Weak and Static on Transmission
bbradburry(at)bellsouth.n
PostPosted: Mon Jan 16, 2012 6:10 am    Post subject: Weak and Static on Transmission Reply with quote
I have a GNS430W radio and Advanced Aircraft Electronics high gain antenna model 5T in my Lancair Legacy (fiberglass fuselage). The antenna is mounted vertically behind the rear bulkhead on the right side of the fuselage. Although I didn’t need that much length to reach the antenna, I made the coax the recommended 13 feet or so length. (right now I cant remember the exact length recommended). This antenna is designed to be mounted inside plastic airplanes and doesn’t require a ground plane.
I get a “weak and lots of static but usable” reports from radio checks and on occasion, while airborne, static gets so great that I can not hear approach at all. I have had to make two NORDO landings at a Class C airport that is located under an overhanging Class B airspace due to the receiving static. The controllers are beginning to take exception to this and I need to get this fixed! :>)
I have checked the SWR on the antenna and it was around 1.5 which I understand to be fine.
Any ideas as to where I should begin my investigation on the source of this static?
Bill B
bakerocb
PostPosted: Tue Jan 17, 2012 6:37 am    Post subject: Weak and Static on Transmission Reply with quote
1/17/2012
Hello Bill Bradburry, You wrote:
1) "Although I didn't need that much length to reach the antenna, I made the
coax the recommended 13 feet or so length."
It may not have a direct bearing on your "weak and lots of static but
usable" problem, but it sounds like you are a bit confused about the antenna
requirements of the GNS 430W.
The specific coax length that you referred to in your posting refers to the
GPS antenna for the 430W. High quality coax such as RG400 is required.
Here is what AAE says about the cable length for one of their VHF comm
antennas:
"Q. What cable length is recommended for the antenna ?
A. Any length can be used. This antenna is impedance matched to 50 ohms to
allow you to use any length required."
2) "Any ideas as to where I should begin my investigation on the source of
this
static?"
You could narrow down the source of the problem a bit if you could borrow a
GNS 430W from a fellow builder or shop and install it temporarily for
testing. If the problem goes away the problem is inside your 430W box and
not the aircraft installation.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PS: Pull out and reseat your 430W box before going to the bother of
borrowing another unit -- the problem may just be a reseating or mis aligned
pin condition.
Time: 06:10:00 AM PST US
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Weak and Static on Transmission
plastic airplanes and doesn't require a ground plane.
I get a "weak and lots of static but usable" reports from radio checks and
static?
Bill B
PostPosted: Tue Jan 17, 2012 8:08 am    Post subject: Weak and Static on Transmission Reply with quote
At 08:07 AM 1/16/2012, you wrote:
. . . I get a “weak and lots of static but usable” reports from radio checks and on occasion, while airborne, static gets so great that I can not hear approach at all. I have had to make two NORDO landings at a Class C airport that is located under an overhanging Class B airspace due to the receiving static. The controllers are beginning to take exception to this and I need to get this fixed! :>)
Bob's points are well taken. I can expand by suggesting
that you are committed to the classic "divide and conquer"
ploy . . . you need to separate the potential for an antenna
system problems from the radio's potential problems.
It's difficult to sift the sands of potential problems
without hearing the nature of the "static". If you were
getting a signal report from a grey-bearded ham radio
operator he would qualify the report with "weak to the point
of inducing pop-corn noise", or succumbing to atmospheric
noises like lightning crashes, or scratching noise reminiscent
of a loose connection. Further, such noises heard by
experienced ears could probably tell if it was in the
RF or audio chain of your transmission system.
But alas, I've never heard a cogent signal report from
a tower operator and seldom from other pilots in their own
airplanes.
I'd recommend a series of experiments. Plug a
hand held into the antenna system and get signal reports
from other pilots. You can start on the ground but
they should probably be airborne so that they can fly
outbound and get some sense of signal strength along
with judgement of audio quality. If it doesn't repeat
on the ground, then you go flying too. If the other
guy reports noises, do YOU hear any noises? Open the
radio's squelch control and tune in stations some
distance away. Does the complaining controller repeat
the complaint while the hand-held is being used?
If the antenna system seems okay, this leaves the
radio. "Weak and static" suggests one or more issues
combining to reduce power output and introduction
of noises reminiscent of loose connections. Probably
nothing you can do about it personally except to
confirm poor performance by getting a measurement
of output power during an SWR check. This takes a
unique kind of instrument not often found in the
OBAM aviation toolbox.
[img]cid:.0[/img]
Also, check with someone else in another airplane or
even on the ground who overhears both sides of your
conversation with the controllers. Does that third party
agree with the controller's assessment? Can they refine the
description of "static"? I assisted in a similar
exercise many years ago where the builder left a
tape recorder running with the mic in front of
the Unicom receiver in his hangar. One could hear
both sides of the conversation. In this case, both
sides of the conversation were clear. We then did a
frequency check on the airplane radio and found that
it was at the high end of the spec . . . enough off
center to be at the edge of the government's receiver
bandwidth but still inside the bandwidth of the
lower cost receiver in the hangar. Replacing one
of the transmitter's crystals fixed the problem.
In your modern, frequency synthesized radio, this
is an exceedingly remote possibility.
The point is that you need GOOD data that tests
a host of possibilities. "Weak and static" from
one observer is insufficient data.
 Filesize:  18.62 KB
 Viewed:  16128 Time(s)
jonlaury
PostPosted: Wed Jan 18, 2012 9:30 am    Post subject: Re: Weak and Static on Transmission Reply with quote
Just to make sure the obvious is not overlooked, are you sure that the location of the antenna is surrounded by fiberglass and not RF-opaque carbon fiber?
IIRC, the Legacy uses a lot of CF in the airframe.
Kellym
PostPosted: Wed Jan 18, 2012 8:22 pm    Post subject: Weak and Static on Transmission Reply with quote
I'm surprised no one has brought up the obvious of likely P-static. Does
the aircraft have any static wicks?
http://forums.matronics.com/viewtopic.php?p=364203#364203
Kelly McMullen
KCHD
PostPosted: Thu Jan 19, 2012 6:08 am    Post subject: Weak and Static on Transmission Reply with quote
???? Hmmm . . . didn't know that about the Legacy
but I wondered when he made the reference to 'fiberglas'. I
thought it curious that Lancair would use the carbon
fiber in the IV and glass in the Legacy.
Yeah, if the antenna is inside a carbon structure
it's effectiveness is severely degraded.
PostPosted: Thu Jan 19, 2012 6:12 am    Post subject: Weak and Static on Transmission Reply with quote
of likely P-static. Does the aircraft have any static wicks?
He didn't mention flying in precip and static
wicks don't have anything to 'connect' to on
a glass airplane. If it's a carbon fiber then
wicks might be useful but my impression was that
his poor signal reports were at low altitudes
and probably slowed down for approach to landing
and in clear weather. P-static wouldn't hurt
a transmitted signal, only a received signal and
he didn't mention not being able to hear . . .
only be heard.
This is why the differentiation between weak-signal
static versus poor connection static is important.
The presence of carbon would support the notion of
it being the weak-signal variety.
PostPosted: Fri Jan 20, 2012 5:42 am    Post subject: Weak and Static on Transmission Reply with quote
Well, to further clarify this problem. I seem to be able to hear ok on the
ground while taxiing around the airport, but after I leave the airport the
reception gets really bad. At first I thought it was a problem with the
approach frequency because that is where it would first start up. It was a
loud hiss in the headphones so loud that I could not hear ATC. In fact, I
have made two NORDO landings as a result on this loud hiss. I sent my radio
back to have it checked out and nothing was found. All this trouble is at
below 5000 ft and fine weather. I am flying off my 40 hours (22 so far) and
am only flying in good weather. These radio problems at a Class C airport
have made me afraid to fly. ATC could take some action against me if it
continues.
Lancair has an all carbon Legacy available but this one is all fiberglass
with the exception of the horizontal stabilizer, which is carbon. The
antenna is inside the fuselage about 4+feet forward of the stabilizer.
The bottom and rear half of the plane is in primer. The rest of the plane
is bare fiberglass. The primer ends just about at the location of the
antenna on the fuselage. I don't know if this would have an effect on the
static on the plane or not. I would have had to consider static wicks a
long time earlier in the build in order to install bonding wire. It is too
late now AFAIK.
Bill B
wschertz(at)comcast.net
PostPosted: Fri Jan 20, 2012 6:18 am    Post subject: Weak and Static on Transmission Reply with quote
Bill,
Could this be interference from
1. Your EFIS?
2. Your electronic ignition at higher RPM?
I have an SL-30 with the antenna behind my rear seat bulkhead, and a SL-40
with the antenna a homemade in the vertical stab.
SL-30 is noisy like you describe, but the -40 works fine.
I think it is the EFIS (was worse with Blue mountain, still present with
Grand Rapids, but not as bad)
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
skywagon
PostPosted: Fri Jan 20, 2012 11:47 am    Post subject: Weak and Static on Transmission Reply with quote
Any chance that the kit has carbon material layered into the fiberglass for
some reason like rigidity, or some other form of strength needed..? Sure
sounds like the antenna is being blocked. Have you tried to temporary
substitute a simple outside antenna..? At least that would eliminate the
radio system as being the cause....
Dave
___________________________________________________________
bakerocb
PostPosted: Sat Jan 21, 2012 5:05 am    Post subject: Weak and Static on Transmission Reply with quote
1/21/2012
Hello Bill Bradburry, You wrote: "These radio problems at a Class C airport
have made me afraid to fly."
I consider the following items to be mandatory equipment in my experimental
amateur built airplane both during phase one testing and subsequently:
1) One of the readily available, portable, battery powered hand held VHF
communications radios along with both its original rechargeable battery
(recently recharged) and a spare fitted battery case filled with alkaline
batteries.
2) An adapter that allows me to plug my headset into the portable radio.
3) A means to temporarily connect the antenna connection of the portable
radio into one of the airplane's more capable antennae. Note that:
a) Actually using this temporary antenna connection is optional at the time
of intended use and initial attempts at communication may be made using the
antenna mounted on the portable radio itself.
b) Using this temporary antenna connection and the hand held radio for
trouble shooting may aid in locating the source of your communication
problem.
Following the above philosophy may take you out of the "afraid to fly
category".
When you eventually solve this problem please let us know what the problem
was -- thanks.
PS: You also wrote: "I sent my radio back to have it checked out and nothing
was found."
A "ground checks OK" result does not guarantee that the connection between
the radio and your airplane is also OK. Have you been able to borrow an
identical radio and test it in your airplane?
Time: 05:42:24 AM PST US
Subject: RE: Re: Weak and Static on Transmission
continues.
late now AFAIK.
Bill B
PostPosted: Sun Jan 22, 2012 7:55 am    Post subject: Weak and Static on Transmission Reply with quote
continues.
This is the first time I've been aware that you were having
problems both with hearing and talking. While the ground
listeners complain of "static" you have described the extraneous
audio as a "hiss". We may be talking of two different problems.
I'm having trouble resolving a single noise source that would
manifest in both what you hear and what is transmitted to the
ground.
Get a hand-held transceiver and use it to 'probe' around
the airplane. Use tune the hand-held to an unused frequency,
open the squelch and open the volume to get a low level of
no-signal hiss common to all receivers. Then probe around
the panel mounted goodies and wire harnesses with the
hand-held's antenna. See if the no-signal hiss changes
in level with the master switch on versus off. If it does
change, turn off accessories and/or pull breakers/fuses to
see if any one accessory produces a noticeable change
in noise from the hand-held.
You can use the hand-held as an airborne signal quality
sniffer too. Use a headset with the hand held to listen
to your own transmitted signals. You may have to take the
antenna off the hand-held to avoid overloading the hand-held
receiver. You don't need to talk on the ship's radio, just
listen to your transmitted signal to characterize the noise.
Is it the same "hiss" you hear in your received signals?
In any case, carry the hand held to avoid the no-radio
return to the airport. In fact, having the 'three musketeers
of dark-panel ops' in your flight bag is good insurance
for any flights:
www.aeroelectric.com/Pictures/Misc/Failure_Tolerance.pdf
It was also suggested that you try a substitute antenna.
I've fabricated test antennas that could be taped to the
top or bottom surface of a wing and coax brought into
the cockpit through the door gasket or some other pathway.
But using the hand-held to characterize your transmitted
and received signals personally takes ATC and others
out of the loop. This is an especially good thing when
they're unable/unwilling to join the discussion and
offer their own observations/insights.
Float Flyr
PostPosted: Sun Jan 22, 2012 10:54 am    Post subject: Weak and Static on Transmission Reply with quote
Do you get the same static when you return from a flight? Does the hiss go
away as the engine cools down?
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sun Jan 22, 2012 12:01 pm    Post subject: Weak and Static on Transmission Reply with quote
I have borrowed an ICOM A6 handheld that I could use to do the sniffing you
are describing, but I cant use it to transmit in the plane. It seems that
the A6 comes with a headset adapter, but if you don't also buy the optional
PTT adapter as well, both mics will be open at the same time.
Do you suggest a good value handheld radio? I need to buy one, but I am
concerned with the type of "gotchas" that ICOM seems to have. It also will
not transmit they tell me if the external power is plugged in.
During this probing you describe, I should have everything in the panel
turned on for the first pass, then if I get a response, start turning
everything off one at a time till I find what causes the response??
This includes the radio??
Bill B
Float Flyr
PostPosted: Sun Jan 22, 2012 2:15 pm    Post subject: Weak and Static on Transmission Reply with quote
The adapter you describe is simply a NO (normally open) momentary switch
connected to a 1/8 in mono jack. Both mikes only open if you push the PTT
switch on the radio.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sun Jan 22, 2012 3:42 pm    Post subject: Weak and Static on Transmission Reply with quote
I wonder why the handheld mike is not turned off when the headset adapter is
plugged in? That would solve the problem and you wouldn't need to buy an
"optional" part so that it will work.
I haven't noticed much of a problem with receiving when I am on the ground.
It also seems better when I get close to the airport and contact the tower.
At first, I thought the problem was with approach/departure freq because
that was where I had the most trouble.
Bill B
Float Flyr
PostPosted: Mon Jan 23, 2012 10:07 am    Post subject: Weak and Static on Transmission Reply with quote
The momentary switch is actually a remote PTT for the headset and doesn't
activate the built in mic.
What I was thinking is that you may have being having a problem with heat on
the spark plugs, voltage reg or rectifier. I had it happen once with a
R-582 when the seal for the water jacked perforated and allowed the plugs to
foul at anything less than WOT. What was happening was water from the
cooling system was getting into the cylinders and fouling the resistor
plugs. At one point I was flying literally feet from the tower's antenna and
still had major TX/RX problems.
Now assuming that your problem is not heat originated what I would try is
unloading your buss in flight to see if any particular circuit could be
interfering with your radio. The last test I would try is to use the
portable radio and shut down the master switch and the gen switch.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
ulflyer(at)verizon.net
PostPosted: Tue Jan 24, 2012 9:33 pm    Post subject: Weak and Static on Transmission Reply with quote
What kind of engine, if 2-stroke and using a voltage regular what brand is it, also what brand/model hand held radio are you using? I have almost the same identical problem.
When I first flying my new home built airplane it was fine, crystal clear both transmission and receiving. However, something changed, now I can hardly understand transmissions. I haven't yet been able to put my finger on what's changed and causing it.
jerryb
At 09:51 AM 1/22/2012, you wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
--> AeroElectric-List message posted by: "Bill Bradburry" <bbradburry(at)bellsouth.net>
continues.
ground.
for any flights:
AeroElectric-List Email Forum -
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
PostPosted: Wed Jan 25, 2012 6:23 am    Post subject: Re: Weak and Static on Transmission Reply with quote
When I first flying my new home built airplane it was fine, crystal clear both transmission and receiving. However, something changed, now I can hardly understand transmissions. I haven't yet been able to put my finger on what's changed and causing it. jerryb
The vast majority of electrical problems are caused by bad connections. I suggest that each connection be disassembled, mating surfaces cleaned, and fasteners tightened.
Joe
Joe Gores
PostPosted: Wed Jan 25, 2012 7:22 am    Post subject: Weak and Static on Transmission Reply with quote
Jerryb,
The engine is a Mazda Renesis rotary. It is a 4 stroke engine but has no valves, so it is somewhat like a two stroke. The voltage regulator is a Transpo V1200. I am trying to use a ICOM IC-A6 handheld radio with little or no success.
My problems are evolving as well. I was previously getting “5 by 5” responses from the tower on radio checks. Now it is “weak but usable”. The first flights were uneventful as far as radio communications go. I could hear them and they could hear me. Not so much now. As far as what has changed…well, I have been building on this plane for years!
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jerb
Sent: Wednesday, January 25, 2012 12:30 AM
Subject: RE: AeroElectric-List: Re: Weak and Static on Transmission
jerryb
continues.
ground.
for any flights:
