rflick(at)ovalinternet.ne Guest
Posted: Sun Feb 05, 2012 11:51 am Post subject: weight and bal |
hello. i am finishing my 601 HDS with a corvair eng and can t decide to use the 16 gal hdr tank since i also have the wing tanks. i am concerned the hdr tk will put the w&bal out where i have to add weight to tail and don t want that. anyone have exp with this or advice. i am also useing the marvel s carb so i like the hdr tk which is pretty foolproof. thanks ralph
don.honabach(at)pcperfect Guest
Posted: Sun Feb 05, 2012 1:46 pm Post subject: weight and bal |
I have a 601HDS with just the wing tanks and have been rather happy with the setup.
I’m flying behind a Jabiru 3300A with my battery on the firewall. I’m not sure about the weight differences with a corvair, but for me I didn’t have any W&B issues in my setup using just the front of spar ~11 gallon wing tanks.
Don
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Flick
Sent: Sunday, February 05, 2012 12:48 PM
Subject: weight and bal
==============[/b][/quote] enith-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?Zenith-List">http://www.matronics.com/Navigator?Zenith-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
larrycmcfarland(at)gmail. Guest
Posted: Sun Feb 05, 2012 2:41 pm Post subject: weight and bal |
Hi Ralph,
With my Stratus Subaru, I have a 9.8 gallon header with 7.1 gallon wing tanks and my radiator is 34 inches aft of the firewall on the belly. Within all variations I cannot get it out of CG unless it were loaded beyond 1300 lbs., my max utility wt.
Would think the Corvair would be close if not a bit forward on the CG.
I’ve a program you can have that you can modify numbers to run the variations for your plane if you want it. It runs on EXCEL and is nicely done and easy to use.
Reply email to larrycmcfarland(at)gmail.com (larrycmcfarland(at)gmail.com)
Sent: Sunday, February 05, 2012 1:48 PM
steve.freeman(at)syntaxds Guest
Posted: Mon Feb 06, 2012 6:58 am Post subject: weight and bal |
HI Larry,
May I have a copy of that spreadsheet? I am putting in an 0235 and it is a heavy engine. I would love to run some the W&B numbers as I try to determine where to put a battery.
I am building the 650B
Steve
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Larry McFarland
Sent: Sunday, February 05, 2012 3:39 PM
Subject: RE: weight and bal
Hi Ralph,
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com] ([email][mailto:owner-zenith-list-server(at)matronics.com][/email]) On Behalf Of Bill Flick
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
012345678901234567
steve(at)cccparis.com Guest
Posted: Mon Feb 06, 2012 7:57 am Post subject: weight and bal |
would your program work on a 701? I'm installing an 0200A and planned on using the battery to help set CG. Steve
japhillipsga(at)aol.com Guest
Posted: Mon Feb 06, 2012 8:28 am Post subject: weight and bal |
Contact Roger D. at ZAC. He will know every possible combination of engine, w & B and batt location, etc. in the 601 series. Over the years he's seen them all.
georgerace
Posted: Mon Feb 06, 2012 9:29 am Post subject: weight and bal |
Sent: Monday, February 06, 2012 12:24 PM
To: 'zenith-list(at)matronics.com'
Attached is an Excel Spreadsheet. It will work for any airplane.
Is filled out with my information for my 701, all is changeable to your figures.
George
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com
Sent: Monday, February 06, 2012 11:26 AM
Subject: Re: weight and bal
Description: |
 Download |
Filename: |
My_WEIGHTBALANCE.xls |
Filesize: |
23 KB |
Downloaded: |
570 Time(s) |
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
