lwinger
Posted: Wed Jan 18, 2012 4:49 pm Post subject: Transponder antenna location |
On the 601XL or 650, where have builders placed the transponder antenna? I'm considering a location on the bottom of the aircraft, just behind the center spar and under the seat area. The advantages of that location seem to be a short coax run, minimizing signal loss. The disadvantages might be shadow effect on the ground.
I would appreciate your thoughts before I drill holes. Thanks.
Larry Winger
Tustin, CA
CH 650B / Corvair
Wiring
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
larrycmcfarland(at)gmail. Guest
Posted: Wed Jan 18, 2012 5:09 pm Post subject: Transponder antenna location |
Hi Larry,
I placed my transponder antenna just behind the seats thru the belly and have had no problems with
transmission or signal. Radio antennae went thru the back top skin and returns opposite side from the transponder cable. Coaxial signals don’t affect each other this way.
Larry McFarland at www.macsmachine.com
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Larry Winger
Sent: Wednesday, January 18, 2012 6:44 PM
Subject: Transponder antenna location
Larry Winger
Tustin, CA
CH 650B / Corvair
Wiring
| Quote: | | http://www.matronics.com/Navigator?Zenith-List< - MATRONICS WEB FORUMS - | 01234567
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Jan 18, 2012 5:09 pm Post subject: Re: Transponder antenna location |
Larry,
My transponder antenna is right behind the passenger seat going out the bottom of the fuselage. No complaints from ATC yet about being able to see me.
_________________ David Gallagher
Cincinnati, OH area |
psm(at)att.net Guest
Posted: Wed Jan 18, 2012 5:20 pm Post subject: Transponder antenna location |
Hi Larry,
I put mine behind the seats in the middle of the bottom skin. I wouldn't lose any sleep about signal loss in the coax cable. I have had my transponder certified and used it with ATC with no complaints from anyone.
Paul
Zodiac XL in phase I flight test ~25 hours
On 1/18/2012 4:43 PM, Larry Winger wrote: [quote]On the 601XL or 650, where have builders placed the transponder antenna? I'm considering a location on the bottom of the aircraft, just behind the center spar and under the seat area. The advantages of that location seem to be a short coax run, minimizing signal loss. The disadvantages might be shadow effect on the ground.
Larry Winger
Tustin, CA
CH 650B / Corvair
Wiring
bryanmmartin
Posted: Wed Jan 18, 2012 5:36 pm Post subject: Transponder antenna location |
On Jan 18, 2012, at 6:43 PM, Larry Winger wrote:
| Quote: | On the 601XL or 650, where have builders placed the transponder antenna? I'm considering a location on the bottom of the aircraft, just behind the center spar and under the seat area. The advantages of that location seem to be a short coax run, minimizing signal loss. The disadvantages might be shadow effect on the ground.
That's where mine is, no complaints from ATC. That's where it is on most factory built planes.
I don't understand your concerns about shadow effects on the ground, the transponder isn't used on the ground for the most part. It's for signaling your position in the air.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
lwinger
Posted: Wed Jan 18, 2012 9:46 pm Post subject: Transponder antenna location |
Thanks, guys. Bryan, you're right about shadow effects. Not an issue.
Back to drilling.
Larry
On Wed, Jan 18, 2012 at 5:32 PM, Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)> wrote:
[quote]--> Zenith-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)>
Bryan Martin
N61BM, CH 601 XL,
do not archive.
target="_blank">http://www.matronics.com/Navigator?Zenith-List
http://forums.matronics.com
le, List Admin.
Tustin, CA
