SWR Meter
mrspudandcompany(at)veriz
PostPosted: Sat Jan 21, 2012 11:02 am    Post subject: SWR Meter Reply with quote
I have a Vintage Sears SWR / FS meter which appears to be
the same as the Cal Com Model 9856. Can this be used to check the antenna
on aircraft nav com radios? If so, how do I set it up for use?
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.52 KB
 Downloaded:  286 Time(s)
PostPosted: Sat Jan 21, 2012 1:58 pm    Post subject: SWR Meter Reply with quote
Roger
This is no doubt an excellent example of a
transmission line sampling reflectometer. Dozens
of products of this genre' were manufactured
and they are quite common.
Float Flyr
PostPosted: Sat Jan 21, 2012 2:51 pm    Post subject: SWR Meter Reply with quote
I wouldn't use this type of SWR meter on anything north of 50 mHz. Find a
ham or telco tech who used to work on microwave equipment to test your
antenna. Such a person might also advise you on things like ground planes
and antenna location. For certified aircraft the work should be signed off
by a certified avionics shop.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Jan 21, 2012 2:52 pm    Post subject: SWR Meter Reply with quote
I forgot to say there was at least one Heathkit VHF SWR/FS meter on E-Bay a
few minutes ago. Not the highest quality meter but it will put you in the
ball park.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sat Jan 21, 2012 4:29 pm    Post subject: SWR Meter Reply with quote
At 03:54 PM 1/21/2012, you wrote:
<nuckolls.bob(at)aeroelectric.com>
Roger
and they are quite common. (insert OOPS here
when I sent the response too soon).
I fumbled the ball when I changed the subject line
and my complete response didn't get tacked onto this
thread. Be sure to get the whole 9-yard response under
a similar subject line.
PostPosted: Sat Jan 21, 2012 6:45 pm    Post subject: SWR Meter Reply with quote
Roger
Thanks Guys,
It appears that I have a unit suitable for the CB band.
Since they are reasonably priced I will purchase a new one in the correct
frequency band.
Roger
winmail.dat
 Filesize:  3.96 KB
 Downloaded:  292 Time(s)
