tgesele(at)optonline.net Guest
Posted: Fri May 26, 2006 4:54 am Post subject: Fiberglass panel options |
For those who went with one of the after-market fiberglass panels available,
were there any modifications required in the upper fwd fuselage assembly?
Also, is there a rough guesstimate of the difference in weight between the
fiberglass and stock panel?
Tom Gesele #473 - Fuselage
Tim(at)MyRV10.com Guest
Posted: Fri May 26, 2006 5:59 am Post subject: Fiberglass panel options |
I can't comment on fiberglass specific mods, but I can tell you
that no matter what kind of panel you go with, you'll probably
need to modify the ribs in the upper forward fuse if you go with
any EFIS product. Those ribs get in the way.
Tom Gesele wrote:
Randy(at)abros.com Guest
Posted: Fri May 26, 2006 12:06 pm Post subject: Fiberglass panel options |
The modification all depends on what you put in the panel. I had almost
no changes to rib (only a slight relief on the lower flange). I moved
the MX20 to the top of the stack so the center rib has no modifications
at all. Randy
Posted: Fri May 26, 2006 1:54 pm Post subject: Fiberglass panel options |
First, thanks for the responses to my question.
Second, I was hoping to get information on the mounting differences between
the stock aluminum panel and the various fiberglass substitutes available.
Specifically, looking at the way the stock panel mounts, there is a lower
sub-panel (F-1003B) that screws to the main panel and is riveted to the
fuselage side skins. If you use one of the fiberglass substitutes, is this
piece required, does it require modifications, or is there a piece that
substitutes for it? Also, do any of the three ribs from the F/W to the panel
require any modifications?
Thanks in advance for any insights from those who've already gone this
route.
Tom Gesele #473
wvu(at)ameritel.net Guest
Posted: Sat May 27, 2006 4:14 am Post subject: Fiberglass panel options |
That is true. The biggest problem is when you get the EFIS put right in
front of the pilot and copilot, it will sit very near the rib. Then,
if you try to put anything under them, you're stuck. Like on my panel,
putting the redundant 2-1/4" round gauges is what did me in, and also
the EIS on the other side. Anyway, I think modding the ribs is going to
be a common thing for many people. I don't know what mods need to be
done to get a fiberglass panel in though, unfortunately....out of my
knowledge base. Anh, have you got yours put in yet? Maybe you can
comment on what needs to be done with that lower subpanel?
DejaVu wrote:
Only if you have 3 Cheltons and two of everything, Tim! I have two
GRTs side by side and no mods to those ribs.
Anh
Posted: Sat May 27, 2006 9:58 pm Post subject: Fiberglass panel options |
I've fitted the panel a few times. Had to cut a 7 X 8" hole in the
sub-panel to the right of the center rib to accomodate the stack. My round
gauges are below the GRT's. They cleared the ribs just fine. The GRT
EFIS's are 3" deep so I positioned them low enough to clear the ribs. I had
another alum panel cut and bypassed most of the lower bar. The ends of this
bar are riveted to the fuse sides so I kept the outter 1.5" of the ends for
this purpose.
Anh
Posted: Tue May 30, 2006 2:32 pm Post subject: Fiberglass panel options |
On my fiberglass panel I used the ends or the cross brace only. I cut
the last 1 1/2" off and riveted it to the fuse side skin. When I placed
the panel in place I drilled through the panel into cross brace end
pieces then pulled the panel and installed nut plates on them. Now there
is one screw in each lower corner to hold it. I have the center console
so there is no movement at all. Randy
