Viking Aircraft engine
Goto page 1, 2  Next
bill mcclellan
PostPosted: Thu Jan 26, 2012 10:22 am    Post subject: Viking Aircraft engine Reply with quote
Bud or anyone,
This seems to be a very nice engine for the Europa, a Viking Honda aircraft engine. The Viking shop in in Edgewater, FL. Do you know anything about this engine? It is the Honda 1500 cc, 117 hp, 6300 rpm max, 2.33/1 reduction drive, fuel injected, liquid cooled, 178 lb dry weight, fully developed package for aircraft use. The package includes 40A Alternator, Dual Engine controllers, Exhaust / Muffler, Air intake, K&N Filter, Starter, Radiator, Oil cooler, fuel pumps and Engine mounting for your airplane. The engine is fully assembled. $13,000 Looks like a very good alternative to the Rotax. They haven't yet but likely to develop retro fitable turbo-charge down the road.
Bill McClellan
davidjoyce(at)doctors.org
PostPosted: Thu Jan 26, 2012 2:23 pm    Post subject: Viking Aircraft engine Reply with quote
Bill, It sounds like a great option, but if you talk to the various folk who
have fitted anything other than a Rotax to a Europa, I guess you will be a
bit wary about being the first one to try it! Regards, David Joyce, G-XSDJ
garrys(at)tampabay.rr.com
PostPosted: Thu Jan 26, 2012 5:57 pm    Post subject: Viking Aircraft engine Reply with quote
This engine is being sold by Eggenfeller.........formerly selling the Subaru engine conversions. Those Subaru engines turned out to be completely unreliable and downright dangerous. I know nothing about his latest project, the Honda conversion, but based on his previous engines, I wouldn't trust him. Google his name and you'll get a real education.
Garry Stout
On Jan 26, 2012, at 1:18 PM, William McClellan <wilwood(at)earthlink.net> wrote:
Bud or anyone,
Bill McClellan
wdaniell(at)etb.net.co
PostPosted: Fri Jan 27, 2012 4:30 am    Post subject: Viking Aircraft engine Reply with quote
Yes I too looked at this option but as garry points out, and without knowing
Eggenfelner, I saw a lot of negative stuff on the web and also you see quite
a few of his engines for sale...being changed out for something else. This
generates a significant degree of caution in me at least. He might well
have got it right this time.
I think the base Honda fit engine is a very interesting powerplant and the
volume and quality control is unlikely to have the manufacturing problems
that the aviation manufacturers have like dodgy cranks but I am personally
am not up for the experimentation process required to get it flying.
There was a chap flying in Canada whose name escapes me with a Honda/CAM100.
Will
peterz(at)zutrasoft.com
PostPosted: Fri Jan 27, 2012 5:27 am    Post subject: Viking Aircraft engine Reply with quote
fwiw, I've subscribed to his email group list and have been watching the banter with interest. I too have heard not-to-good things about the fellow. His on-line demeanor, and his answers to my in-person questions to him at Osh two years ago suggest arrogance.
My issues with the design are 1- the prop turns the 'wrong' way. 2- he uses a rubber coupler in an attempt to deal with harmonic resonances, and from my EAA chapter colleagues experiences (with other redrives) and also my research on this topic, this damper will not be able to dissipate the power at the resonance peak (typically at lower rpms and power settings... just above idle) for any extended durations. When asked about this design he didn't really answer it other than stating that the built-in fan 'blades' in the starter ring gear were designed to cool it.
I think the Honda block has promise tho - it's the same engine that is raced in the amateur leagues, and also the same one they use in their outboard marine engines.
Time will tell I guess whether his installation is more sound than his previous efforts with the Subarus
Pete
On Fri, Jan 27, 2012 at 7:27 AM, William Daniell <wdaniell(at)etb.net.co (wdaniell(at)etb.net.co)> wrote:
[quote] --> Europa-List message posted by: "William Daniell" <wdaniell(at)etb.net.co (wdaniell(at)etb.net.co)>
Will
Speedbird
PostPosted: Fri Jan 27, 2012 6:22 am    Post subject: Viking Aircraft engine Reply with quote
Folks,
I have been lurking on the forum now for awhile and would like to suggest to look at the UL-Power engine instead!
As far as I now there is one in UK I think nearing completion for the Europa and my personal choice as soon as I can order the kit...
I have no commercial interest in the company but to me that engine is probably the best engine right now.
Blue Skies & Tailwinds!
Ivan
KajakCenter Halland
Org nr; 5805034625
P: +46 703 621310
P: +46 704 694444
M: midwing(at)telia.com (midwing(at)telia.com)
W: www.kajakcenter-halland.se
27 jan 2012 kl. 14:23 skrev Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)>:
[quote]fwiw, I've subscribed to his email group list and have been watching the banter with interest. I too have heard not-to-good things about the fellow. His on-line demeanor, and his answers to my in-person questions to him at Osh two years ago suggest arrogance.
My issues with the design are 1- the prop turns the 'wrong' way. 2- he uses a rubber coupler in an attempt to deal with harmonic resonances, and from my EAA chapter colleagues experiences (with other redrives) and also my research on this topic, this damper will not be able to dissipate the power at the resonance peak (typically at lower rpms and power settings.... just above idle) for any extended durations. When asked about this design he didn't really answer it other than stating that the built-in fan 'blades' in the starter ring gear were designed to cool it.
Pete
Will
Gary.Leinberger(at)miller
PostPosted: Fri Jan 27, 2012 7:02 am    Post subject: Viking Aircraft engine Reply with quote
I looked at using auto engines in my Europa - the applications (car versus airplane) are just so different. While the base cost of these converted engines seems attractive, the problems soon run the cost (and the aggravation) far above the cost of a Rotax - just started my 912S and am impressed with it. Like all German/Austria equipment, if maintained by the book, they seem to run forever. After nine years of building the last thing I want is to experiment with an engine generally backed by an undercapitalized entrepreneur.
If you are just starting your build, my advice is to wait to buy. One never knows how long it will take to build and any savings in buying the engine earlier (prices do go up with inflation) are eaten up in maintenance on dried-out o-rings and required updates that are standard for new engines. I looked at the 912S when I started the build in 2003 and it was $15K or so list, and in 2010 bought my engine for $23K (with all the bits and shipping). This is about a 6% increase a year. But the engine is far superior to the 2003 engines (the U.S. Army required a bunch of very good changes) and Rotax improved the engine in other ways. Several other people that bought early (and cheaper) are paying more in the long run for an inferior early engine
europapa
PostPosted: Fri Jan 27, 2012 7:35 am    Post subject: Re: Viking Aircraft engine Reply with quote
There are some alternatives to the Rotax like this German one:
http://www.silent-hektik.com/UL_M800a_1.htm
but I too would not dare to try it out.
Juergen
PostPosted: Fri Jan 27, 2012 8:08 am    Post subject: Viking Aircraft engine Reply with quote
Interesting site - they have a big bore kit for the 912 taking it to
110hp....add a turbo....130-140hp.....
max8992
PostPosted: Fri Jan 27, 2012 8:11 am    Post subject: Viking Aircraft engine Reply with quote
Hi there all,
The club in which I was (and still am) flying owns an Ecoflyer 135CDI from Robin. The engine is the A Class Mercedes engine modified by  Thielert (now Centurion). Performances and easy to fly were there till we discovered the many troubles and lack of reliability attached to the transformation. Then the maintenance costs increased dramatically, and this was part of the failed over of Thielert.
Socata (previously a subsidiary of EADS and now part of Daher) built from scratch an engine 230HP turbo charged. Even if the staff in charge was previously the one which mad the Renault 10 cylinders
leader in Formula One , it took them 10 years to make it reliable, but still very expensive…
My conclusion is: an engine made for a car is not made to be installed in a plane!
Max  Cointe
F-PMLH TriGear Kit #560
912ULS Airmaster 400 hours
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] De la part de Gary Leinberger
Envoyé : vendredi 27 janvier 2012 15:58
À : 'europa-list(at)matronics.com'
Objet : RE: Viking Aircraft engine
I looked at using auto engines in my Europa – the applications (car versus airplane) are just so different. While the base cost of these converted engines seems attractive, the problems soon run the cost (and the aggravation) far above the cost of a Rotax - just started my 912S and am impressed with it. Like all German/Austria equipment, if maintained by the book, they seem to run forever. After nine years of building the last thing I want is to experiment with an engine generally backed by an undercapitalized entrepreneur.
If you are just starting your build, my advice is to wait to buy. One never knows how long it will take to build and any savings in buying the engine earlier (prices do go up with inflation) are eaten up in maintenance on dried-out o-rings and required updates that are standard for new engines. I looked at the 912S when I started the build in 2003 and it was $15K or so list, and in 2010 bought my engine for $23K (with all the bits and shipping). This is about a 6% increase a year. But the engine is far superior to the 2003 engines (the U.S. Army required a bunch of very good changes) and Rotax improved the engine in other ways. Several other people that bought early (and cheaper) are paying more in the long run for an inferior early engine.
Gary Leinberger
A237
Hope to fly this spring.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Peter Zutrauen
Sent: Friday, January 27, 2012 8:24 AM
Subject: Re: Viking Aircraft engine
Pete
Will
Max8992
Europa XS #560 F-PMLH
paul.the.aviator(at)gmail
PostPosted: Fri Jan 27, 2012 8:21 am    Post subject: Viking Aircraft engine Reply with quote
Guys,
I'll toss my 2 cents worth into the ring on alternative engines.  Fristly I would like to preface my comments with the statement that if we didn't try new things then we would be still flying with stuff powered from designs that trace there roots back 50 years.  Come to think of it, if we didn't try new stuff then we wouldn't be even flying Europa's.
Installing alternative power plants is not for the faint of heart, even proven designs. I recently completed some cooling modifications to my 914 and it was a lot of testing, work, re work and more testing.  My modifications are trivial compared to something like a Viking.  Even conventional conversions such as the Jabaru have taken a lot of collective effort to get them to the point of being a viable alternative.
I don't want to discourage anyone from trying alternatives, but please be aware that once you move away from  the original design that you moving down a path that will consume considerable resources.
Cheers,  Paul
grahamsingleton(at)btinte
PostPosted: Fri Jan 27, 2012 8:47 am    Post subject: Viking Aircraft engine Reply with quote
Hi Paul
I agree with everything you say, I would add that even now the Jab is still not a viable alternative (imho) I onlyknow of one successful Jab 6 owner and he isn't completely satisfied.
Graham
From: Paul McAllister <paul.the.aviator(at)gmail.com>
Sent: Friday, 27 January 2012, 16:17
Subject: Re: Re: Viking Aircraft engine
Guys,
Cheers, Paul
[quote]http://www.matro====================
europapa
PostPosted: Fri Jan 27, 2012 9:20 am    Post subject: Re: Viking Aircraft engine Reply with quote
I have been interested in new aircraft engines for a long time and I have learned that there are more problems with the gearbox, the clutch or both than with the engine itself.
That´s why I wouldn't trust the the three cogs they call gearbox on the silent hektik engine.
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Jan 27, 2012 9:59 am    Post subject: Viking Aircraft engine Reply with quote
Hi! Graham /all
Right on the money ! ...and I certainly know a good amount of the hassle associated with the subject!
Regards Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: 27 January 2012 16:44
Hi Paul
Graham
Guys,
Cheers, Paul
mau11(at)free.fr
PostPosted: Fri Jan 27, 2012 10:20 am    Post subject: Viking Aircraft engine Reply with quote
An aircraft engine is a "good engine" when he have made ten years of flight life minimum! To resolve all problems.
Michel AUVRAY
fklein(at)orcasonline.com
PostPosted: Fri Jan 27, 2012 11:18 am    Post subject: Viking Aircraft engine Reply with quote
and the
problems
personally
CAM100.
Will...that would be Alex Bowman who flies out of Nanaimo, BC...he has
the CAM125 which is built around (I believe) a mid-80s Honda Civic
engine...and he's been quite satisfied w/ performance, ops, and
maintenance. He flew it to the EAA show at Arlington, WA back in 2004
or 5, and I've seen it at a fly-in at Pemberton, BC alongside Peter
Timm's Classic. Alex is now in his late 80s and has had some medical
issues which, I believe, have been the sole reason for why he has not
been burning holes in the sky w/ his Europa...it remains a low-time
aircraft, but I much admire what he has achieved. Incidentally, he
built his plane where he lives on a small island "off the grid", and
true to form, the manufacturers of the CAM engines have evaporated.
Though the success rate for auto engine conversions for aircraft use
may be low, Alex's CAM125 installation along w/ his Airmaster CS prop
has been one of the success stories...of course, it would be more
convincing to be able to point to say 10 Europas thus powered, each w/
a thousand hours and still going strong. Some listers may recall that
w/ the demise of the original Europa company, I attempted to assemble
a group of FWF'less builders to utilize Alex's production cowl molds
and experience w/ mating the CAM125 to the Europa, but alas, that
never happened.
Of course, auto engine conversions are a subset of the question of
whether or not one may choose to deviate from orthodoxy...anyone so
interested can do some web searches and find any number of scholarly
papers and descriptive narratives on the pros and cons of doing so.
For myself...as I continue my XS mono powered w/ a derivative of a
Subaru (the RAM Performance 140 hp, MPEFIed engine w/ an Autoflight
helical-geared PSRU)...I spent about 15 months molding the cowls,
designing and fabricating the mounting frame, ditto for cooling and
tuned exhaust systems, plus temp & pressure sensors...176# "wet" but
excluding cooling & exhaust systems.
I find that a high tolerance for ambiguity has been essential...
I will post test/performance data when available.
I trust that there's a place in the Europa community for the
occasional deviant,
Fred
 Filesize:  75.36 KB
 Viewed:  23953 Time(s)
 Filesize:  44.39 KB
ivanshaw(at)btinternet.co
PostPosted: Fri Jan 27, 2012 12:01 pm    Post subject: Viking Aircraft engine Reply with quote
Words of wisdom in deed
Ivan
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
Sent: 27 January 2012 18:18
To: europa-list
Michel AUVRAY
http://www.matronics.com/Navigator?Europa-List< - MATRONICS WEB FORUMS -
Speedbird
PostPosted: Fri Jan 27, 2012 12:33 pm    Post subject: Viking Aircraft engine Reply with quote
The "other" Ivan agrees!
Cheers!
Ivan Midwing
Sweden
KajakCenter Halland
Org nr; 5805034625
P: +46 703 621310
P: +46 704 694444
27 jan 2012 kl. 20:58 skrev "Ivan Shaw" <ivanshaw(at)btinternet.com (ivanshaw(at)btinternet.com)>:
[quote]p.MsoNormal {margin-left:7.5pt;} <![endif]--> <![endif]-->
Ivan
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
To: europa-list
Michel AUVRAY
rlborger(at)mac.com
PostPosted: Fri Jan 27, 2012 12:34 pm    Post subject: Viking Aircraft engine Reply with quote
Bill,
Think about all that has to be developed to put in a non-standard engine.
1. New cowling - probably has to be made from scratch. Have you ever made a female mold?
2. New baffling - probably will require multiple tries and much effort to get the cooling right.
3. New engine mount - you'll be lucky to get it right the first time.
4. New Plumbing - probably not too terrible once the above has been settled.
5. New Electrical - again, probably not too terrible once the above has been settled. Depends a lot on the electrical requirements of the engine, F/I, ignition, etc.
6. New Physical connections - throttle, mixture, carb heat, etc.
The Europa was designed for and around the Rotax 9xx engine. A complete FWF kit is available for purchase and it all works (at least it did on mine).
Electrical and plumbing are all worked out, just do it like the instructions say. Physical connections are all worked out for you (no mixture or carb heat to fuss over). They are light, powerful, economical and reliable (if you follow the instructions). No they are not perfect but they are pretty darn good.
Anything else and you become the chief engineer and developer on a serious experimental project.
Ya pays your money and takes your chances. (And do check into Mr. Eggenfeller) Good luck which ever way you go.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 26, 2012, at 12:18 PM, William McClellan wrote:
Bud or anyone,
Bill McClellan
rlborger(at)mac.com
PostPosted: Fri Jan 27, 2012 1:01 pm    Post subject: Viking Aircraft engine Reply with quote
Fred,
There's plenty of room in the Europa (and total OBAM) community for you wild and crazy guys. You are out there on the pointy end of this whole Experimental thing. God bless you for all your efforts, failures and successes. I hope to see you at RR this year.
BTW, nice looking cowl!
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Will...that would be Alex Bowman who flies out of Nanaimo, BC...he has the CAM125 which is built around (I believe) a mid-80s Honda Civic engine...and he's been quite satisfied w/ performance, ops, and maintenance. He flew it to the EAA show at Arlington, WA back in 2004 or 5, and I've seen it at a fly-in at Pemberton, BC alongside Peter Timm's Classic. Alex is now in his late 80s and has had some medical issues which, I believe, have been the sole reason for why he has not been burning holes in the sky w/ his Europa...it remains a low-time aircraft, but I much admire what he has achieved. Incidentally, he built his plane where he lives on a small island "off the grid", and true to form, the manufacturers of the CAM engines have evaporated.
Though the success rate for auto engine conversions for aircraft use may be low, Alex's CAM125 installation along w/ his Airmaster CS prop has been one of the success stories...of course, it would be more convincing to be able to point to say 10 Europas thus powered, each w/ a thousand hours and still going strong. Some listers may recall that w/ the demise of the original Europa company, I attempted to assemble a group of FWF'less builders to utilize Alex's production cowl molds and experience w/ mating the CAM125 to the Europa, but alas, that never happened.
Of course, auto engine conversions are a subset of the question of whether or not one may choose to deviate from orthodoxy...anyone so interested can do some web searches and find any number of scholarly papers and descriptive narratives on the pros and cons of doing so.
For myself...as I continue my XS mono powered w/ a derivative of a Subaru (the RAM Performance 140 hp, MPEFIed engine w/ an Autoflight helical-geared PSRU)...I spent about 15 months molding the cowls, designing and fabricating the mounting frame, ditto for cooling and tuned exhaust systems, plus temp & pressure sensors...176# "wet" but excluding cooling & exhaust systems.
I trust that there's a place in the Europa community for the occasional deviant,
Fred
<DSCN3071.jpg>
<DSCN3688.jpg>
Goto page 1, 2  Next
Page 1 of 2
