bicyclop(at)pacbell.net Guest
Posted: Thu Jan 26, 2012 3:44 pm Post subject: Fuses instead of breakers |
I'll try and find it. I know that Klaus is adamant about having a breaker and not a fuse.
Ed
On 1/25/2012 9:56 AM, Robert L. Nuckolls, III wrote: [quote] At 11:24 AM 1/25/2012, you wrote:
Just one more thing to think about if you are doing this with a Lightspeed ignition. From what I've read, there is some sort of crowbar inside the ignition module to protect it from an overvoltage event. If a fuse is fitted and the crowbar kicks it, you'll not be able to reset it as easily as with a breaker - if you can reach the fuse at all. I've heard of at least one case where an airplane was brought down because it was wired differently than the installation instructions in that regard.
Can you elaborate on what you've read and give us sources?
I'm unaware of any crowbar ov protection built into the
LSE system. Is this called out in any of their published
literature? I found this on the Lightspeed site:
Electrical System Requirements
All Plasma CDI systems can be used with 12 or 24 volt electrical systems. Input voltages above 35 volts or reversed polarity can cause system damage.
For this reason it is mandatory that all aircraft using Plasma CD Ignitions are equipped with over-voltage protection in their alternator charging system(s). Over-voltage protection is a requirement for certified aircraft. Power connection must be directly to the battery terminals to avoid voltage spikes and electrical noise. Aluminum should never be used as an electrical conductor for the Plasma CDI. Use only the supplied aircraft quality stranded wire.
Minimum supply voltage for starting is 6.5 Volts.
Minimum operating voltage is 5.5 Volts.
This statement argues against any built-in ov
protection. At the same time, the very wide operating
voltage for the system guarantees that a properly
designed 14v system will NEVER offer a threat to
the LSE system.
I am presently participating in an analysis of
cause and effect for simultaneous failure of
dual LSE systems. Root cause for that event
was a failure to craft a failure tolerant
architecture . . . a design goal which is foundation
for all efforts here on the AeroElectric-List.
It's a certainty that no builder who participates
here on the List will suffer such an event.
Bob . . . [b]
Posted: Thu Jan 26, 2012 5:02 pm Post subject: Fuses instead of breakers |
At 02:43 PM 1/26/2012, you wrote:
--> AeroElectric-List message posted by: Jeff Page <jpx(at)qenesis.com>
At 04:27 PM 1/25/2012, you wrote:
I merely meant that a 5A fuse and a 5A breaker behave differently, but since
the protection type is not specified, the rule could be interpreted as
a maximum of a 5A fuse.
Oh absolutely. The fact that such a level was
given without an accompanying I(squared)T time
constant goes to suggest the arbitrary nature
of the value. As we've discussed here before,
seeing a 5A number on a protective device
is a small bit of knowledge about how the
device performs. I'd have to go arm-wrestle with
dragons to get a 10A fuse attached to a battery
bus in a TC aircraft . . . but you and I know
that a 10A ATC fuse is faster than a miniature
5A breaker and is . . . therefore . . . a
rational crash safety substitute for always-hot
feeders.
What controls the pump motor . . . a contactor?
The float manufacturer (Montana) supplies the pump and control circuitry
already mounted. The relays are Bosch 12V/20A 0 332 209 137
The diagram shows a 25A pullable breaker feeding the relays. A 1A fuse
protects the relay control wiring. So a pullable breaker would be a
convenient way to deal with a stuck relay or a defective pressure switch. That
is perhaps what I should do.
Agreed. Those relays are not specifically
crafted for motor control service. Having
a crew-operated means by which a runaway
can be controlled seems prudent.
I will be interested in the results of your discussions with Klaus
about powering the Lightspeed ignition. I know two people who are
about to install these.
There are no doubt many hundreds if not
thousands of these flying. To the best of my
knowledge, they are not "special" devices
deserving of extra-ordinary attention.
Discussions not withstanding, the published
current draw values for LSE products say that
the greatest current draw for a 6-cylinder
system is 2.1A at 13.8 volts.
[img]cid:.0[/img]
Given that the device features a switchmode power
supply with a wide range of operating voltages,
we know that this is a constant-power mode of
operation. So 2.1 x 13.8 sez the critter needs
right at 30 watts for operation at MAX RPM. One
can expect the current to climb as voltage goes
down . . . so if you're operating battery only
and the battery is down on that 11-volt-slide-
to-darkness, the ignition system current will
have risen to something around 2.7 amps.
Likewise, operating current on a 29 volt bus
will be down around 1.0 amps. The 4-Cylinder
systems are still more frugal in their demands
on the electrical system.
Thanks again for all the great advice. Even while lurking, I learn
something new and useful every week !
Thanks for getting involved and asking. It's
through EXCHANGES of observation and events that
I learn useful things too. Folks have often
asked why the 'Connection is up to Revision 12
in "just 23 years of publication". I tell
them that my education came from a collaboration
with colleagues who spoke engineereze. And we
hammered on a different class of airplane. When I
sat down to do the first chapters of the
'Connection, I realized that I could not answer
questions without knowing what the questions
are. Further, they needed to be written in
OBAMeze.
It's the collective participation of all
the builders on the List/emails/telephone/
seminars that drive what goes into the
next revision. It's truly a work in progress
that would not have happened without this
join venture arena.
85.1 KB |
14221 Time(s) |
Posted: Thu Jan 26, 2012 5:21 pm Post subject: Fuses instead of breakers |
| Quote: | Without getting into the discussion of whether the design should or
shouldn't be modified, my purpose on posting (now and back in early
2009) is simply to make those with dual LSE ignition setups aware
that fuses can't be arbitrarily substituted for CBs in this case.
I would agree that when the installed system is
at risk for an event triggered by conditions
of installation and/or manufacturing mod levels
then the system is indeed still 'experimental'.
Now that the 'student installer' has graduated
from the lab to the working environment, I'll
suggest that the risk for substitution is
microscopically low.
This is something that we must always keep in
mind. Instructions and ratings are important.
When in doubt, go measure it. It's entirely
possible that the builder who experienced this
event might not have survived to give us his
particular dark-n-stormy-night narrative.
We wouldn't be having this discussion about that
particular event . . . indeed we wouldn't even
know the details.
But the fact is that he DID experience a trip in
a critical system power feeder which prompted further
investigation and he shared his discovery with
the rest of us. That information goes to making
us MORE confident, not less.
I recall a discussion here on the list a some
time back where wires in the wreckage were found
pulled out of the terminal crimps. Hmmm . . .
we'll never know if this failure-to-follow the
instructions precipitated the event . . . but
the overt evidence of failure in craftsmanship
does raise valid questions.
So if one chooses to explore departures from
published instructions, any such departure needs
to be considered carefully. It's not difficult,
just rigorous. Get on the List and let's talk
about it. Bundle all the concerns together and
develop a plan to morph an experiment into a
recipe for success.
But if you don't want to be an explorer or
crafter of new recipes, that's fine too. The
vast majority of our brothers building OBAM
aircraft are not explorers and the last thing
they want to do is experiment. This venue for
acquiring a personally owned aircraft recognizes
that too. Most never frequent this List and
don't need to . . . their relationship with
their airplane's electrical system is no
different than the average spam can driver
in a 172 . . . and that's okay.
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Fri Jan 27, 2012 11:51 am Post subject: Fuses instead of breakers |
| Quote: | >......Are there any other reasons why a pullable circuit breaker
would be >preferred for this situation ?
There are two seperate potential issues here. First, is there an
alternate source
of hydraulic pressure? If you have a practical hand pump available, then
the nuisance trip issue is just that. If the electric pump is your
only practical
source of hydraulic power, then things are a little different. I
could envision
a scenario where the motor for the hydraulic pump has degraded such that
the current draw trips the circuit protection, leaving you with a
gear up landing,
or potentially worse, a partial gear landing. Personally, I would prefer
resettable circuit protection in that scenario.
There is a manual hand pump, so no emergency is created.
| Quote: | "I have had to do one inflight reset on the Plasma III on one system
once. The reset was successful and power was restored to the unit. I
removed the unit and sent it back to Klaus for inspection. The fault
was determined to be an overheat situation. That unit was located in
an area without any real ventilation and without an form of cooling
while operation in Arizona during the summer. the compartment temp
was estimated to have exceeded 200 deg. F. The unit was modified to
the latest version (lower heat output components and a ventilation
port. The aircraft was modified to provide air circulation in that
compartment. After 300+ hours on that unit no faults noted. The
point, when the unit faulted it tripped the CB and was then reset
and provided service throughout the remainder of that flight. "
Hmmm. If it immediately resumed functioning after resetting the
breaker, perhaps
the ignition never failed, but the heat (and probably higher currents
operating at
high temperatures) caused the breaker to nuisance trip.
| Quote: | I will be interested in the results of your discussions with Klaus
< deserving of extra-ordinary attention.
They just get extra attention since pilots are more concerned with their
ignition failing than say their nav lights going out
| Quote: | The relays are Bosch 12V/20A 0 332 209 137
A pullable breaker would stop current flow caused by a stuck relay,
and the manual pump could be used to operate the gear, so there is
no significant flight risk.
Those relays do look undersized to me.
Better relays might reduce long term maintenance however. Or perhaps
just carry a spare along might be the most practical approach. I think
the latter ?
Jeff Page
Dream Aircraft Tundra #10
Posted: Fri Jan 27, 2012 12:43 pm Post subject: Fuses instead of breakers |
Then a robust fuse solution goes toward a cleaner
panel and possibly a cleaner plan B. When THIS
happens, do THAT . . . every time.
> . . .<snip>
>The point, when the unit faulted it tripped the CB and was then reset
>and provided service throughout the remainder of that flight."
breaker, perhaps the ignition never failed, but the heat (and probably
higher currents operating at high temperatures) caused the breaker
to nuisance trip.
The keyword here is "nuisance". I've had to cut the
TC guys some slack for being somewhat submissive to
nuisance trips . . . to strive for the elegant solution
can sometimes be very time consuming and expensive.
One is well advised to trade off cost/benefit ratios.
In the OBAM aircraft world, we're not only able, we are
encouraged to refine any system's configuration in way
that increases the displacement between it's experimental
roots and an enduring recipe for success.
But when one gets a 'nuisance trip' with current protection
that is nearly 2.5 times the published draw numbers . . .
there are reasons to seek answers to some serious questions.
There is a clash of postulates which beg resolution.
ABSOLUTELY! Which is why I've recommended that electrically
dependent engine accessories drive from always hot battery
bus with totally independent power paths. If two ignition
systems require power and two batteries are available, then
split the systems between the batteries.
But when a 2A device trips a 5A breaker . . . well . . .
Great.
the latter ?
I thought we were talking about a much larger
hydraulic system. The amount of snort needed to
operate the gear in floats is much smaller than
that used on a GlasAir or Lancair. I think these
relays will be fine and since you have a backup
hand pump, your risks are quite low.
jbr79r(at)yahoo.com Guest
Posted: Fri Jan 27, 2012 3:37 pm Post subject: Fuses instead of breakers |
Hi Bob
I built a cold air induction for my glasair and will have an alternate filtered air when on the ground. I take off with 10 deg of flaps. Could there be a way to sequence this alternate air door with the flaps? When the flaps come up the the door opens to allow ram air and when the flaps come down it closes the ram air. Am I getting to complicated?
Jim
James Robinson Glasair lll N79R Spanish Fork UT U77
Sent: Friday, January 27, 2012 1:40 PM
Subject: Re: Re: Fuses instead of breakers
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
. . .<snip>
to nuisance trip.
Great.
the latter ?
mrspudandcompany(at)veriz Guest
Posted: Fri Jan 27, 2012 4:56 pm Post subject: Fuses instead of breakers |
Hi Bob
Jim
Is your alternate air door electrically
operated? If so, you can use a switch, activated by the flaps, to open the
door when flaps are up, and close as soon as flaps are cycled down.
Roger
 Download |
| Filename: |
winmail.dat |
3.92 KB |
| Downloaded: |
851 Time(s) |
Posted: Fri Jan 27, 2012 6:47 pm Post subject: Fuses instead of breakers |
Thanks Roger
It was going to be a simple cable operation, but I thought I would explore other alternatives before making a final decision.
Jim
From: ROGER & JEAN CURTIS <mrspudandcompany(at)verizon.net>
Sent: Friday, January 27, 2012 5:53 PM
Subject: RE: AeroElectric-List: Re: Fuses instead of breakers
Hi Bob
Jim
Roger
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Sat Jan 28, 2012 5:53 am Post subject: Fuses instead of breakers |
Back when this came up a couple years ago, and Bob C and I discussed possible solutions to this, I did some testing with a 10amp breaker and a 7.5 amp breaker switch. Klaus calls out for power to always be hot from the battery which is not something I am fond of so I figured a switch breaker would be a better choice than two breakers and a switch. In running these two devices in series with the approx length of wire needed, I was able to repeatedly get the breaker switch to "blow" without tripping the 10amp. I know this is a bit of a given but I wanted to see it for myself.
I have a dual LSE3 config and I'm now considering simplifying this by having one off of my vp200 and the other direct to the battery with just a 7.5 amp fuse or breaker. This way if there is a nuisance trip, I can reset via the vp200 and run off a single lse if needed until I land. Of course that still does leave a potential failure mode should both trip and the vp200 connected one not come back online.
Michael
On Jan 26, 2012, at 2:21 PM, "bcondrey" <bob.condrey(at)baesystems.com> wrote:
FWIW, this subject has been discussed before on the AeroElectric list. Use the search function for the words "Klaus" and "crowbar" and you'll find a couple threads from early 2009. Turns out that it's not just over-voltage events that will cause them to crowbar but apparently over-temp. This was posted on Feb 1, 2009:
point, when the unit faulted it tripped the CB and was then reset and
Without getting into the discussion of whether the design should or shouldn't be modified, my purpose on posting (now and back in early 2009) is simply to make those with dual LSE ignition setups aware that fuses can't be arbitrarily substituted for CBs in this case.
Bob C
http://forums.matronics.com/viewtopic.php?p=364895#364895
bcondrey
Posted: Sat Jan 28, 2012 7:36 am Post subject: Re: Fuses instead of breakers |
In the spirit of trying to move the ball forward I'll suggest that fusible links to protect the battery feeders are probably the best way to go in a cost/weight/reliability trade. They provide protection of the feeder wires, have a slow time constant so a panel CB will trip first, are inexpensive and lightweight. A larger CB would does the job also but with more weight and cost.
If you've only got a single LSE then maybe no issue since you'll always have a mag to fall back on. If you're running a pair of them however, you need to fully understand failure modes and mitigate the risks. This thread started with the question of whether a fuse would be an adequate substitute for a CB in this application. Given what I believe to be true about the ignitions, the answer is a qualified NO. Qualified because it's only a REAL issue if you don't have a mag to fall back on. Installing as recommended by the manufacturer using a panel mounted CB gives you a solid install. Just make sure you don't do something that compromises that by putting a fuse upstream or substituting a fuse for the panel CB. If you want to protect the feeder use a slightly larger CB or fusible link. You can do a very simple experiment as Michael did to validate the fuse issue (when upstream of a CB).
Bob C
Posted: Sat Jan 28, 2012 7:53 am Post subject: Fuses instead of breakers |
At 07:49 AM 1/28/2012, you wrote:
Sausen)" <rvbuilder(at)sausen.net>
It's not always a 'given'. Thermally operated feeder protection
have what is called and I(squared)*T constant. Meaning that if
you plot trip times versus fault current, you find that doubling
the fault current produces a trip in 1/4th the time.
Combine this knowledge with the manufacturer's specs for I(squared)*T
for any given device and you can deduce the probability that one
device will trip before the other. But understand too that thermally
activated circuit protection are not "calibrated devices". Look at
the response curves for an exemplar miniature breaker . . .
http://www.aeroelectric.com/Pictures/Curves/Exemplar_Circuit-Breaker_Trip_Response.pdf
For any given fault current combined with ambient temperature
the trip times can vary widely. On top of that variation you
can add "preheat" influences and manufacturing tolerances.
Bottom line is that one should be very cautious about putting
two protective devices in series with any notions about one
tripping before the other.
Your power company has done these studies. As you travel
up the energy-chain from a hair dryer plugged into the
wall to the alternator that provides watt-seconds to dry
your hair, each protective device upstream of any
other protective device is many times more robust.
You don't want the protective device in hair dryer
being over stressed but the whole neighborhood goes
dark instead.
Let's talk design goals:
(1) It's a GOOD thing to be able to cut all power to
every other accessory in the airplane and NOT have
the engine stop. Solution - electronic ignitions
and fuel pumps should power from an always hot
battery bus.
(2) It's a GOOD thing to have always hot wires in
the airplane limited in their ability to produce
fault currents likely to ignite post crash fires.
Solution - protect such feeders at the battery bus
with I(squared)*T constants that reduce such risk
to acceptable levels. Question - what's an acceptable
level? Answer - Don't know from first hand knowledge.
However, folks-who-claim-to-know-more-about-airplanes-
than-we-do have declared that 5A circuit protection
is the golden number.
Exceptions - They did not specify an I(squared)*T
constant for that protection.
What's the prudent system integrator to do? Well,
for starters we can deduce that the exemplar 5A
breaker common to GA, AT, and Military aircraft
is "blessed" so we are on reasonably sound foundation
using that performance for a baseline. What's good
for 100,000 airplanes is good for my RV.
Okay, it's easily demonstrated that a miniature 5A
breaker in series with a 10A ATC fuse will not
open before the fuse does. But what are the risks
for raising the always hot feeder protection to
say 15 or 20A ATC fuse? Who knows? It's a certainty
that some agency would love to have a $million$ budget
to research an answer and then write rules about
it.
So what's a reasonable approach for standing off
the worries amongst those in our numbers who do
worry about it a lot?
I suggest that it is quite simple:
But a bigger fuse in at the battery bus. I don't
care if you go to 20A. 20A wire too? No. We already
KNOW that a 20A steady state current will not burn
a 22AWG wire.
http://aeroelectric.com/Pictures/Wire/22AWG_20A.pdf
So wire with 20AWG or even 18AWG. Remember, we're
talking about crash safety. What is the likelihood
that your 20A/18AWG, always-hot feeder will be
placed in a potential position for setting you
on fire? Very low. Further, keep in mind that an
always hot wire in a wreck may not get hard-faulted
in a way that would open even the 5A breaker. A
soft-fault on a 12 volt battery feeder protected
at 5A is VERY capable of starting fires. So that
5A number goes more to setting rules and stopping
arguments than it does to any scientific hedge
against conflagration.
The rational solution:
(1) I suggest that agonizing over fuse sizes
is a waste of intellectual and emotional
capital. Make the fuse BIG in comparison to system
DEMAND. Make the wire mechanically robust which
makes it QUITE capable of meeting system demands
but not necessarily capable of meeting AC43-13
temperature rise recommendations - you're never going
to load the wire that hard. This is a special
case that does not fit the legacy design goals
for wire/breaker/fuse sizing.
(2) Don't get wrapped around the axle of crash safety.
That problem has been painted with a VERY broad
brush. Better that you crash for reasons
beyond your control than because ignition or fuel
pump supply feeders protection were too light
and the engine quit.
It's my considered recommendation that the LSE
system not depend on ANY other features in your
power distribution beyond a fuse at the battery
bus (not a breaker . . . we want it to be FAST)
and a switch on the panel. You want to be able
to shut the MASTER off without having the engine
quit. Same thing for your fuel pumps if you have
them.
Remove the term NUISANCE TRIP from the lexicon
of talking about your airplane's electrical systems.
The only circuits that EVER nuisance trip are those
not properly crafted to design goals . . . like
those stated above.
ANY time you hear a hangar-tale or ramp-rumor
about somebody's system tripping but the day was
saved by pushing a breaker back in, then thank
your stars for the fact that you participate
on the AeroElectric-List and folks have helped
you design for robustness. YOUR airplane is not
going to suffer nuisance trips. If it EVER does,
you'll find out why and make appropriate changes
to see that it never happens again. Then you'll
share that event with the rest of us on the List
just in case you've discovered some new condition
that others need to be aware of.
Further, if we do find that an LSE product is
fitted with any sort of CROWBAR ov protection
(which I doubt) then I think it is prudent
to ask that your devices be delivered with that
feature disabled. There is no good reason to
build such a feature into any accessory. Even
LSE says it's mandatory that your SHIP'S SYSTEM
be fitted with ov protection.
Finally, if the foregoing does not give you sufficient
confidence based upon understanding the potential effects
of departing from the manufacturer's recipe for
success, then please follow the manufacture's
recommendations TO THE LETTER. Keeping the engine
running should be the LEAST of your worries.
Posted: Sat Jan 28, 2012 8:05 am Post subject: Fuses instead of breakers |
Except that they are overly robust and do not even
come close to addressing concerns for crash safety.
A 20A ATC fuse is an excellent middle ground that
offers approximately 10X operational robustness
factor and still reacts quickly to crash induced
hard faults.
There is no good reason to "double up" with breakers
on the panel. Fuses/breaker/limiters/links are to protect
wires. Only ONE is needed between the ignition system's
power source and the electronics. So the up-sized fuse
makes the most sense.
That's what the List is all about . . .
to fall back on.
Are you offered a dual failure hypothesis?
Operationally correct but no consideration
for crash-safety.
Don't over-simply such experiments. The devil is
in the details. Better you have ONE protective
device crafted for robustness while not seriously
disregarding crash safety.
Tundra10
Posted: Sat Jan 28, 2012 10:27 am Post subject: Fuses instead of breakers |
| Quote: | I thought we were talking about a much larger
So perhaps 10AWG wire is not required ?
The installation instructions show 12AWG with a 25A pullable breaker.
Many builders are happily flying with this installation.
The hydralic pump motor is a Parker-Oildyne series 108 12VDC permanent
magnet motor code AE 0.327".
The pressure switches are 500psi. I assume this means that there will
be brief spikes above
this pressure at the motor when it first starts up, but after the
fluid is moving, it must be less than 500psi.
Based on the small graph, the current at 500psi is 17A to produce a
flow of 51 cubic inches per minute, but I have no method to estimate
the inrush current as the motor starts up. The graph stops at 2000psi
at 48A continuous (but not for long according to the intermittent use
temperature graph). The successful use of small relays would indicate
the inrush current is not significant ?
I don't know how to estimate the inrush current, nor the amount of
voltage sag that would negatively impact the motor at startup.
So I can't calculate any possible advantages of heavier wire
Jeff Page
Posted: Sat Jan 28, 2012 12:12 pm Post subject: Fuses instead of breakers |
Well, let's run the numbers and see . . .
AHA! REAL stick-to-your-grey-matter data. It's amazing
what you can discover if given a few numbers. In this case:
[img]cid:.0[/img]
Okay. The critical numbers here are the cubic inch displacement
per revolution (0.0321). The current at any two flow points which
gives you the slope of the line in PSI/AMP. The point where
pressure goes to zero but flow is max. This point establishes
the internal energy dissipation in motor and pump. We could
develop all the torque and CEMF constants for the motor
in numbers . . . but the questions yield nicely to a
pencil and straight-edge solution too.
I've extended the curves to the point where flow goes to
zero (stall) and current goes to zero (which provides
the anchor point for zero load RPM of the motor. But to
get to THE question of the moment, I deduce that stall
current for this motor is on the order of 70 amps. This
current is EQUAL to that demanded of a 3200 PSI condition
which can never be achieved because of the relief valves.
be brief spikes above this pressure at the motor when it first starts
up, but after the fluid is moving, it must be less than 500psi.
Actually no. Pressure induced motor current is dominant only
after the motor is stable at some speed. During start up, the
flows can be no greater than what the system back pressure
allows and is probably quite low. Motor current is high because
the armature is accelerating to a stable operating point. If
pressure reliefs are set for 500 psi then the maximum operating
current for the motor will be 17A and probably achieved only
when all cylinders reach their limits causing flow resistance
to spike. Only then would we expect the pressure to climb
rapidly for the moon . . . and were it NOT for relief valves,
the current would approach stall or a hose will blow off.
Now, if you started the motor up to FURTHER extend/retract
the gear against hard stops, you get the same 70A inrush
which would fall only to 17A and stay there as the relief valves
cracked. System pressure would never exceed 500 PSI.
temperature graph).
Now you know how to do it.
The successful use of small relays would indicate the inrush
No, it's always significant.
Keep in mind that system wiring can have a profound
effect on inrush currents. 70A at 12v implies a motor
resistance of 12/70 or 0.17 ohms. 10AWG wire is one
millohm per foot. So adding say 10' of 10AWG in the total
loop resistance takes your motor + wire up to 180
milliohms for a new inrush of 12/.180 or 66 amps. Of
course, this doesn't account for any sag in electrical
system voltage during inrush. 12AWG wire is 1.6 milliohms
per foot so inrush comes down some more.
Since the running current cannot exceed 17A due to
action of relief valves, you COULD consider a 14AWG
or even 16AWG feeder for the purpose of limiting
inrush . . . assuming that becomes a design goal.
This would have no effect on available system pressure
because that is set by relief valves. It WOULD reduce
available flow at that pressure because motor voltage
hence RPM is slightly reduced. Wired per the instructions,
it seems that your inrush will be on the order of 50-65
amps which is no big deal on a 30A relay.
The 'advantages' if any are murky. The system you're installing
has a successful track record with components specified
by the manufacturer. I can see no compelling reason
to alter that recipe.
156.45 KB |
14190 Time(s) |
Tundra10
Posted: Sun Jan 29, 2012 8:52 am Post subject: Fuses instead of breakers |
Thank you ever so much for your analysis, and your time that you
obviously took to teach it. I was looking at that graph, thinking it
appeared they were providing lots of information, yet it seemed
insufficient.
Now that you have taught me how easy it is to extend the lines, I am
disappointed I didn't think of that myself, but now I can use that
technique to great benefit in the future.
Also very important, is that I can wire my aircraft, _knowing_ that
the installation is the best possible compromise of all the factors,
rather than blindly following the installation instructions of a
company who's expertise is building floats, rather than electrical
design.
In this case, your analysis confirms their installation instructions
are excellent, providing confidence that they offer a solid product.
Thanks !!
Jeff Page
natsuto Guest
Posted: Tue Feb 14, 2012 6:03 pm Post subject: Re: Fuses instead of breakers |
I promptly pull the hangar and wired directly to the battery Klaus's instructions. I've always wanted, he wrote: There is a reason. Has been working ever since.
Posted: Wed Feb 15, 2012 6:35 am Post subject: Fuses instead of breakers |
At 08:03 PM 2/14/2012, you wrote:
When one is unsure of elegant alternatives
to common sense design goals, it is good to follow
the manufacturer's instructions.
At the same time, the manufacturer's instructions
my be only one of several recipes for success.
This is how the "experimental" airplane becomes
a teaching tool where new recipes can be considered
and proven. Just as the student in the chemistry
lab is learning by 'experiment' the teacher knows the
outcome of every lesson. For the teacher, the lab
is a tool to share recipes and the behavior of
their ingredients . . . anything but an experiment.
For the student, the experience morphs an experiment
into useful knowledge and skills. The next time that
recipe is repeated, the outcome is predictable.
At the same time, the teacher is ever mindful of
individual willingness to expand on their experimental
experiences. The explorer is well advised to temper
their quest for discovery with any admonition the
teacher may offer like, "Don't do that! You'll set
the lab on fire . . . or put your eye out!"
The word experimental is synonymous with explore
and discovery. But just as the automotive industry
is discovering that the lithium battery may not
yet be ready for prime time (perhaps influenced
by institutional pressure to 'hurry up and save
the planet'?) they have learned a lot and are still
in the discovery phase.
In experimental aviation we have a rich
library of historical successes (and failures)
to study. The trick is to shun any form of
pressure, be it institutional or from the hangar
mate next door. In experimental aviation we need
not "launch any new recipe into the sky before it's
time."
