blueyonder.co.uk)>
Kevin
On 19 Feb 2012, at 10:08, "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)> wrote:
> --> Europa-List message posted by: "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)>
> Good luck
> craig
&g====================
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Europa-List" target="_blank">http:=====
http://forums.mle, List Admin.
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Feb 19, 2012 1:17 pm    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Hi! A heat gun (hot air only) worked for me then a good clout with a hammer
and a chisel on the outer diameter.
Bob Harrison.
kingsnjan(at)westnet.com.
PostPosted: Sun Feb 19, 2012 3:23 pm    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Gentlemen,
When removing the magnetic plug, in addition to the heating, cooling and impacting methods, it is important to use the correct tool.
Early engines had a 6 mm Allen fitting. Later engines have a #40 Torx fitting requiring a #40 Torx socket. The latest engines of course now have the Hex headed plug.
Look carefully because the Torx fitting looks very much like an Allen key one at first sight.
Also, don't use a cheap Torx socket, a Snap-on one may prove to be cheap in the long run!
Cheers
Kingsley from Oz - Enjoying my first real cross country trip in a 914 Mono. 800nm from home at the moment but still in the same State! Truly is a great cross country aircraft.
Bob Harrison.
rlborger(at)mac.com
PostPosted: Sun Feb 19, 2012 6:08 pm    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Fellow Europaphiles,
Yes, heat gun, impact device or impact wrench and proper drive. I used a heat gun, #40 Torx and impact device (all from Sears) to remove the magnetic plug from my engine the first time. The impact device was a strange black thing with a square 3/8" drive on one end and the other end was round to hammer upon. Heated the block around the plug with the heat gun, put the Torx drive on the impact device, made sure it was properly and firmly seated in the plug and then whacked it a good one with a 2 lb hammer. The impact simultaneously applied both an inward force and a loosening torque force. Took several good whacks (take care not to crack the block) to get it loose enough to remove with a ratchet. I have since acquired a nice little Makita cordless impact wrench that I would use for the plug removal should it be necessary. Hopefully, by using anti-sieze and proper torque upon last reinstallation, it will not be necessary later this week when I begin the annual condition inspection.
If you have buggered up the hole in the plug such that your Torx or hex wrench will no longer work, Sears has a set of removal tools with a strong left-hand bite that do not require one to drill out the hole. They could possibly be used to remove the plug. I have used them to remove other messed up screws that I though would be impossible to get out.
I can provide pictures of these tools should you want to see what they actually look like before you go searching for them.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Feb 19, 2012, at 5:21 PM, Kingsley Hurst wrote:
Gentlemen,
Cheers
tennant
PostPosted: Mon Feb 20, 2012 12:34 am    Post subject: Re: Removing magnetic plug from Rotax 912 gearbox Reply with quote
And there was me thinking that I was the only dumbo to round off my plug.
I think they made the first batch from chewing gum they are so soft!
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
Remi Guerner
PostPosted: Mon Feb 20, 2012 11:27 am    Post subject: Re: Removing magnetic plug from Rotax 912 gearbox Reply with quote
After I wrecked the torks hole, I cut two flats using a hand saw blade. Then I was able to use a regular wrench to remove the magnetic plug. I bought a good quality torks wrench for use with the new plug and never had the problem ever since.
Remi Guerner
Richard Lamprey
PostPosted: Mon Feb 20, 2012 9:14 pm    Post subject: Re: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Many thanks to all for your comments. Lots of ideas, I'll try with the least brutal and work upwards.
All best
Richard
Richard Lamprey
PostPosted: Mon Dec 31, 2012 11:16 pm    Post subject: Removing magnetic plug Rotax 912 gearbox, Bob, Sears tool? Reply with quote
Happy New Year to all, and apologies for returning to an old topic...
Bob (Borger) had an option for a Sears tool that would remove the plug. Bob, do you have details of that (picture, part number?).
Best
Richard
Kenya
rlborger(at)mac.com
PostPosted: Tue Jan 01, 2013 6:12 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Richard,
Yes, I have a Sears tool that works. I'll get the necessary information and a picture the next time I'm at the hanger. Maybe later today.
Weather has been awful for flying for the last several days, but lovely considering the draught conditions we've had. I'll not complain about cool, rainy, foggy weather in North Texas.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 1, 2013, at 1:16 AM, Richard Lamprey <lamprey.richard(at)gmail.com> wrote:
Best
Richard
Kenya
rlborger(at)mac.com
PostPosted: Tue Jan 01, 2013 11:14 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Friends,
This is the hand tool that can be used to remove the magnetic plug.
[img]cid:721F83DA-E04F-470D-894C-F1AA6BAA1BAC[/img]
It requires a 1/2" drive #40 Torx bit.
For specific instructions on removal of the magnetic plug see the instruction video at Rotax-Owner.com. They provide a quite detailed tutorial.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Jan 1, 2013, at 8:11 AM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
Richard,
On Jan 1, 2013, at 1:16 AM, Richard Lamprey <lamprey.richard(at)gmail.com (lamprey.richard(at)gmail.com)> wrote:
--> Europa-List message posted by: "Richard Lamprey" <lamprey.richard(at)gmail.com (lamprey.richard(at)gmail.com)>
Best
Richard
Kenya
 Filesize:  175.6 KB
 Viewed:  15712 Time(s)
PostPosted: Tue Jan 01, 2013 11:51 am    Post subject: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Richard,
Rotax brought out a replacement plug with a hexagonal connection shape (bolt) which is good.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 1/01/2013, at 8:16 PM, "Richard Lamprey" <lamprey.richard(at)gmail.com> wrote:
Best
Richard
Kenya
http://forums.matronics.com/viewtopic.php?p=391314#391314
Richard Lamprey
PostPosted: Wed Jan 02, 2013 3:34 am    Post subject: Re: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Thanks Bob, this may do the trick. I'll order one. Challenge I have is to get it to East Africa, but thats another story....
Tim, thanks, I have the new one, just need to get the old one out.
All best
Richard
h&jeuropa
PostPosted: Wed Jan 02, 2013 4:41 am    Post subject: Re: Removing magnetic plug from Rotax 912 gearbox Reply with quote
Richard,
The impact tool that Bob used has been copied by the Chinese and is available at motorcycle shops and the like. You may be able to find it locally. The Chinese tool isn't high quality but you only need it to work once!
Jim & Heather
