donaho1(at)verizon.net Guest
Posted: Fri Jan 20, 2012 2:12 pm Post subject: 2.5 " Ivo spacer |
My spacer is made from aluminum, ( I don`t know what grade). Prop and
spacer are held onto the prop flange with six long AN bolts, safety
wired. Too cold (17 degrees) and dark to go measure them tonight. If
you need their length, let me know and I will measure them tomorrow
and get back to you. I can also take a picture if you need it. Lanny N598LF
tombaisley
Posted: Fri Jan 20, 2012 2:41 pm Post subject: Re: 2.5 |
I have a Rotex and the hub is metric, I have to find M8 bolts 125mm long (5") with drilled heads. Looking for a source
Mike Welch
Posted: Fri Jan 20, 2012 2:58 pm Post subject: 2.5 " Ivo spacer |
| Quote: | --> Kolb-List message posted by: "tombaisley" <tombaisley(at)yahoo.com (tombaisley(at)yahoo.com)>
Have you considered IvoProp?
